#781 | Link | |
SeparateFields() gives me half height picture and all different (step by step) video. So it is pure interlaced video. So what can you reccomend as deinterlacing filter. I have some variants Code:
interp = separatefields().selecteven().EEDI2(field=1) deinted = tdeint(edeint=interp,order=1,field=1) tfm(clip2 = deinted,order=1) Code:
2 pass TIVTC first pass tfm(d2v=d2vname, output="matches.txt") second pass tfm(d2v=d2vname, input="matches.txt") Code:
TIVTC for PAL tfm(d2v=d2vname) Some samples from MeGui Code:
#TDeint with EDI edeintted = last.AssumeTFF().SeparateFields().SelectEven().EEDI2(field=-1) TDeint(order=1,full=false,edeint=edeintted) Code:
#TDeint TDeint(order=1,full=false) Code:
#FieldDeinterlace AssumeTFF().FieldDeinterlace(full=false) Code:
#FieldDeinterlace (no blend) AssumeTFF().FieldDeinterlace(blend=false,full=false) Code:
#LeakKernelDeint LeakKernelDeint(order=1,sharp=true) Code:
#TomsMoComp TomsMoComp(1,5,1) Maybe there is other method, which will give me better/best results? Last edited by Livesms; 30th October 2006 at 11:50. |
#782 | Link |
ангел смерти
![]() Join Date: Nov 2004
How much time are you willing to spend on the project? SecureBob, MVBob, and MCBob are very slow but very good at creating crisp 60 fps video without combing. You should try those you posted, however, and see if they might work well enough for a fast deinterlace. Especially TDeint and TomsMoComp.
#783 | Link | |
Can you give working examples for quality/slowest and quality/normal speed scripts. TDeint sometimes give some artifacts like lines and scratces, while TomsMoComp adds some blur in to picture. What does it mean "creating crisp 60 fps" - i need 25P and my source is 25I(50p/2). |
#784 | Link |
ангел смерти
Oh right, PAL - 50 fps then, to which you'd use SelectEven after if you only want 25. I can't really give you good arguments, but that's because I've always been able to get very good results without any parameters.
#785 | Link | ||
I need good deinterlace ![]() Quote:
#786 | Link |
Huh?
tritical, I didn't forget about the Mode0,2 and 7 tests. I'll get to them most likely today.
Read Decomb's readmes and tutorials, the IVTC tutorial and the capture guide in order to learn about combing and how to deal with it. |
#788 | Link | |
How can I found out what shell I use Mvbob().SelectEven or mvbob.SelectOdd() |
#789 | Link |
interlace this!
use selecteven unless you've got half a line of black on the top of the screen (in that case use selectodd)
sucking the life out of your videos since 2004 |
#790 | Link | |
@All I also came across some clips where the regular field matching function in tfm wasn't able tell the difference between two matches but the MIC values made the correct choice obvious (such as 85 vs 9). So I've extended micmatching modes 1/2/3 to include a post match comparison step that looks at the mic values and will change the match decision in such blantantly obvious cases. Last edited by tritical; 1st November 2006 at 01:43. |
#791 | Link | |
Almost Silent Member
That still won't happen, but it's bound to help out in other cases.
Rethinking the "Why?" chromosome. |
#792 | Link |
[link removed], changes:
TDecimate: - switch setfps() with muldivfps() for modes 0, 1, and 5 - use FloatToFPS() from assumefps/changefps/convertfps for modes 2 and 7 TFM: + micmatching modes 1, 2, and 3 now check each match decision for cases where the correct match is obvious based off mic values but the field matching routine is unable to distinguish the correct match + added micmatching mode 4, does the post match decision check and nothing else if ((mics[m2]*3 < mics[m1] || (mics[m2]*2 < mics[m1] && mics[m1] > MI)) && abs(mics[m2]-mics[m1]) >= 30 && mics[m2] < MI) where m1 was the chosen match, m2 was the alternative, and mics[x] is the MIC value for match x. The >= 30 means the MIC value for match m2 doesn't need to be calculated unless m1 has a MIC value >= 30. Since that usually isn't the case, there shouldn't be much of a slowdown vs previous versions. Last edited by tritical; 27th November 2006 at 07:23. |
#793 | Link | |
#794 | Link |
Didn't ever say so ... your plugins eat much of my CPUs' cycles every day.
![]() Ah, the speed! With a 10fold call, pace is ~400% of the script function. (what, is that all? booo! ![]() Really great, thank you. ![]()
#795 | Link |
Huh?
tritical, sorry to have procrastinated for so long. I downloaded SysInternals's DebugView and tried a slightly different mode=2 script:
[script deleted] Which, upon loading gave me the following error message: ![]() (that would be the TDecimate line) and the following DebugView log: ![]() The stats file was created from an earlier clip but it was made according to your instructions and in that regard the script didn't change.
Read Decomb's readmes and tutorials, the IVTC tutorial and the capture guide in order to learn about combing and how to deal with it. Last edited by Chainmax; 10th November 2006 at 06:43. Reason: removed space-hogging useless script |
#796 | Link |
ангел смерти
Open the stats files and delete the parts marked crc; they're normally designed to require exactly the same input as the first run, but you can override it that way. Once you do that, you'll be able to open to debug further if necessary.
#797 | Link | |
Alright, I don't know where to put this so I'm putting it here: smartdecimate+avisynthc. These are builds I made from the sources on Kevin Atkinson's site (avisynth_c 0.15/smartdecimate 0.23)... the normal version would always crash if weave/bob were the same... at least for me.
![]() @Chainmax I'm definitely interested in the results of your tests. Last edited by tritical; 8th November 2006 at 00:25. |
#798 | Link |
Wow, that was straight out of left field... I haven't seen smartdecimate in a while. In fact, I haven't used it since I started using TIVTC regularly.
#799 | Link |
Huh?
They are coming up soon, I decided to make a new stats file as I changed bobbing to SecureBob since it looked better.
#800 | Link |
Huh?
tritical: Phew! Stats creation took over a day
![]() The tests were conducted with the following script: Code:
SetMemoryMax(256) LoadPlugin("X:\wherever\DGDecode.dll") LoadPlugin("X:\wherever\ColorMatrix.dll") LoadPlugin("X:\wherever\Corrector.dll") LoadPlugin("X:\wherever\EEDI2.dll") LoadPlugin("X:\wherever\LeakKernelDeint.dll") LoadPlugin("X:\wherever\MVTools.dll") LoadPlugin("X:\wherever\MedianBlur.dll") LoadPlugin("X:\wherever\SangNom.dll") LoadPlugin("X:\wherever\TomsMoComp.dll") Import("X:\wherever\MVBob.avs") LoadPlugin("X:\wherever\TIVTC.dll") LoadPlugin("X:\wherever\MT_MaskTools.dll") LoadPlugin("X:\wherever\DCTFilter.dll") Import("X:\wherever\DeBlock_QED_MT2.avs") LoadPlugin("X:\wherever\FFT3DFilter.dll") LoadPlugin("X:\wherever\Deen.dll") Import("X:\wherever\HQDering_MT2.avs") LoadPlugin("X:\wherever\RemoveGrain.dll") Import("X:\wherever\LimitedSharpenFaster.avs") Import("X:\wherever\Soothe_MT2.avs") LoadPlugin("X:\wherever\AddGrainC.dll") MPEG2Source("X:\wherever\familytape.d2v",info=3) Trim(0,1982)+Trim(2355,0) ColorMatrix(hints=true,interlaced=true) SecureBob() TDecimate(cycleR=2003,cycle=5000,input="stats.txt",debug=true) TDecimate(mode=2,rate=29.97,input="stats.txt",debug=true) one of these per test, of course ;) DeBlock_QED() Crop(22,6,688,552,align=true) FFT3DFilter(sigma=6,plane=3,bw=32,bh=32,bt=3,ow=16,oh=16) ColorYUV(off_y=-3,gain_y=20,cont_u=0,cont_v=51.2,opt="coring") HQDering(255) FFT3DFilter(sigma=1,bw=32,bh=32,bt=3,ow=16,oh=16,sharpen=0.3) Lanczos4Resize(656,448) dull=last sharp=dull.LimitedSharpenFaster(SMode=4,Strength=150,wide=true) Soothe(sharp,dull,25) AddGrainC(5,2) AddBorders(32,16,32,16) Levels(0,1,255,16,235) a = ImageSource("X:\wherever\Otrarr.bmp") ApplyRange(2354,2357,"Overlay",a) b = ImageSource("X:\wherever\Frm3.bmp") ApplyRange(2358,2393,"Overlay",b) c = last.Trim(2395,2395) ApplyRange(2394,2394,"Overlay",c) d = last.Trim(72151,72151) ApplyRange(72150,72150,"Overlay",d) e = last.Trim(82220,82220) ApplyRange(82219,82219,"Overlay",e) f = last.Trim(152177,152177) ApplyRange(152176,152176,"Overlay",f) g = last.Trim(164536,164536) ApplyRange(164532,164656,"Overlay",g) h = last.Trim(164660,164660) ApplyRange(164657,164659,"Overlay",h) i = last.Trim(165675,165675) ApplyRange(165676,165676,"Overlay",i) j = last.Trim(165686,165686) ApplyRange(165681,165686,"Overlay",j) k = last.Trim(165687,165687) ApplyRange(165688,165688,"Overlay",k) l = ImageSource("X:\wherever\HiPay.bmp") ApplyRange(171430,172184,"Overlay",l) Mode=2, however, was not so lucky. I received the same access violation error that points at the TDecimate line. DebugView's log was as follows: ![]() I hope this helps.
Read Decomb's readmes and tutorials, the IVTC tutorial and the capture guide in order to learn about combing and how to deal with it. Last edited by Chainmax; 10th November 2006 at 06:45. |
tdeint, tivtc |
