Old 27th February 2016, 13:02   #21  |  Link
LigH
LigH's Avatar
Under Windows, you may use jb_alvarado's media-autobuild_suite to compile x264 with included libav inside an MSYS environment. I hope you can analyze their script to discover some hints how to create a matching configuration.
German doom9 / Gleitz board
MediaFire shares: x265 | VPx | AOM | Xvid
Rémoulade is spoiled
Old 28th February 2016, 12:54   #22  |  Link
hydra3333
Thank you. I fluked mp4: yes, with this
# x264 cloned by now, and gpac is already built in mp4box_gpac
cd x264
mkdir ./gpac
chmod 777 ./gpac
echo " ------------------------- copying gpac include files ... "
cp -R -v ../mp4box_gpac/include/gpac/* ./gpac
echo " ------------------------- copying gpac_static.a file ... "
cp -v ../mp4box_gpac/bin/gcc/libgpac_static.a ../mp4box_gpac/bin/gcc/gpac_static.a
export LDFLAGS=-L../mp4box_gpac/bin/gcc/
export CFLAGS="$CFLAGS -I./gpac"
# now get on with the cross-compile
The resulting x264.exe reports a funny error though,
".\x264.exe" --thread-input --threads 8 --profile high --level 4.1 --preset fast --interlaced --tff --no-cabac --crf 18 --sar 64:45 -o "temp.h264" "input.mpg"
raw [error]: raw input requires a resolution.
x264 [error]: could not open input file `input.mpg' via any method!
As mentioned above, it looks like I also need to compile libav libraries for lavf-support and add that to LDFLAGS and CFLAGS and see if that makes a difference.
Or, since by that time I've cross-compiled ffmpeg, find out how to "link to" libavformat.a and .h files (or something like that) which hopefully may be cross-compiled as a part of ffmpeg.
I took a look at a ./configure file to see how it "detects" however it is beyond my skills for the time being.
I'll goggle pkg-config to find out what that is and hope it is compatible with Ubuntu based mingw cross-compiling.
I'll also goggle jb_alvarado's media-autobuild_suite as well as config.log.
linux newbie: and I'll also need to goggle how to put multiple paths in each of "LDFLAGS=-L" and "CFLAGS= -I" unless you can suggest it
Old 28th February 2016, 13:16   #23  |  Link
LigH
LigH's Avatar
github.com/jb-alvarado/media-autobuild_suite
It contains heavy Windows cmd batch and bash shell scripts for installing and using a MSYS/MinGW cross compiling suite under Windows. I doubt it would run under a real Linux as a whole, but should contain good material to adapt your own workflow from.
Old 28th February 2016, 13:20   #24  |  Link
hydra3333
Originally Posted by LigH View Post
Beaut, thanks.
edit: my attempt is also 99% based on the very nice, linux cross-compiling tool from Roger Pack : https://github.com/rdp/ffmpeg-windows-build-helpers (as updated when comparing it to zeranoe's listed sources).
Old 29th February 2016, 09:35   #25  |  Link
jpsdr
I've made a tutorial build for x264 here.
Even if it's Windows related, at least for the MSYS2 part, i think you can use all the others informations, it may help you.
Old 26th March 2016, 13:22   #26  |  Link
hydra3333
I finally got x264 to cross-compile with gpac for .mp4 compatibility and with ffmpeg lavf libraries so that it directly accepts input like .mpg etc as input ... with the help of your examples, using ubuntu, a variation of rogerdpack's script (uses mostly latest source versions, or zeranoes, depending) and a variation of zeranoe's toolchain build script (to use the latest compiler and related stuff). It's a horrific train-wreck of a hacked up script used for debugging ... but it did work.
To me as a linux knowledge free zone, it seems that the configure file for x264 has a number of non-obvious fixed dependencies, eg things like
- pkg-config had to be copied from /usr/bin/pkg-config into the cross-compiler folder with a different name based on a cross_prefix, since the toolchain build script didn't (copy a linux-runnable pkg-config, which the configure needs to see
- setup of PKG_CONFIG_PATH and PKG_CONFIG_LIBDIR
- copying ffmpeg sources and libraries into specific folders
- copying gpac sources into a specific folder and a .a file to specific place with a specific name
- using a custom configure_flags to point to the right places
So now, to consider whether to spend the time to find out why the mp4box built via rogerdpack's script produces .mp4 files which don't behave right when played in mpc-hc, as compared to the the official mp4box; eg when playing a .mp4 and click say 3/4 down the timeline and then the audio plays but the video takes 5 seconds to catch up and start playing, whereas an .mp4 with same video and audio but produced by an older mp4box handles it just fine with no "catchup" (using the same commandline on mp4box).
Old 13th October 2016, 17:30   #27  |  Link
Selur
Selur's Avatar
Anyone got statically linked 8bit and 10bit x264 versions which run on Mac OS X Sierra?
Builds from http://download.videolan.org/pub/vid...macosx-x86-64/ don't work on Sierra
Old 17th February 2017, 14:52   #28  |  Link
Barough
Barough's Avatar
x264 0.148.2762 90a61ec - 8 bit & 10 bit Win32/64 Binaries
(libswscale 4.3.101)
(libavformat 57.66.102)
(ffmpegsource 2.23.0.0)
Built on Feb 17 2017, GCC v6.3.0
http://ge.tt/3gT9Eri2
https://git.videolan.org/?p=x264.git;a=summary
Old 17th February 2017, 17:50   #29  |  Link
Midzuki
Unavailable
Midzuki's Avatar
Time for an overdue update to post #1, me thinks.
Namely, remove the links to x264.nl and fushizen.eu.
OR add a notice informing that those sites haven't been updated since ages ago.
Midzuki is offline   Reply With Quote
Old 17th February 2017, 23:13   #30  |  Link
LoRd_MuldeR
Software Developer
LoRd_MuldeR's Avatar
You are right. I removed the defunct "x264.nl" and "doom10" links and also added an outdated notice to the "fushizen.eu" link.
(If there are any more links you'd like to see there, let me know)
Old 18th March 2017, 10:30   #31  |  Link
Midzuki
Unavailable
Midzuki's Avatar
Hummm, post #1 has other broken links :-/
Other posts also have broken links :-/
komisar's site hasn't been updated with the latest stable release of x264 :-/
Probably it's better to bury this thread and replace it with a brand-new sticky...
Old 18th March 2017, 14:40   #32  |  Link
LoRd_MuldeR
Software Developer
I will try to fix some more of them!
Well, I think we can't keep every link in every post up-to-date all the time. I will concentrate on the first one.
Slightly outdated, yes. But I'm hoping for update soon.
It's not like there have been fundamental changes in x264 since the 2016/12 build.
Old 25th May 2017, 18:34   #33  |  Link
Barough
Barough's Avatar
x264 0.150.2833 df79067
Built on May 25 2017, GCC v6.3.0
DL :
http://www83.zippyshare.com/v/XRwxwj4Z/file.html
Old 25th May 2017, 22:14   #34  |  Link
LigH
LigH's Avatar
I remember that x264 started to require NASM 2.13 (to support AVX512, I believe?) to build in the media-autobuild_suite.
Old 25th May 2017, 23:17   #35  |  Link
Midzuki
Unavailable
Midzuki's Avatar
That's correct, and it's mentioned in the changelog itself.
https://www.videohelp.com/software/x264-Encoder
Old 26th May 2017, 12:19   #36  |  Link
LoRd_MuldeR
Software Developer
Now has
Old 26th May 2017, 13:55   #37  |  Link
Midzuki
Unavailable
Midzuki's Avatar
Originally Posted by LoRd_MuldeR View Post
Now has
ő/
Even though his builds are v. 2829 and mine are v. 2833
(just like Barough's ones)
Old 26th May 2017, 15:47   #38  |  Link
LoRd_MuldeR
Software Developer
ő/
If you look at the commit log, you'll probably notice that in the last four commits there were no changes that effect static Win32 builds.
Old 26th May 2017, 17:53   #39  |  Link
komisar
komisar's Avatar
no, i am delete my message
..::[I am live here]..::..[My x264 CLI/VFW builds and tools]::..
komisar is offline   Reply With Quote
