Old 12th October 2010, 13:56   #601  |  Link
[DB-FR] Nikko
You answer is here in the first message of this topic ^^:
Originally Posted by Wilbert View Post
ColorMatrix corrects the colors of mpeg2 streams of dvds. More correctly, those mpeg2 streams are encoded using a different set of coefficients as used by AviSynth's color conversion routines or by the XviD/DivX decoders, with the result that DivX/XviD clips or mpeg2 clips encoded by TMPGEnc/CCE using AviSynth or VirtualDub are displayed with slighty off colors (which looks like a small difference in brightness [*]).
[DB-FR] Nikko is offline   Reply With Quote
Old 21st February 2011, 17:20   #602  |  Link
henryho_hk
If I put "info=3" in mpeg2source() and "hints=true" in colormatrix(), do I need to specify "interlaced=true" in colormatrix() too?
henryho_hk is offline   Reply With Quote
Old 21st February 2011, 17:25   #603  |  Link
SilaSurfer
SilaSurfer's Avatar
If you are dealing with interlaced source I think yes.
SilaSurfer is offline   Reply With Quote
Old 22nd February 2011, 03:03   #604  |  Link
henryho_hk
Oh, I thought the interlace information is put in the hints by "info=3". Thanks for the clarification. (But.... why isn't it?)
One further question about "clamp" and "outputFR". I am encoding AVI from DVDs for viewing on PC monitor (TFT LCD), using madVR (32bit) and VMR9 renderless (64bit XP). Should I specify both "clamp=0" and "outputFR=true" ?
Old 22nd February 2011, 18:57   #605  |  Link
Wilbert
Indeed it's not. It's not, because it's not made that way Using the interlaced flag from DGDecode/mpeg2source is not reliable way to determine whether the stream is trully interlaced.
From the documentation:
hints:
DGDecode v1.20 or newer can output colorimetry hints in the video stream which ColorMatrix can read in order to automatically determine the source coefficients.
Old 22nd February 2011, 19:03   #606  |  Link
Boulder
Pig on the wing
Boulder's Avatar
But doesn't the source being encoded as interlaced force the use of interlaced=true even if the stream is actually progressive?
Old 22nd February 2011, 19:35   #607  |  Link
Wilbert
Do you mean 'force' as in forced by using hints? Then no. No interlaced information is passed by hints.
Old 22nd February 2011, 19:48   #608  |  Link
Boulder
Pig on the wing
Boulder's Avatar
I meant "force" as in "force the user to set interlaced=true in CM" since the chroma information has been encoded as interlaced anyway.
Old 30th May 2011, 21:17   #609  |  Link
leeperry
Kid for Today
Hi tritical,
Thanks for the great ColorMatrix(), I use it for upscaled SD through madVR
I was wondering, is there a way you could implement 16bit? like the hack recently added to SmoothAdjust() that I also use: http://forum.doom9.org/showpost.php?...&postcount=210
I run Avisynth 2.6 if that matters.
for considering it!
Old 1st June 2011, 10:42   #610  |  Link
szabi
Hi
I am using megui, it creates this line to aviscript, when my source is :
LoadPlugin("C:\Program Files (x86)\AviSynth 2.5\plugins\DGDecode.dll")
DGDecode_mpeg2source("C:\wedding\VTS_01_1.d2v", info=3)
LoadPlugin("C:\Program Files (x86)\AviSynth 2.5\plugins\ColorMatrix.dll")
ColorMatrix(hints=true, interlaced=true, threads=0)
My question what does "threads=0" mean?
Bye
szabi
szabi is offline   Reply With Quote
Old 1st June 2011, 12:10   #611  |  Link
leeperry
Kid for Today
Originally Posted by szabi View Post
what does threads=0 mean?
it's all explained in the manual.
Old 1st June 2011, 13:03   #612  |  Link
steptoe
steptoe's Avatar
Sets the number of threads Colormatrix will use for processing. Can be any value greater than 0 and, for YUY2, less than the frame height, for YV12, less than the frame height divided by 2. If set to 0, ColorMatrix will automatically detect the number of available processors and set threads equal to that value
So if you have a dual core processor, with threads=0 then it will use both cores to process the source, with quad core it will use all 4 cores to process the source and so on
I personally set it by hand then you know it really is using all CPU cores, so threads=4 would be the value set on my quad core
steptoe is offline   Reply With Quote
Old 1st June 2011, 16:07   #613  |  Link
szabi
Thnx, for the explaination.
It helped me.
bye
szabi
Old 18th June 2011, 01:44   #614  |  Link
mandarinka
mandarinka's Avatar
Hi tritical,
for considering it!
For encoding where absolute speed isn't critical beyond some basic level, what would suffice would be some script for the most needed conversions between rec709 and rec601.
But of course, somebody who 1) knows what to do 2) can write such a function would be needed...
EDIT:
Actualy I missed this initialy, but since version 1.9, Dither includes functions to convert between rgb and yv12, which can be coupled to perform a 16bit (stacked format) conversion between any of FCC, ITU-R BT.601, ITU-R BT.709 and SMPTE 240M.
Last edited by mandarinka; 19th June 2011 at 01:18. Reason: mention the dither 1.9 option
mandarinka is offline   Reply With Quote
Old 6th April 2016, 19:03   #615  |  Link
TalasNetrag
The download link is dead.
TalasNetrag is offline   Reply With Quote
Old 6th April 2016, 19:09   #616  |  Link
Yep all links to it seem dead.
http://www.mediafire.com/download/69...rMatrixv25.zip
EDIT: Includes source.
colormatrix
