Old 20th June 2005, 10:38   #461  |  Link
drob
I can confirm problems with batch processing, BeLight only runs one of the jobs, usually the last one, in other cases it reported transcoding done, without actually doing anything.
There seems to be an issue with latest b30 of BeSweet, BeLight finished the job, log file confirmed the job was done, but didn't change the button to green and the status still showed trasncoding, or when transcoding into mp2, i got BeSweet doesn't exist.
When transcoding into mp2 using b29 of BeSweet, i got the BeSweet is a command line and has a GUI pop up.
Encoding into mp2 doesn't have the option for adding the -e error correction switch, trying to edit he command line didn't help.
I tried the progress bar issue both in inputing AC3 to wav and to mp2.
drob is offline   Reply With Quote
Old 20th June 2005, 12:33   #462  |  Link
Kurtnoise
Swallowed in the Sea
Kurtnoise's Avatar
Thanks for the bug report, I'll fix that asap...
Old 20th June 2005, 14:40   #463  |  Link
drob
Old 20th June 2005, 15:58   #464  |  Link
aliumalik
Posts: n/a
Is it me or progress bars aren't working in beta4?
Thanks for that noid3 option Kurt
Old 20th June 2005, 18:21   #465  |  Link
johnman
johnman's Avatar
I just recieved this notification from my firewal:
Application Hijacking has been detected
The application: F:\......\BeLight.exe  try to launch another
application: F:\.....\mozilla.exe  to go to remote host  www.paypal.com
Am i the only one with this problem?
Im doing a virus check now since i suspect something is wrong with my system (totaly unrelated to belight) just to be shure.
johnman is offline   Reply With Quote
Old 20th June 2005, 18:50   #466  |  Link
m0rtal
open source addict
m0rtal's Avatar
nothing suspicious @ my pc atm... take care
Software is like sex - better when it's free!
m0rtal is offline   Reply With Quote
Old 20th June 2005, 21:19   #467  |  Link
johnman
johnman's Avatar
Nothing found by online scanner and my own scanner.
Dont know what's the cause of this.
Old 22nd June 2005, 08:18   #468  |  Link
deets
just wanted to say thanks, its a nice gui
deets is offline   Reply With Quote
Old 22nd June 2005, 15:16   #469  |  Link
Paulcat
It IS a nice GUI, but...
I am trying to transcode 6 (six) MP3 files to AC3 format. I dragged all six into the menu box, but checked only the first one. The transcoding went fine (I did one to see how long it would take). I then checked 2 through 6 and started processing. I got logs for 2 and 6 only, and it kept over-writing the AC3 I had made for MP3 #1!
I got the job done by doing one at a time, closing and re-opening BeLight for each one, however, it was a bit of a pain. And, no, the progress bar did nothing for me either!
It is a beta version though!
Paulcat
p.s. I am using the latest BeSweet 1.5 beta30 and BeLight 0.22 beta4. To convert to AAC, can I use the DLL's from corecodec? Are they recognized by being in the BeSweet directory or is something else needed?
Paulcat is offline   Reply With Quote
Old 22nd June 2005, 16:36   #470  |  Link
LigH
LigH's Avatar
CoreCodec made an AAC *en*coder? That's new to me - I thought they only provide a *de*coder filter.
For encoding to AAC, BeSweet only supports the Nero AAC encoder via BSN, as far as I know.
Old 22nd June 2005, 17:41   #471  |  Link
daphy
Miles Freak
daphy's Avatar
Hi Kurt,
first impression: the GUI looks real nice and works fine so far
two thinks Ive noticed while trying to split a 32bits 6channel WAV:
I found no way to use this command with the GUI
BeSweet.exe -core( -input "c:\...\6ambi1.5.wav" -output "c:\...\6ambi1.5-New-" -6chfloat -logfilea BeSweet.log ) -ota( -G 0.95 )
while spliting into channels the 0% stay constant -> maybe someone else has posted this before
CYA Daphy
daphy is offline   Reply With Quote
Old 23rd June 2005, 18:10   #472  |  Link
Kurtnoise
Kurtnoise's Avatar
Heya,
Sorry for the delay guys...I'm really busy with my job.
Do you use the GUI to create the command line or your hands + run button ? If you use BeLight, it's maybe a bug. I'll check out this thing.
indeed...
Old 28th June 2005, 04:03   #473  |  Link
ron spencer
DVD Magistrate
first off...thanks for the proggy.,
when it is done converting 5.1 to 2.0 WAV (which is does perfectly), the dialog stops with an x and says "transcoding aborted" probably should be "transcoding finished"
ron spencer is offline   Reply With Quote
Old 28th June 2005, 09:15   #474  |  Link
dwrbudr
Unregistered User
dwrbudr's Avatar
@Kurtnoise13: Can you redirect the console output into some memo box in the GUI? This is done using pipes. I can supply some delphi code if you want. I used that technique in an old project I've done and it works fine.
my subtitle site
dwrbudr is offline   Reply With Quote
Old 28th June 2005, 11:59   #475  |  Link
Kurtnoise
Kurtnoise's Avatar
fixed....
Old 28th June 2005, 12:02   #476  |  Link
Kurtnoise
Kurtnoise's Avatar
for what for ?
Use the logfile option. It gives you exactly what you looking for.
Old 28th June 2005, 13:40   #477  |  Link
ron spencer
DVD Magistrate
thanks Kurtnoise...does this mean that we should re download beta 4? Or are you making a beta 5?
Old 28th June 2005, 13:45   #478  |  Link
dwrbudr
Unregistered User
dwrbudr's Avatar
@Kurtnoise13: Because I cannot see the progress of the transcoding. I'm using the latest beta and transcoding to AAC, but the current and total progress bars are always at 0%. Redirecting the console to text box is really easy - about 20-30 lines of code
my subtitle site
Old 28th June 2005, 20:01   #479  |  Link
Kurtnoise
Kurtnoise's Avatar
Just wait a new beta...
Old 28th June 2005, 20:03   #480  |  Link
Kurtnoise
Kurtnoise's Avatar
it's the same problem like someone else has described in different post above...It's fixed for wav files but there is a strange thing with vorbis and mpeg files. I use the same code but it doesn't work... Give me some times to find this bug. Thanks.
