Old 4th January 2007, 18:22   #41  |  Link
Petetheking
Colorization
Hello ALL
Plz can anybody send me this rar file (complete file of colorization using optimizing cause link doesnt work)
Please im also very interested
THANKS a lot
Greets Peter
Petetheking is offline   Reply With Quote
Old 5th January 2007, 10:18   #42  |  Link
jimlong
Originally Posted by Hero-- View Post
Thanks, Hero. Mohan's work is really great. I also posted a message in that thread to see if anyone knows where to find e-male's work as well.
jimlong is offline   Reply With Quote
Old 8th January 2007, 21:33   #43  |  Link
E-Male
mad computer-scientist
hi guys & sorry for disappearing
I'll try to get a dyndns working again so you can get the files you want
I might also do some more video related coding soon (after doing Java for some time)
EDIT: for now:
http://rapidshare.com/files/10846379...ource.rar.html
should(!) be Ming Yang's original code, not modded by myself
E-Male is offline   Reply With Quote
Old 9th January 2007, 08:21   #44  |  Link
jimlong
Thanks, E-Male. File downloaded. Will take a look and compare with Mohan's work soon.
Old 17th January 2007, 21:58   #45  |  Link
Petetheking
Hi @ll!!!
How must i implement Visual c++ 5.0 with OpenCV to Compile his code property??
Can anyone give me a short tutorial ??
Plz cause first time with visual c++ and OpenCV!!! Normally i Made it in C++ Builder or Delphi
Thanks A LOT
Greets Peter
Old 13th February 2008, 02:17   #46  |  Link
Zarxrax
Hmmm, this seems very interesting. It seems like this would be extremely useful for the process of rotoscoping--that is, isolating an object from the rest of the frame. This is typically a very laborious process, as anyone who has ever used photoshop to remove the background from behind an object should know (just imagine doing that on every frame of a video clip!). The way this colorization process is able to detect the edges of objects, it seems that this could almost automate the process with very little user input.
Could anyone comment on whether this code would indeed be suitable for such a process?
Zarxrax is offline   Reply With Quote
Old 26th November 2008, 07:09   #47  |  Link
chr2000
EDIT: for now:
Hi, is there anybody post the code again? I can not download the code. thanks
chr2000 is offline   Reply With Quote
Old 26th November 2008, 16:51   #48  |  Link
Fizick
AviSynth plugger
Fizick's Avatar
I should have it somewhere at harddrive (original, not E-male plugin).
What do you want to do with a code?
Old 27th November 2008, 02:37   #49  |  Link
chr2000
I just want to know how to color one image correctly, and does this code works?
I had done some work about tranfering color to gray image serveral years ago. I know that it is very difficult to adapt the algorithm to all kinds of image.
Old 27th November 2008, 06:30   #50  |  Link
Fizick
AviSynth plugger
Fizick's Avatar
i found the archive (in my "Imaging" foder, not video-related). where to put it, to preserve it from disappearing again? It is 1.62 Mbytes.
Old 27th November 2008, 10:16   #51  |  Link
Comatose
I think the best solution might be to attach it here.
Comatose is offline   Reply With Quote
Old 27th November 2008, 18:51   #52  |  Link
Fizick
AviSynth plugger
Fizick's Avatar
max attachment size = 200 kbytes
temporary mirror:
http://avisynth.org.ru/tmp/ColorSource.rar
chr2000, if you can provide a mirror, do it.
and please post your results if any
Old 1st December 2008, 02:01   #53  |  Link
chr2000
here is the mirror
http://www.freedrive.com/file/585019
