Old 19th November 2004, 01:57   #1  |  Link
Kurtnoise
Swallowed in the Sea
Kurtnoise's Avatar
BeLight 0.22 beta 9 is out
Hi guys,
Actually, I'm developping a new Graphical User Interface for BeSweet, one of the best audio tools for transcoding. Why a new one ? Coz the official from DaniDin seems to be out dated now (AAC support by example) and there are some bugs (Dialog Normalisation Reduction...). In addition, some newbies can be troubled by the interface...That's why I created BeLight.
New thread for BeLight can be found here
Features :
- AC3, WAV, OGG, MP2, MP3, AVI, VOB, LST & MUX in input.
- AAC/MP4 (3GP Reference, Faac, Nero Digital and WinAmp encoders), AC3, MP2 (tooLame or MP2Enc), MP3 (Lame), VORBIS, WAV and AIFF in ouput.
- Most of BeSweet functions (Gain, SSRC, Boost, Partial Encoding, Change Frame Rate, Soundtouch...)
- MultiLanguages Support (German, Spanish, French, English, Polish, Russian, Portuguese, Slovenian, Hungarian, Serbian, Italian, Japanese, Greek, Nederlands...more are welcome )
- Delay Detection for input files.
- Some AAC/AC3/MP2/MP3/VORBIS/WAV Presets.
- Mux File Wizard (in version 0.22)
- File List Creator (in version 0.22)
Notes :
- For the moment, BeLight 0.22 branches doesn't support AVI, VOB Files as input files. If you want to use these formats, I'd suggest you to try BeLight 0.21 instead.
- For AVI and VOB as input files you need VOBinput.dll.
- Tu use negative q values for Vorbis Transcoding, libvorbis.dll is needed.
- If CoreCodec.org is down, you can grab the last versions here.
- There are 3 packages now at CoreCodec.org (Normal, Lancer and P4). The main difference between these 3 builds comes from libvorbis. The Normal version corresponds to normal libvorbis.dll, Lancer bundle is optimized for speed without loose quality and P4 version refers to libvorbis.dll optimized for Pentium4 core. In addition, all versions use AoTuv enhancements.
How to use it :
First, grab the last BeSweet beta release in DSPGuru web Site.Second, put BeLight in the same folder as BeSweet and load it.
Or you can install directly some BeLight package available in CoreCodec.org.
How to report some bugs:
Try to describe your bugs with some precision. First, post your complete logfile (which is in your input folder). And eventually the BeLight messages errors.
On my To Do List :
- Job List Support.
- BeSplit functions.
- UpMix functions.
Links to access directly in the thread :
  1. BeLight 0.22
  2. BeLight 0.21
Feedback and/or suggestions are welcome.
Old 19th November 2004, 03:02   #2  |  Link
Sycho
This Is How It Goes
Sycho's Avatar
one thing that should be one the top of your "to do list" is a spell checker
hint: recommended
Sycho is offline   Reply With Quote
Old 19th November 2004, 04:18   #3  |  Link
SiXXGuNNZ
Your Buddy
SiXXGuNNZ's Avatar
nice++
I like what i see
10,000 Bullets
10,000 Bullets Forums
Exploring the world of Cinema from the Arthouse to the Grindhouse™
SiXXGuNNZ is offline   Reply With Quote
Old 19th November 2004, 08:20   #4  |  Link
buzzqw
HDConvertToX author
Some hint
please: tooltip !
is not possible to encode in mp2 cbr
In abr mode (mp3) bitrate is always 128
Switching from preset to alt-preset not enable bitrate choice if in alt-preset is abr/cbr
hybrid gain seems not fuctional...
Good gui, but after some test i don't know what are standard settings..., could be possible to implement some preset ?
thanks
BHH
Old 19th November 2004, 09:38   #5  |  Link
Kurtnoise
Kurtnoise's Avatar
yeahh, my english is crap. Yes, I know. I'll fix it.
Ok for the hints...I'll add them in the next releases.
Originally posted by buzzqw is not possible to encode in mp2 cbr. In abr mode (mp3) bitrate is always 128. hybrid gain seems not fuctional...
My bad...This is a bug with Job List tab. I'll correct it. For the moment, don't push the Job List tab when you want to transcode. Stay in Output Audio Format tab.
Originally posted by buzzqw Switching from preset to alt-preset not enable bitrate choice if in alt-preset is abr/cbr
Ok...I see.
And yes, I'll add some presets. It's in my todo list now.
Thanks for your support.
Old 19th November 2004, 13:52   #6  |  Link
ursamtl
Re: BeLight 0.15 : a new GUI for BeSweet
Looks promising. Un beau travail.
Originally posted by Kurtnoise13
Hi guys,
<image deleted to avoid repetition>
Features :
- AC3, WAV, OGG, MP2, MP3 in input.
- AAC/MP4, AC3, MP2, MP3, VORBIS, WAV and AIFF in ouput.
- Most of BeSweet functions (Gain, SSRC, Boost, Partial Encoding, Change Frame Rate...)
- MultiLanguages Support (only French and English actually...more are welcome )
How to use it :
Second, just put BeLight in the same folder as BeSweet.exe and load it.
On my To Do List
- Job List Support.
- Profiles for output Formats.
- AVI/VOB support for input.
- UpMix functions.
ursamtl is offline   Reply With Quote
Old 19th November 2004, 15:08   #7  |  Link
jorel
Posts: n/a
Kurtnoise13, help please.in all links i got:
"Forbidden
You don't have permission to access /~media-video/forum2/download.php on this server."
any clue please? "we need that" ... thanks!
Old 19th November 2004, 15:23   #8  |  Link
Boulder
Pig on the wing
Boulder's Avatar
@Kurtnoise13
If you already didn't add this, please consider disallowing the non-working resampling and changing frame rate (using BeSweet's internal routine) at the same time - or changing it so that SoundTouch is used, I think that works with simultaneous resampling.
Old 19th November 2004, 16:31   #9  |  Link
Kurtnoise
Kurtnoise's Avatar
@Jorel : did you use a firewall ?? coz all works fine here... Try it again maybe the server has some problems sometimes.
@Boulder : BeLight use -soundtouch routine for the Changing Frame Rate. I tested quickly resampling + changing frame rate and all seems to be ok...
Old 19th November 2004, 16:37   #10  |  Link
Boulder
Pig on the wing
Boulder's Avatar
Nice, will probably save the forum from a couple of bug reports
Old 19th November 2004, 17:29   #11  |  Link
filewalker
filewalker's Avatar
I like your GUI style.Cool
But I'M waiting hard till VOB support for input is ready. I just use it for my backups.
Cu filewalker
I 'm ripping waves!...nothing else! \m/
filewalker is offline   Reply With Quote
Old 19th November 2004, 17:33   #12  |  Link
buzzqw
HDConvertToX author
btw why not implement an "ifo parsing mode" for encoding vob audio ?
BHH
Old 19th November 2004, 18:57   #13  |  Link
Kurtnoise
Kurtnoise's Avatar
btw why not implement an "ifo parsing mode" for encoding vob audio ? BHH
It's not necessary... BeSweet has already AVI/VOB support as input files. Yes, one more thing on my todo list.
I'll post a new release tonight.
Old 19th November 2004, 20:06   #14  |  Link
filewalker
filewalker's Avatar
I have a question concerning AAC settings:
Is it possible to add the profiles (first line) of the orginal Nero encoder settings. see here what I mean
It's helpful because the profiles show an overview of all seetings:
VBR/CBR
kbps range
VBR modes
AAC profiles
Cu filewalker
Old 19th November 2004, 20:26   #15  |  Link
Brother John
(schein)heilig
Brother John's Avatar
Great work, Kurt!
BeLight definitely has a much easier to understand interface than BeSweetGUI.
And not only that: Even this first release does everything I'll ever need of BeSweet's features.
Only thing I'm missing at the moment is a show/copy command line function. I've already seen the checkbox in advanced options though, so I won't push you.
Brother John
When lost in BeSweet's options, have a look at the Commandline Reference.
DVD nach MPEG-4 klappt nicht? Verzweifelt? Auf zum Encodingwissen!
Brother John is offline   Reply With Quote
Old 20th November 2004, 01:46   #16  |  Link
Kurtnoise
Kurtnoise's Avatar
Here it is...the 0.16 is out
Changelog:
- Corrected typos.
- Fixed some internal errors.
- Added Presets for AAC. --> yeahh filewalker
- Added SuperEqualizer.
- Much More Hints.
Yes...it's expected. Just be more patient.. I'm not developper expert.
Old 20th November 2004, 02:09   #17  |  Link
MaXiMuS
MaXiMuS's Avatar
I LIKE !
iNTEL Q9300 - 4GB - 9800GT + MacMini iNTEL + MacBOOK iNTEL + MSiWind
MaXiMuS is offline   Reply With Quote
Old 20th November 2004, 04:02   #18  |  Link
neo75903
The One, as in unique :)
neo75903's Avatar
Very nice work!
Love the clean interface.
It looks less nice on a win2k pc
Mr. Anderson, welcome back. We...missed you.
-= Agent Smith, The Matrix Revolutions =-
neo75903 is offline   Reply With Quote
Old 20th November 2004, 08:02   #19  |  Link
McoreD
Appreciate your work, Kurtnoise13
McoreD is offline   Reply With Quote
Old 20th November 2004, 09:06   #20  |  Link
Sakuya
Sakuya's Avatar
I might be just dumb but how do I get the conversion process to start? There's no start button. I put BeLight.exe in the same folder as BeSweet.exe and BeSweetGUI.exe. I clicked to add to job list but nothing happened.
Edit:
Nevermind! Found it at the very bottom. It was hidden due to my 800x600 resolution.
Sakuya is offline   Reply With Quote
