Old 16th November 2004, 08:21   #61  |  Link
freelock7
High beam
freelock7's Avatar
[NuEnc]Reading Registry Keys
[NuEnc]Drawing Display
[NuEnc]Initialising Codecs
[NuEnc]Loading Matrices
[NuEnc]Creating Encoding Dialog
[NuEnc]Loaded AVS File C:\Documents and Settings\Freelock7\Mes documents\DVD.avs
[NuEnc]Encoding Starting...
[NuEnc]Displaying Encoding Window
[NuEnc]Successfully Loaded AVS File
[NuEnc]CQ Mode Set
[NuEnc]Beginning Encode
[NuEnc]Encoding Frame 0
[NuEnc]Encoding Frame 1
[NuEnc]Encoding Frame 2
[NuEnc]Encoding Frame 3
[NuEnc]Encoding Frame 4
[NuEnc]Encoding Frame 5
[NuEnc]Encode Complete
[NuEnc]Quitting...
freelock7 is offline   Reply With Quote
Old 16th November 2004, 08:31   #62  |  Link
Peter Cheat
Just a Member
wtf, apparently it only encodes the first 5 frames, then decides it has finished, and exits normally...Must be a break statement.
Thankyou freelock7.
Edit: It is crashing just before updating the encoding window.
If you want it done properly, do it yourself!
Modified Libavcodec Site
Peter Cheat is offline   Reply With Quote
Old 16th November 2004, 08:38   #63  |  Link
Peter Cheat
Just a Member
Freelock7 - update the debug exe with this one NuEnc.exe and can you try again?
Old 16th November 2004, 08:54   #64  |  Link
freelock7
High beam
freelock7's Avatar
[NuEnc]Selected AVS File C:\Documents and Settings\Freelock7\Mes documents\DVD.avs
[NuEnc]CQ Mode Set
[NuEnc]Updating Statistical Information
[NuEnc]Quitting...
Old 16th November 2004, 09:02   #65  |  Link
Peter Cheat
Just a Member
The problem is therefore somewhere here:
fprintf(stderr, "[NuEnc]Updating Statistical Information\n");
DoEvents();
int nPercent = (int)((((double)i)/((double)AVSReader.GetNumFrames()))*100.0);
bEncodeDlg->m_bEncodeProgress.SetPos(nPercent);
if ( bFlip && bEncodeDlg->IsWindowVisible() )
    fprintf(stderr, "[NuEnc]Updating Encoding Window\n");
"[NuEnc]Updating Encoding Window" is not displayed, its either crashing when trying to update the progress bar, or at the if statement. SoI'll comment out the "bEncodeDlg->IsWindowVisible()" part and try again. Thanks again freelock7.
Just updated here:
http://www.petercheat.host.sk/libav/files/NuEnc.exe
Old 16th November 2004, 09:45   #66  |  Link
freelock7
High beam
freelock7's Avatar
The link don't match (invalid url)
Old 16th November 2004, 10:10   #67  |  Link
Peter Cheat
Just a Member
I think its fixed.Try this. The encoding window can't be closed, you have to move it and press stop on the main window if you want to stop. Hopefully, it will work though.
Old 16th November 2004, 10:25   #68  |  Link
freelock7
High beam
freelock7's Avatar
17 frames encoded.
Bloks more & more (no response from control panel). No report log.
Old 16th November 2004, 10:38   #69  |  Link
Peter Cheat
Just a Member
Ok, one more try. See if this this works. I am out of ideas.
Old 16th November 2004, 11:22   #70  |  Link
freelock7
High beam
freelock7's Avatar
Freezing...
Old 16th November 2004, 11:31   #71  |  Link
Peter Cheat
Just a Member
Ok, back to the drawing board. Thanks anyway . Perhaps someone else will find that it works for them. I don't know .
Old 16th November 2004, 12:34   #72  |  Link
freelock7
High beam
freelock7's Avatar
The new GUI seems to be unable to work with the new options.
If you delete some of them, maybe you'll find out.
Old 16th November 2004, 13:01   #73  |  Link
Sectie.B
Sectie.B's Avatar
I'm sorry to have to confirm each of freelock7's findings. I hope it has nothing to do with both of us living in Belgium? Now wouldn't that be a rather special, eh bug
Is it perhaps an option/solution to remove the seperate encoding/statistics-window and just use a simple 1-window-gui as it was in 0.00d?
Sectie.B is offline   Reply With Quote
Old 16th November 2004, 13:03   #74  |  Link
dragongodz
dragongodz's Avatar
if nothing comes up between now and then i will have a look on thursday.
dragongodz is offline   Reply With Quote
Old 16th November 2004, 22:26   #75  |  Link
fabrice
Running in debug mode, with VC7 gives me a lot of failed assertion (with windows, and showWindow?!).
Could be because of different versions of VC++?
I'll change what I see, and send you the changes...
Fabrice
fabrice is offline   Reply With Quote
Old 17th November 2004, 00:36   #76  |  Link
dragongodz
dragongodz's Avatar
Peter - quick dirty fix.
in EncodeDlg.cpp change
m_bBufferStatus.Create( WS_VISIBLE | WS_CHILD | PBS_SMOOTH, rect, this, IDC_BUFOC );
to
// m_bBufferStatus.Create( WS_VISIBLE | WS_CHILD | PBS_SMOOTH, rect, this, IDC_BUFOC );
will stuff up the progress bar but it encodes and the other information is updated properlly.
EDIT - ok heres a quick temporary build done with the above mentioned change. so the people who have had problems with it working can try this out until Peter fixes it properly etc.
http://www.pcpages.com/dragongodz2/
Old 17th November 2004, 06:05   #77  |  Link
Peter Cheat
Just a Member
So its the buffer status that is the problem. Thankyou very much dragongodz for spending time to work out the problem, and to upload a solution. I'll fix this bit up, and upload a new version asap.
Old 17th November 2004, 08:57   #78  |  Link
freelock7
High beam
freelock7's Avatar
@Dragongotz
The nuenc0.01-d build works!
Good job.
Go for testing now.
Old 17th November 2004, 10:24   #79  |  Link
Peter1234
Hooray for dragongodz. His version seems to work. XP SP1 SSE2 on P4. I haven't done any testing other than to check that it works.
Peter1234 is offline   Reply With Quote
Old 17th November 2004, 11:19   #80  |  Link
dragongodz
dragongodz's Avatar
ye sorry i didnt do a proper fix but things are a bit on the busy side.
i also noticed in avsenc.cpp that there is both a showwindow() and enablewindow() together. the showwindow() should(i say should) enable it anyway so the enable is a bit redundant. just something you may want to try Peter.
Powered by vBulletin® Version 3.8.9
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
