Go Back   Doom9's Forum > (HD) DVD, Blu-ray & (S)VCD > Advanced authoring
Old 8th June 2004, 20:54   #161  |  Link
Zeul
@fourtyfour
Sorry, forgot i had mention that. Found the error that was causing the GRPM value to be set incorrectly. All fixed.
Zeul is offline   Reply With Quote
Old 8th June 2004, 22:06   #162  |  Link
k-c-ksum
ifoedit author
i have had very limited success with the scenarist version of NuMenu4U, it would like to try some failed titles using the old version that authored using ifoedit but cant find it, all references point the the new version. Can someone please provide a link to the last pre scenarist version?
thanx
k-c-ksum
k-c-ksum is offline   Reply With Quote
Old 9th June 2004, 08:12   #163  |  Link
foxmid
Zeul:
Rejig never fires, thus - there is no file created by rejig. I can change from rejig to cce, and neither of these programs actually launch.
I can clearly see the log say that it IS launching either CCE or ReJig, but no program pops, and NuMenu4U just continues unabated.
I don't know what else to try. I've uninstalled and reinstalled, are there some files or registry keys I need to make sure are wiped to ensure a clean install?
I love the program, it used to work wonders, I'm not sure what happened in the meantime!
Let me know what other info I can provide you.
Thanks...
foxmid is offline   Reply With Quote
Old 9th June 2004, 14:49   #164  |  Link
D3s7
ScenAid
D3s7's Avatar
foxmid:
The file I believe he's talking about is the ReJig control file.... this would be created BEFORE ReJig starts telling it what assets need to be encoded. Also, do you have ReJig copied to the same directory as NuMenu? It needs to be in the NuMenu directory to start.
If neither Rejig NOR cce is starting up, then it sounds like something else is wrong... Post part of your log file here so we can maybe get a better idea of what's going on.
Also, a "Dir/s" of your demux directory might be helpful
ScenAid
May just replace the dog as man's best friend
http://www.scenaid.com
D3s7 is offline   Reply With Quote
Old 9th June 2004, 18:12   #165  |  Link
rasta21
german.doom9
rasta21's Avatar
...can u plz use version numbers...so its easier to watch out for a new numenu4u version
Cya
rasta21 @ doom9/gleitz.de board
rasta21 is offline   Reply With Quote
Old 9th June 2004, 20:27   #166  |  Link
Zeul
@rasta21
this build is unrealeased at the moment, but not for long
Old 10th June 2004, 13:21   #167  |  Link
Darklistener
Bavarian Ripping Angel
good news
I'm happy to hear that
I count the seconds till then
Darklistener is offline   Reply With Quote
Old 14th June 2004, 16:56   #168  |  Link
foxmid
Well, it doesn't work with either, and it USED to work, so I don't know. I've got rejig.exe in the NuMenu4u folder, the ecl ini file is correct, and if I launch eclcce from the numenu4u folder or rejig from the same folder, they work fine.
Here is the directory listing and log file. I can't find any control file created, either in the demux folders or in the NuMenu4u folder.
Dir /S Here
NuMenu Log file
Thanks for your help, this is quite frustrating! I just HAVE to lose some of the 1 gig worth of Finding Nemo menus, it's killing me..
Old 14th June 2004, 17:43   #169  |  Link
D3s7
ScenAid
D3s7's Avatar
well when Numenu launches CCE it creates a .bat file that launches eclcce.. I'm not 100% sure what the controlfile for rejig is called or how it's launched but you do have this file in one of the dirs
06/14/2004 08:50 AM 0 Rejig.txt
which leads me to think rejig DID start but didn't do anything....
ScenAid
Old 14th June 2004, 17:48   #170  |  Link
foxmid
Yeah, I saw that - I wonder if NuMenu is passing a blank control file to ReJig, and that's why nothing happens?
This is quite frustrating! I'm going to reinstall NuMenu4u in a different spot and see if things get any better.
Love the program, though.. Sorry if I seem negative. Just running out of storage, need to get a few of these projects finished and move on..
Old 24th June 2004, 21:36   #171  |  Link
Justn
i am also having troubles with having cce start, it appears to just skip right over it and go into scenarist. is there anywhere i could get the non scenarist version to see if that still works?
yeah?
Justn is offline   Reply With Quote
Old 24th June 2004, 22:40   #172  |  Link
Zeul
@Justn
I have found the bug that was causing this to happen. The newest build is just about ready, perhaps a day or so.
Zeul
Old 26th June 2004, 20:09   #173  |  Link
Justn
awesome, i can't wait!
yeah?
