Old 10th May 2007, 21:19   #121  |  Link
Bluedan
Bluedan's Avatar
Promising!
I'd be glad to be prime tester on monday!
I'm probably misconfused...
Bluedan is offline   Reply With Quote
Old 12th May 2007, 19:51   #122  |  Link
squid_80
New 64-bit avisynth.dll and tdeint are available. Tdeint's double height ELA modes (-2 and -1) get a pretty big speed increase over the 32-bit version but the other modes actually seem a tiny bit slower. I think that's because even though intel's x64 compiler allows inline assembly, it acts very cautiously around it (dumps all parameters passed in registers onto the stack, even if they're being put back into the same registers).
Motion.dll will have to wait - Clouded's fluent use of template functions seem to confuse the hell out of the compiler and I can't get it to play nice.
Edit: Ok, got motion.dll working. The problem was the compiler was inlining the template instantiations, then when another part of code tried to use them it couldn't find them and was too stubborn to create another instance. It's FAST - nearly 20% faster - but there's a bug somewhere so I'll have to fix it before releasing.
squid_80 is offline   Reply With Quote
Old 13th May 2007, 12:07   #123  |  Link
Bluedan
Bluedan's Avatar
Great!!
Old 13th May 2007, 14:49   #124  |  Link
squid_80
Ok, I've uploaded another new build of 64-bit avisynth.dll which includes reduceby2, horizontalreduceby2 and verticalreduceby2. Also available are 64-bit ports of masktools v1.5.8 (http://members.optusnet.com.au/squid_80/masktools64.zip) and motion.dll (http://members.optusnet.com.au/squid_80/motion64.zip) which should be everything needed for the motionprotectedfps script to work. I've tried it here and get ~10% speed increase above standard 32-bit. But everything new is fairly untested so if there's any problems please let me know. If no-one finds anything wrong with masktools or motion I'll add them to the main page at the end of the week.
Old 13th May 2007, 18:30   #125  |  Link
Wilbert
@squid_80,
Is that bug also present in the "32 bit" source? If so, did you correct that too?
Old 13th May 2007, 18:44   #126  |  Link
squid_80
No, it was a bug in my 64-bit translation. There were a couple of possible bugs in masktools that I corrected, but I can't be sure if they were real bugs or just a misunderstanding on my part. I will post my source code ASAP.
Old 14th May 2007, 03:15   #127  |  Link
Blue_MiSfit
Derek Prestegard IRL
Blue_MiSfit's Avatar
Dude, squid_80, thanks so much for all your hard work! Something worth running in 64 bit is always welcome!!!
~MiSfit
Old 15th May 2007, 15:44   #128  |  Link
squid_80
But wait there's more: 64-bit TCPDeliver. If you get a message about versions not matching, here's a 32-bit build that should work with it. (Yes, of course it's possible to send from a 64-bit program to 32-bit and vice versa.)
Old 22nd May 2007, 10:05   #129  |  Link
squid_80
DeFreq for x64 (with 64-bit fftw3.dll): http://members.optusnet.com.au/squid_80/defreq64.zip
Approx 20% speedup.
Old 14th June 2007, 23:28   #130  |  Link
Bluedan
Bluedan's Avatar
How do I have to change this script (it's generated with megui) to make the TDEINT/EEDI thing work? This way x264 32bit is called, not the 64bit compile, though I have put the 64bit filters in the usual place... which indicates to me that everything in use is 32bit.
# Set DAR in encoder to 47 : 20. The following line is for automatic signalling
global MeGUI_darx = 47
global MeGUI_dary = 20
DGDecode_mpeg2source("F:\Casino Royale\cr.d2v")
edeintted = last.AssumeTFF().SeparateFields().SelectEven().EEDI2(field=-1)
TDeint(order=1,edeint=edeintted)
crop( 0, 74, -2, -76)
Lanczos4Resize(720,432) # Lanczos4 (Sharp)
#denoise
Old 26th June 2007, 02:03   #131  |  Link
lariva
First and foremost - thanks for all the work.
Do you have any plans to look at dgindex for 64-bit? The version that you currently have up is 1.4.6, which works great for everything other then DTS, 1088 (instead of 1080) width for .ts streams.
Sidebar: http://www.nvidia.com/object/tesla_gpu_processor.html
I'm curious if this could actually be a universal solution - the only problem i see is 128 parllel threads.
Approx 20% speedup.
lariva is offline   Reply With Quote
Old 16th July 2007, 18:36   #132  |  Link
squid_80
aWarpSharp for x64.
Old 24th July 2007, 23:54   #133  |  Link
Ferux
Ferux's Avatar
Hi, i'm trying to use Avisynth x64 (actually just for making x264 work as a 64-bit app), but it doesn't work. I putt the avisynth.dll in my I:/Windows/system32/ folder, double-clicked the registry-file and rebooted, but Virtualdub64 still can't open the most simple AVS-script (script with only 'avisource' and with the audio disabled). What do I do wrong? Or do I need ffdshow64?
Ferux is offline   Reply With Quote
Old 25th July 2007, 04:33   #134  |  Link
squid_80
What does veedub64 say and what operating system are you using? Have you checked with windows explorer (not total commander or any other crap) that avisynth.dll is in windows\system32 and not windows\syswow64 by mistake?
Old 25th July 2007, 11:52   #135  |  Link
Ferux
Ferux's Avatar
Veedub64 says:
VirtualDub Error
AVI Import Filter error: (Unknown) (80040154)
Avisynth.dll is in the right folder as you say.
My OS is Windows XP x64
Old 25th July 2007, 13:00   #136  |  Link
squid_80
First install the vs2005 sp1 redistributable package to make sure that's not the issue: link.
Make sure you're not double-clicking the .reg file from inside an archive manager program - extract it to somewhere first then double click from explorer. Same goes for avisynth.dll - don't extract directly to \windows\system32, extract to somewhere else then copy it into system32 (I know you've said it's there already, this is just for anyone else getting the same problem).
Please let me know how you get on.
Old 25th July 2007, 13:17   #137  |  Link
Ferux
Ferux's Avatar
I tried to install the software in your link, but the installer seems to exit few seconds after I accept the agreement. I don't think this is normal...
I'm starting to think something is wrong with my system since ffdshow64 won't install either. It's weird because I formatted this PC last week.
Old 25th July 2007, 13:24   #138  |  Link
Ferux
Ferux's Avatar
OK, I found the solution:
The problem is the ATI 'Catalyst' driver. I terminated ccc.exe (Catalyst Control Center I guess) with the Task Manager. When trying to open my AVS-script I got an AVS-error, so from this point, AVS64 was working. I installed ffdshow64 (apearantly ccc.exe was also the reason why this didn't install) and now everything is going fine.
Anyway, thanks squid_80 for your help (and the 64-bit apps ).
Old 25th July 2007, 16:27   #139  |  Link
squid_80
I hate that program. It crashes at random, requires a download of some ridiculous size (something like 30 megs last time I checked) and is so slooow at changing screens - especially unforgivable since it's written by a graphics manufacturer. Then again it uses .NET so I'm not that surprised.
It's going on my naughty programs list (right below windows messenger).
Old 20th February 2008, 00:23   #140  |  Link
XBoy
64 bit avisynth
Where can I get the source for 64bit avisynth?
Mainly I need the avisynth.h file to port a plugin over to 64bit.
XBoy is offline   Reply With Quote
