Thread Tools Display Modes
Old 2nd June 2004, 23:29   #1  |  Link
SiXXGuNNZ
Your Buddy
SiXXGuNNZ's Avatar
interesting, mpeg4 and xp sp2
the last three builds have not been able to play mpeg4 streams(divx/xvid), build 2135, 2138 & now 2142
is microsoft trying to tell us something?
just thought this was rather interesting, since it seems like a deliberate bug
edit: feel free to move me wherever, I didn't see a general mpeg4 posting section
10,000 Bullets
10,000 Bullets Forums
Exploring the world of Cinema from the Arthouse to the Grindhouse™
SiXXGuNNZ is offline   Reply With Quote
Old 2nd June 2004, 23:42   #2  |  Link
SeeMoreDigital
Life looks better in HDTV
SeeMoreDigital's Avatar
That's odd!
I've only tried short (120sec) clips but on the systems where I've installed SP2 RC1, they've worked OK for me - even in WMP9.
Cheers
Still confused about anamorphic images? Then look here! | Main Encoding Interests: Hardware device playback | My Gear |
Old 3rd June 2004, 00:02   #3  |  Link
SiXXGuNNZ
Your Buddy
SiXXGuNNZ's Avatar
just tried a nero digital, it plays fine in the mp4 container, if I export the video it does not play tho
also, yes, rc1 works just fine, these are pre-rc2 builds
I think it worked fine up until the 2135 build, I know it worked fine for sure wuith the public rc1 2096 build
edit: ok, it seems that nero showtime is playing them just fine, any container, xvid/divx/nero
winamp, wmp 9 and 10, mpc, vdubmod, zoomplayer pro and even gspot will not open the files, and if you thumbnail view them, explorer crashes
edit part 2: if you uninstall the divx codec/decoder, xvid plays them just fine, so it is an issue with divx networks
10,000 Bullets
Old 3rd June 2004, 00:06   #4  |  Link
SeeMoreDigital
What exactly do you mean by 'export' the video?
Cheers
Old 3rd June 2004, 00:07   #5  |  Link
SiXXGuNNZ
Your Buddy
SiXXGuNNZ's Avatar
Cheers
open the mp4 in mp4ui and export video as avi
I did a second edit up above, looks like it is the divx decoder, maybe this needs moved to the divx forum
10,000 Bullets
Old 3rd June 2004, 01:34   #6  |  Link
CruNcher
CruNcher's Avatar
i use build 2126 no problems but this sounds spooky if it realy stops working with newer builds, you mean mpeg4 in avi without a signed player does not work anymore ? oh mised your last post add then it's fine man that would be horror if even filters had to be signed now :P
current Main XviD PSNRLab version 1.1
current XviD PSNRLab update 1.1.3
MT1389xx Player Infos
XviD EDP Build CVS (CruNchers Visual System ©) V 1.4 new with predefined profiles ;)
Olivera: "We're expendable assets"
         "and we've just been expended"
"It's not a trick it's a Sony Rootkit" pwnz :devil: :angry: :rolleyes:
Old 3rd June 2004, 11:06   #7  |  Link
SeeMoreDigital
I was afraid of that. MP4UI is not the best tool for doing this as it renders the stream unstable.
Also, regardless of the streams source (in your case Nero Mpeg4) MP4UI will display the 4CC as being DivX4. And changing the 4CC to Nero's 'NDIG' 4CC code will not help either.
This probably explains why your 'exports' don't work.
Cheers
Old 3rd June 2004, 11:30   #8  |  Link
bond
if it really doesnt work anymore with higher builds, maybe m$ updated their avi splitter in a way mpeg-4 placed in it will not be supported anymore?
Ogg Theora | Ogg Vorbis
Old 3rd June 2004, 11:34   #9  |  Link
CruNcher
CruNcher's Avatar
No don't think so they couldn't justify that step but the signed filters only could be justified as another security measurement which would be absolutely bad for FREE/OSS codecs
Old 3rd June 2004, 12:04   #10  |  Link
SeeMoreDigital
Hmm, hopefully the final SP2 release will be OK (remember all those annoying problems with SP1).
By the way I started a thread about SP2 here.
Cheers
Thread Tools
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
