Old 30th October 2007, 11:07   #41  |  Link
legionator2
Leecher
legionator2's Avatar
I have tested some anti-aliasing script. Here are some pics :
Source :
http://i23.servimg.com/u/f23/11/31/41/30/shot210.jpg
AAA(xres=1024, yres=576, xshrp=20, yshrp=20, us=1, ds=2, chroma=true) :
http://i23.servimg.com/u/f23/11/31/41/30/shot410.jpg
AntiAliasing(th_luma=20, th_croma=20) :
http://i23.servimg.com/u/f23/11/31/41/30/shot510.jpg
SAA():
http://i23.servimg.com/u/f23/11/31/41/30/shot310.jpg
SAA()
SAA()
http://i23.servimg.com/u/f23/11/31/41/30/shot111.jpg
It seems like the SAA() script of Soulhunter gave the best result here. It even got rid of the halos, though the video looks a bit more blurry. It's a very nice function, but all of the anti-aliasing scripts seems to be slow like hell. I wonder if there's an equivalent method, but faster than this.
legionator2 is offline   Reply With Quote
Old 30th October 2007, 16:44   #42  |  Link
foxyshadis
ангел смерти
foxyshadis's Avatar
You can get some low-budget anti-aliasing with TIsophote, or Lanczos4Resize(width*2,height*2).BilinearResize(width,height), but they don't look nearly as good as the slower methods.
There are four boxes to be used in defense of liberty: soap, ballot, jury, and ammo. Please use in that order. ~ Ed Howdershelt
Old 31st October 2007, 21:33   #43  |  Link
*.mp4 guy
*.mp4 guy's Avatar
frfun7(1.01, 256, 256) Will give some very powerful, relatively quick antialiasing, but it blurs alot.
*.mp4 guy is offline   Reply With Quote
Old 1st November 2007, 17:58   #44  |  Link
Soulhunter
Bored...
Soulhunter's Avatar
A hint to write a "FRFun7@EdgesOnly" AA function? ;]
Thx n' Bye
Visit my IRC channel
Soulhunter is offline   Reply With Quote
Old 2nd November 2007, 00:35   #45  |  Link
*.mp4 guy
*.mp4 guy's Avatar
Nah, I actually already tried that, its not neccesarily any better or faster then other aproaches, once you take care of certain dificulties (mainly all the extra blur, which can cause problems with masking), which is why I never mentioned it before; Of coarse thats not to say someone else coudn't do a better job then me at it and make it competitive. It is, however, usefull without masking, on already "ruined" sources where you need extremely strong antialiasing.
Old 2nd November 2007, 23:37   #46  |  Link
jethro
Thx n' Bye
Yes, edges like in msharpen mask with adjustable detection...
jethro is offline   Reply With Quote
Old 18th March 2008, 13:24   #47  |  Link
Socio
I tried SAA and antialiasing they are indeed hella slow and got me thinking;
If video games can use the antialiasing features on video cards, in some cases even be forced to, could there not be a way for Avisynth to do the same and deinterlacing as well for that matter.
The speed increases alone would be phenomenal I would think.
Socio is offline   Reply With Quote
Old 18th March 2008, 15:09   #48  |  Link
Dark Shikari
x264 developer
Dark Shikari's Avatar
Antialiasing on video cards relies on being able to render many samples per pixel and average them. You can't do this when you aren't rendering 3D graphics; when you're just using an ordinary input image, there's no real way to render more samples.
Old 20th March 2008, 00:45   #49  |  Link
Socio
Maybe one could have it take samples from 30 frames ahead and 30 frames back to get enough samples but that would probably require a lot more ram for that data and make it slower than the AA scripts we have now.
Old 20th March 2008, 01:26   #50  |  Link
scharfis_brain
brainless
scharfis_brain's Avatar
that's what is called temporal super resolution (TSR).
This also had been discussed here several years ago
http://forum.doom9.org/showpost.php?...3&postcount=19
http://forum.doom9.org/showthread.ph...&highlight=tsr
Don't forget the 'c'!
Don't PM me for technical support, please.
scharfis_brain is offline   Reply With Quote
Old 21st August 2009, 02:22   #51  |  Link
Chengbin
Where do I get the function "edgemask"?
EDIT: Nevermind, I needed masktool.dll, apparently it didn't work with masktool 26.
Wait, how do I use this? I wrote antialiasing(), and it had no effect.
Chengbin is offline   Reply With Quote
Old 20th November 2009, 02:55   #52  |  Link
maki
Hi can someone help with this:
This is without SAA
import("C:\Program Files\AviSynth 2.5\plugins\AAA.avs")
import("C:\Program Files\AviSynth 2.5\plugins\SAA.avs")
import("C:\Program Files\AviSynth 2.5\plugins\Antialiasing.avs")
loadplugin("C:\Program Files\AviSynth 2.5\plugins\SangNom.dll")
loadplugin("C:\Program Files\AviSynth 2.5\plugins\UnFilter.dll")
loadplugin("C:\Program Files\AviSynth 2.5\plugins\MaskTools.dll")
MPEG2Source("C:\Documents and Settings\HP_Administrator\My Documents\Vocabulary\air sample.index\air sample.d2v",cpu=0,info=3)
http://i49.tinypic.com/2zoho55.jpg
http://i48.tinypic.com/2yl8gog.jpg
This is with SAA:
SAA()
http://i48.tinypic.com/mvn6v7.jpg
http://i49.tinypic.com/v5ctwh.jpg
So here's my question I believe the one without SAA to be better, which should I chose and also, I want to keep the resolution at 1920x1080, if isn't possible at least 1280x720. I know I need to change something so when I keep the resolution at 1920x1080 or 1280x720 it would be of the same quality as the one above.
What do I need to change here:
maki is offline   Reply With Quote
Old 20th November 2009, 04:36   #53  |  Link
canuckerfan
^you're calling an anti-aliasing filter multiple times in both attempts. unless you've got some serious aliasing you won't need so many calls. post a sample of what you're encoding and we can have a better look at how to tackle this.
but for what it's worth I think the one without SAA looks betters.
as for your resolution is your source 1024 by 576? in that case I'd do something like this:
AAA(xshrp=20, yshrp=20, us=1, ds=2, chroma=true)
Spline36Resize(1920,1080)
but as always it really is up to how you wanna do this. btw you might wanna check out MCTemporalDenoisePP(). it's AA feature is also quite good.
canuckerfan is offline   Reply With Quote
Old 20th November 2009, 05:06   #54  |  Link
Keiyakusha
契約者
Keiyakusha's Avatar
maki
Looks like this is Air BD. To be honest I don't see a single reason why you want keep it 1080p. There is no details for that. This is actually upscale from SD... so you should be fine with 720p. Especially with this horrible source since it needs heavy filtering. Unprocessed sample would be fine, maybe there is some tricks and someone will be able to suggest you a better script.
Anyway you probably need to change this:
AAA(xres=1280, yres=720, xshrp=20, yshrp=20, us=1, ds=2, chroma=true)
Old 21st November 2009, 00:32   #55  |  Link
maki
Okay so here's the original mpv file this file is cut, so it's around 2 minutes long, I know that the size is big for a 2 minute video, but I believe that starting with the source is the way to go. Here you go:
http://www.megaupload.com/?d=7HGV2SL0
Here's a m2st file. It's around 86 mb. If this work as well than here:
http://www.megaupload.com/?d=BQ0LSSG1
Can someone help me here.
Old 23rd November 2009, 08:11   #56  |  Link
maki
Ok so I changed the resolution and this how it looks:
http://i49.tinypic.com/5o5k4g.jpg
Do I need to change anything---xshrp=20, yshrp=20, us=1, ds=2, chroma=true----- and ----AntiAliasing(th_luma=20, th_croma=20)----- so that it might look a little bit better, or does anyone know which filter can improve the video to a much better quality?
Can someone please help me here.
Old 24th November 2009, 04:57   #57  |  Link
martre
Hello, your samples weight to much, almost 500mb. For what i see on your last picture your dvd is grainy and need chroma cleaning. For the colours you may use something like:
coloryuv(levels="tv->pc",gain_u=25).tweak(hue=10,sat=1.2,cont=.9)
You can keep on playin with the numbers yourself.
saluts
martre is offline   Reply With Quote
Old 24th November 2009, 19:50   #58  |  Link
maki
Right now I just want to change the AntiAliasing. I want to get rid of the jitteriness outlining the characters. I want smooth black lines.
Like here:
Except I want the resolution to be at 1280x720.
I used your filter, and this is what I got:
http://i46.tinypic.com/2nklv60.jpg
I took out----.tweak(hue=10,sat=1.2,cont=.9)----. the color was too dark.
It's an improvement from this:
A filter that might improve AntiAliasing would be nice. Any ideas?
Old 22nd December 2009, 00:28   #59  |  Link
Lyris
Thanks to the script writers - I used this on a source which had bad aliasing and DV compression artefacts which is going through CCE SP2 for DVD.
Before (200% pixel resize):
After:
Loss of detail is minimal, pleased with the results. Shame the guys who shot it couldn't supply a lossless version when asked.
Lyris is offline   Reply With Quote
Old 21st December 2010, 22:12   #60  |  Link
Porsche_fan
Go easy on me this is my first attempt to share something. All the credit goes to SpikeSpiegel & Didée among others. I am just sharing some modifications I made to the original script which I have found helpful…especially for HD content.
The main difference is the ability to fine tune the supersampling factor to include factional numbers instead of being locked into whole numbers. Fractional numbers help mitigate the trade off in supersampling. The larger the supersampling the less negative effects such as blurring but also the less aliasing is correctable…it is a balancing act.
I also prefer unsharpmask as a sharpener and positioned it in the script so sharpening is supersampled to reduce unwanted side effects. LimitedSharpenFaster is commented out for those who prefer it.
Lastly, I have found the original version of SangNom is about 4x faster on my quadcore than the more current versions. Unfortunately it does have a very slightly lower quality but it is hardly perceivable. http://mf.creations.nl/avs/filters/SangNom_old2.dll
# AAAmod
# Thanks @ SpikeSpiegel, Didée, mf, Akirasuto & ScharfisBrain...
#________________________________________________________________________________________
# Usage: AAAmod(Xres, Yres, Shrp, Us, Ds, chroma, Order, AAstr, ss_x, ss_y)
# Xres/Yres = The final resolution... InputSize = OutputSize is the default
# Shrp = Unsharpmask strength... 30 is the default
# Us = Resizer for upsampling... 0 = PointResize (default) / 1 = Lanczos
# Ds = Resizer for downsampling... 0 = Bilinear (default) / 1 = Bicubic Catmull-Rom / 2 = Lanczos
# Chroma = Enable/disable chroma antialiasing... Disable = false (default) / enable = true
# Order = 0=Top Field, 1= Bottom Field, 2= Bob... default is 1
# AAstr = Anti-Aliasing strength in Sangnom... default is 48
# ss_x = Supersampling coefficient for x effective range 2.0-3.0... if using Pointresize then set to 2.0
# ss_y = Supersampling coefficient for y effective range 2.0-3.0... if using Pointresize then set to 2.0
# Example...
#Import("C:\Programme\AviSynth 2.5\plugins\AAAmod.avs")
# AAAmod(656,480,40,1,2,chroma=false,order=1,AAstr=48,ss_x=2.15,ss_y=2.25)
function AAAmod(clip clp, int "Xres", int "Yres", int "Shrp",
\ int "US", int "DS", bool "chroma", int "order", int "AAstr", float "ss_x", float "ss_y")
        clp = clp.isYV12() ? clp : clp.ConvertToYV12()
        ox = clp.width
        oy = clp.height
        Xres  = default(Xres,  ox)
        Yres  = default(Yres,  oy)
        Shrp = default(Shrp, 30)
        us  = default(us, 1)
        ds = default(ds, 2)
        chroma = default(chroma, false)
        order = Default(order, 1) # 0=Top Field, 1= Bottom Field, 2= Bob
        AAstr = Default(AAstr, 48)
        ss_x = default(ss_x, 2) #For pointresize use 2.0
        ss_y = default(ss_y, 2) #For pointresize use 2.0
        xxs=round(ox*ss_x/8)*8
        yys=round(oy*ss_y/8)*8
        us==0 ? clp.PointResize(xxs,yys) : clp.Lanczos4Resize(xxs,yys)
        TurnLeft()
        SangNom(order,AAstr)
        TurnRight()
UnsharpMask(Shrp)
#LimitedSharpenFaster(ss_x=1.0,ss_y=1.0, Smode=4, strength=200)
        ds==0 ? BilinearResize(Xres,Yres) :
\ ds==1 ? BicubicResize(Xres,Yres,0,.5) :
\ LanczosResize(Xres,Yres)
        chroma ? MergeChroma(clp.Lanczosresize(Xres,Yres)) : last
Porsche_fan is offline   Reply With Quote
