Old 5th June 2005, 19:22   #21  |  Link
codefish
so that's not too bad I believe because halving the values just works fine for YUY2.. but one has to take care of input colorspace when using the filter, so I suggest if you plan to update the release someday, simply leave a note in the DOC (I am not a programmer so I won't easily be able to look for the "error" in the code which seems to be a forgotten multiplicator or divisor)
Good work, just to repeat once more you've helped me very much with your 2.6.1 !!!
analyzing greetz from germany
codefish
codefish is offline   Reply With Quote
Old 6th June 2005, 06:40   #22  |  Link
tritical
To be quite honest I'm not sure if it is an error. Even the source included with the dll currently on marc fd's site matches the output from the source wilbert linked to before and the output from 2.6.1 and does not match the output from the included dll itself. Also, the way YUY2 is handled in those sources seems to be correct to me. I guess I could simply change the defaults for YUY2, but I don't really see a reason too as users should be tweaking the settings for every source anyways .
tritical is offline   Reply With Quote
Old 6th June 2005, 07:35   #23  |  Link
codefish
I just checked the "original" CNR 1.1 for VDub (Gilles Mouchard), the defaults read 16, 21, 21 for the n-values - higher values start the filter to produce ghosts. Seems the defaults for cnr2 v2.4 have been chosen wrong... after seeing this (I did not check before I must admit) I also believe it's correct the way you "finalized" it. Shouldn't have compared it to the 2.4
Video processing can sometimes be rather confusing, but it's very much fun, too (I just started one year ago as a complete know-nothing...)
...and of course you're right, filters should be tweaked for every material which I usually do - cnr(2) was my only favourite which clearly showed that the defaults are just fine for anything I tested it with (but it's NEVER the only filter I use - it's for prefiltering VHS-Caps only!)
Old 1st September 2010, 16:07   #24  |  Link
royia
Drazick
What's the latest release of this plug in?
According to Trtical home page:
http://web.missouri.edu/~kes25c/
It's 2.61 - 30/06/2004.
Yet here:
http://avisynth.org/warpenterprises/
There's a CNRk version dated at 13/3/2005.
What's the difference?
royia is offline   Reply With Quote
