Old 14th November 2005, 01:42   #821  |  Link
LoRd_MuldeR
Software Developer
LoRd_MuldeR's Avatar
Really strange !!!
I've made a clean re-install of Windows today and now BeLight looks correct
I use WinXP (SP1)
Got no idea how to reproduce this problem. Only thing I know is, it's gone...
Old 14th November 2005, 02:02   #822  |  Link
7ven
Audiografix
7ven's Avatar
Hello Kurtnoise13,
So, I update the newest BeLight Version, but Itīs the same Problem what I posted here http://forum.doom9.org/showthread.ph...949#post734949
Thanks 7ven
7ven is offline   Reply With Quote
Old 14th November 2005, 08:07   #823  |  Link
Kurtnoise
Swallowed in the Sea
Kurtnoise's Avatar
Yes...I'll try to fix that asap.
Old 14th November 2005, 08:44   #824  |  Link
dwrbudr
Unregistered User
dwrbudr's Avatar
Maybe the problem is in the use of frames in delphi.
my subtitle site
dwrbudr is offline   Reply With Quote
Old 14th November 2005, 09:10   #825  |  Link
7ven
Audiografix
7ven's Avatar
a lot
7ven
Old 14th November 2005, 20:34   #826  |  Link
Kurtnoise
Kurtnoise's Avatar
It should be ok now....
http://corecodec.org/frs/?group_id=4...se_id=215#r215
Old 15th November 2005, 12:50   #827  |  Link
opsis81
@ Kurtnoise
Greek language for BeLight 0.22 beta 8
Download Hellenic.ini from
http://rapidshare.de/files/7664009/Hellenic.ini.html
opsis81 is offline   Reply With Quote
Old 15th November 2005, 13:00   #828  |  Link
Jalavera
Cosmetic bug:
In the WAV/PCM tab when click on DD-WAV (output format) then 'Output channels' doesn't disappear. These output channel only affect to WAV or AIFF not DD-WAV.
In fact if you select DD-WAV as output format nothing happens to 'output channels' but if you change the tab (i.e MP3, VORBIS,...) and come back to WAC/PCM then 'output channels' options disappear.
Jalavera is offline   Reply With Quote
Old 15th November 2005, 13:17   #829  |  Link
MacAddict
XviD User
Originally Posted by Kurtnoise13
Yep, seems to have fixed the DRC button box bug. Thx
DFI NF4 SLI Expert | Opteron 165 CCBBE 0616 XPMW (9x325HTT=2.9Ghz) | 2x1GB G.Skill HZ (3-4-4-8-12-16-2T) | LG 62L DVD/CD | Geforce 7300GT | All SATA | Antec 650 Trio PSU | XP SP2
MacAddict is offline   Reply With Quote
Old 15th November 2005, 13:36   #830  |  Link
dimzon
BeHappy/MeGUI developer
dimzon's Avatar
Annoing bug
dimzon is offline   Reply With Quote
Old 15th November 2005, 16:22   #831  |  Link
subiksha
How to check
How to view the belight (or any) encoded file info ....
subiksha is offline   Reply With Quote
Old 15th November 2005, 16:27   #832  |  Link
dimzon
dimzon's Avatar
Try latest foobar2000 beta
Old 15th November 2005, 22:02   #833  |  Link
wdmalik
Struggling for Perfection
wdmalik's Avatar
well found a strange bug today ...
I think it should be
Time Elapsed 00:00:32 & Time Remaining 00:02:57
and there should be no AM there as well
EDIT: if it help somehow, the encoding was done during PM not AM
version 0.2.2.0 @14/11/2005
wdmalik is offline   Reply With Quote
Old 16th November 2005, 03:27   #834  |  Link
ron spencer
DVD Magistrate
this bug has been there for a while
ron spencer is offline   Reply With Quote
Old 16th November 2005, 03:36   #835  |  Link
schrady
How about the LST feature?
Is that going to be reenabled? Being able to process a list of files is a great feature
schrady is offline   Reply With Quote
Old 16th November 2005, 09:56   #836  |  Link
Kurtnoise
Kurtnoise's Avatar
Come on...go back to the earth. This is not a bug. You have probably an US Windows. That's can explain why. Coz I don't have this trick here with a french Windows. Btw I can modify this.
@dimzon: sorry. I check again and again and I don't know why for the moment.
@opsis : Thank you very much. I'll add it.
@schrady : what do you mean ? A batch mode or a Job List ? coz the batch mode should be ok now and I'm working on the Job List.
Old 16th November 2005, 11:21   #837  |  Link
dimzon
dimzon's Avatar
Seem's like it's wellknown bug occured in Delphi applications when its running under different screen font dpi:
Old 16th November 2005, 16:22   #838  |  Link
ron spencer
DVD Magistrate
I am referring to batch or anything....I am referring to the time on the bottom. It gives clock time on my machine...don't know what this has to do with U.S. or French installation
Old 16th November 2005, 17:22   #839  |  Link
LoRd_MuldeR
Software Developer
@dimzon
I had this bug on my machine too. Only a clean re-install of Windows fixed the problem...
Old 16th November 2005, 17:32   #840  |  Link
dimzon
dimzon's Avatar
This is pure BeSweet issue!
