Old 28th April 2007, 00:22   #361  |  Link
BlueCup
Originally Posted by Backwoods View Post
www.flmpro.com/DLLreq.zip
Chanmix and GiCoCu
You didn't look hard enough.
BlueCup is offline   Reply With Quote
Old 28th April 2007, 13:23   #362  |  Link
anton_foy
Whohoooo!
@ BlueCup
Thank you my friend, they like to hide for some reason hehe.
anton_foy is offline   Reply With Quote
Old 28th April 2007, 14:06   #363  |  Link
E-Male
mad computer-scientist
I haven't been here for some time, so I din't see the requests until today.
I currently can't access the HD with my old programming stuff.
But I'll try to get the dlls and sources as soon as I got my new PC and will upload anything I could save to some webspace.
THX a lot to anyone providing mirrors.
E-Male is offline   Reply With Quote
Old 28th April 2007, 17:36   #364  |  Link
anton_foy
Thats ok E-Male I got it now. Was a fool not knowing it was in the DLLreq.rar.
But cannot get ChanMix to work. The image just comes out black and white when testing.
Converttorgb24().ChanMix(10,10,10).Converttoyv12()
Is Chanmix exactly like in photoshop BTW.? In photoshop you can adjust RGB for each.
Like:
Red: red
green
blue
Constant
Green: red
green
blue
Constant
Blue: red
green
blue
Constant
And values between -200 to +200
Old 29th April 2007, 14:28   #365  |  Link
E-Male
It is supposed to create greyscale output.
The 3 parameters are the weight of each color channel.
Old 2nd May 2007, 11:41   #366  |  Link
Korben
actionman133 could you please post your curve.txt again. And beside this,the Tint function on avisynth homepage (http://avisynth.org/index.php?page=Tint) doesnt work properly.
It says:
VirtualDub Error
Avisynth open failure:
Overlay: Mask and overlay must have the same image size! (Height is not the same)
(tint.avs, line 29)
(O:\Capture\Project_107\720p.avs, line 33)
Any ideas?
BR
Korben is offline   Reply With Quote
Old 4th May 2007, 16:35   #367  |  Link
actionman133
Movie buff & shine
Sorry Korben, I've long since deleted that curve file and I can't remember what values I used.
I had a look at the script but I can't see where it's going wrong... What are the dimensions and colourspace of your clip?
I'm a boxer who can Bob () & Weave (). I like to Overlay () punches and Blur () his vision to ShowFiveVersions (). My KO punch will always Pulldown ().TimeStretch () and all he will hear is Tone ().
actionman133 is offline   Reply With Quote
Old 5th May 2007, 09:42   #368  |  Link
Korben
Ok.. no problem, if anybody has still the curve.txt please post it.
I dont know why, but it works now. The video is just SD-Video, 720x480. Iam almost using YUY2.
Old 12th May 2007, 14:43   #369  |  Link
anton_foy
Another ChannelMixer
Recently my friend Gustaf Ullberg made another ChannelMixer plugin. It is identical to the Photoshop ChannelMixer and it supports RGB24 and RGB32 colorspaces. Hope you like it.
http://redshift.xtreem.nu/gustaf/fil...mixer_v1_0.zip
Old 12th May 2007, 22:18   #370  |  Link
BlueCup
Great news, thank you.
Old 18th May 2007, 15:02   #371  |  Link
anton_foy
Gicocu bugg?
When using a Photoshop curve with GiCoCu everything works fine but if I use two curves in a row like this:
GiCoCU("C:\Projekt\Curve1.amp",photoshop=true)
GiCoCU("C:\Projekt\Curve2.amp",photoshop=true)
my image gets a strong blue tint all over.
Possible bugg or Im doing something wrong?
Old 19th May 2007, 08:40   #372  |  Link
BlueCup
Just curious, what version of Photoshop are you using?
Old 19th May 2007, 11:44   #373  |  Link
anton_foy
@BlueCup
Im using 7.0...I know its old
Old 20th May 2007, 05:51   #374  |  Link
BlueCup
Just making sure because I think CS1/2 (don't know about 3) save curves in a different file format.
Old 30th May 2007, 07:48   #375  |  Link
WorBry
I'd be interested in that curve file also. Does anyone still have a copy?
WorBry is offline   Reply With Quote
Old 24th July 2007, 11:38   #376  |  Link
jkwarras
jkwarras's Avatar
I'm using the Backwoords script V2F on some DV PAL interlaced footage. It's great! Some thoughts:
1) Anyone has worked out a new version with new plugins, simpler, or with less color conversions?
2) I see in the output (it's a weeding video, outdoors, natural lights) some artifacts, like mosquito noise around edges. I guess it's due to some of the overlay, blur, masks stuff in the scripts.
3) Deinterlacing with leakkerneldeint (0) gives a progressive video and more film look feeling.
4) Grain is difficult, because adding addgrain(18,0,0) it's too much for me. Adding 10 is fine, but I see it too much. It's "over" the picture, not "in" the picture as in film. Adding it on the second step (FILM) brings more edges and it look worst. I've tried noisegenerator.dll and I get weird results, with colour changes.
5) Does someone knows if it'll be better (and quicker/simpler) to apply curves like the Panasonic DVX100 or HVX200 does? Another think is to get them and how to apply them to video.
Iván
Blog: http://ivancastell.org | Myspace: http://myspace.com/ivancastell | Last.fm: http://lastfm.es/user/jkwarras/
jkwarras is offline   Reply With Quote
Old 24th July 2007, 12:02   #377  |  Link
scharfis_brain
brainless
scharfis_brain's Avatar
3) use a more sophisticated deinterlacer like yadif, or mcbob/mvbob.
Don't forget the 'c'!
Don't PM me for technical support, please.
scharfis_brain is offline   Reply With Quote
Old 24th July 2007, 17:19   #378  |  Link
jkwarras
jkwarras's Avatar
Nice, I'll try one of these. Thanks.
Iván
Old 25th July 2007, 03:22   #379  |  Link
Mug Funky
interlace this!
Mug Funky's Avatar
film grain is tricky. negative film has much more grain in the darks than the highlights. however, most "film look" people experience is telecined film on TV. telecine machines on neg film will add their own noise to the highlights, but it's a different sort of noise. a simple luma mask could sort this out though.
applying curves to get a film look is also tricky - 1D LUTs aren't enough to reproduce some of the effects of exposed film. it doesn't take crosstalk into account (channel mixing). a 3D LUT can handle this very well though, and in fact there's a lot going on in the DI world that involves getting good 3d LUTs to simulate certain effects (bleach bypass, certain specific stocks, etc). these tend to be proprietary though, and usually made via direct measurements.
i'd love to see a 3d LUT plugin for avisynth, but it'd only be really useful in 10 bits or more (preferably float).
Old 25th July 2007, 04:50   #380  |  Link
IanB
Avisynth Developer
3d LUT, well it ain't gonna be fast, 256x256x256=16,777,216 table entries. At 3 bytes per entry give a 48Mb table. Certainly do-able with current machines, but oh what it will do to the L1 and L2 caches.
Full 10 bit is even worse, 1024x1024x1024=1,073,741,824 tables entries. At 3 words per entry gives a 6Gb table, sure you could spec an x64 machine to cope.
Compromise 10bit might just fit, 1024x256x256=67,108,864 table entries. At 1 word plus 2 bytes per entry gives a 256Mb table.
By understanding a particular table some clever tricks may be possible to drastically reduce the load, but then it's not general LUT anymore.
IanB is offline   Reply With Quote
