Go Back   Doom9's Forum > (HD) DVD, Blu-ray & (S)VCD > DVD Rebuilder
Old 24th March 2004, 00:42   #121  |  Link
quantum
jdobbs fanclub member#892
0.23 audio is working on Pioneer standalone.
Now looking closer at the chapter problem. On every chapter change there is pixelation and jerkiness that goes away in a second or two. This happens if the chapter point is jumped to or if it reaches the chapter point by normal time.
This didn't appear to happen on the Toshiba standalone so this looks like another bit of weirdness that needs to be tracked down and fixed.
quantum is offline   Reply With Quote
Old 24th March 2004, 00:46   #122  |  Link
lab-one
lab-one's Avatar
@quantum
I've noticed on my Sony DVP-NS725P that I do not get the blocking and pixelation when playing through chapter changes, only when FF/RW through them. Weird. I haven't had any problems with the audio either.
lab-one is offline   Reply With Quote
Old 24th March 2004, 00:47   #123  |  Link
robw
@purplered
run regedit and search for
HKEY_LOCAL_MACHINE\SOFTWARE\Avisynth\plugindir2_5
this is your avisynth dir.
be sure your unzipped decodefix.zip is put into this dir or change the registry to reflect where these files are stored.
robw is offline   Reply With Quote
Old 24th March 2004, 00:49   #124  |  Link
jdobbs
Originally posted by acido
SOLVED also chapters SKIPPING !!!
by running every VTS_XX_0.IFO through IfoEdit -> VOB Extras -> Check CORRECT VOB NAV PACKS -> Check CORRECT ORIGINAL IFO'S -> Uncheck AUTOCOPY MENUS and then just run. Everything other you should leave as it is.
It REALLY WORKS ! now the DVD on my standalone plays flawlessly !
and also DVDSHRINK is no more reporting errors on the fixed VIDEO_TS
Hope this helps jdobbs finding the problem !
Hey thanks. This will help a lot. I'm going to run a couple of tests and see what differences I see! Have you tried it with only one of the two (CORRECT NAVPACKS or IFOs)? I have to believe it is the NAVPACK alone causing the problem.
Website: www.jdobbs.net
Old 24th March 2004, 01:40   #125  |  Link
Raymongo
It also solved the FFWD/RWD problem, in my case, as discribed is other posts.
Raymongo is offline   Reply With Quote
Old 24th March 2004, 02:22   #126  |  Link
jdobbs
I'm close to fixing this. It appears I have incorrectly calculated the first, second, and third reference frame end blocks. These are used for fast playing.
Old 24th March 2004, 02:49   #127  |  Link
hypo20
Isn't that the part "every VTS_XX_0.IFO through IfoEdit -> VOB Extras -> Check CORRECT VOB NAV PACKS -> Check CORRECT ORIGINAL IFO'S -> Uncheck AUTOCOPY MENUS and then just run. Everything other you should leave as it is." exact copy of my post on the same page???
I think....YES!!!!! I was writing about it few times, and somebody before me too.
@jdobbs
Now it seems, we have only one major problem. Stills.
My devil:
MB: MSI K8D Master F
CPU: 2x AMD Opteron 244 (1800Mhz)
SYS HDD: Maxtor Atlas 36GB SCSI 10K RPM
DATA HDD: 3.2TB RAID6 SCSI DISK SUBSYSTEM
VGA: MSI GeforceFX 9590Ultra 256MB DDRAM ViVo
MONITOR: iMAC 19" 16:9 LCD
CASE: ThermalTake Xaser III Silver
RAM: 12GB DDR400 ECC (6x Kingston KVR333X72RC25/2G)
KB & MOUSE: MS Optical Wireless Desktop
DVD-RW: NEC ND-2500A
DVD-ROM: Pioneer DVD-120
VIDEO CARD: Matrox RT.X100 Xtreme Pro
hypo20 is offline   Reply With Quote
Old 24th March 2004, 03:05   #128  |  Link
jdobbs
@jdobbs
Which shall be conquered soon! Then on to seamless branching and angles.
And YOU'RE RIGHT!!! I apologize profusely for not crediting you!
Old 24th March 2004, 03:16   #129  |  Link
quantum
After bugs, shouldn't adjustable bitrate for extras be the first enhancement?
Old 24th March 2004, 03:24   #130  |  Link
robw
Well JDobbs, you're the programmer and I bow to your wishes on DVD-RB. But just a humble second to Quantum's request on bitrates for extras. That would be more useful for the "typical" user IMHO. If you decide to address seamless branching, I'll still be a very happy camper.
Old 24th March 2004, 03:28   #131  |  Link
hypo20
@jdobbs
It was not to you. It was to ACIDO.
This is not about crediting me or someone else. But when someone just copy and paste someone else's post (or it's main part) and then publish it as his own....that's what I'm not accepting. I didn't said, that correcting VOB NAV PACKS was mine idea. It in some post on the early stage of forum (when v0.16 was released). I have only tested it and post here, that works. All I am doing is telling it to next people, which hasn't read it. But I'm not telling "I SOLVED THE PROBLEM!!!".
But this is off-topic. Let's test new version of YOUR baby.
My devil:
Old 24th March 2004, 04:04   #132  |  Link
jdobbs
Ok. I'll take the advice of to you and robw and work on that next. But first the bugs. Right now I'm fixing the ff/rw bug, I know exactly what it is -- but it's late and I'm getting punch drunk so I'm going to leave the correction until tomorrow. Next I'll clean up the stills (which I believe are also the cause of the runtime '9' error during rebuild).
Old 24th March 2004, 04:07   #133  |  Link
jdobbs
@hypo20
At any rate it pointed directly to the problem. All I had to do was run IFOEdit against my output, compare it to a first run with a file compare -- and it pointed me directly to the error. I'm just happy to be putting this one behind me.
Old 24th March 2004, 04:15   #134  |  Link
djan
- DVDRB User -
I solved this problem with only pushing "Get VTS Sectors" in IfoEdit.
- CaN -
djan is offline   Reply With Quote
Old 24th March 2004, 04:38   #135  |  Link
bigskank
any thoughts about possibly adding support (at some point down the road, as I know requests are piling) of adding support for re-encoding menus?
bigskank is offline   Reply With Quote
Old 24th March 2004, 04:41   #136  |  Link
2COOL
PGC Navigator in Training
2COOL's Avatar
@jdobbs
I also have been getting the Runtime error '9', Subscript out of range message. What gets to me is that it always occurs when it processes my VTS_01_1.VOB during rebuild and it doesn't have any stills in it. Interesting, I discovered something that might be a hint.
After I had closed DVD-RB, I played my partial VTS_01_1.VOB in PowerDVD and behold, I got this message in bright red fonts with a black background.
  • Script error: there is no function named "mpeg2source"
    (D:/D2AVS/V01000000001001.AVS, line 5)
Does anyone see what I see?
Update: I get the same exact message with I open V01000000001001.AVS in VirtualDub. This what I have in the AVS.
    # AVS File Created by DVD Rebuilder
    # VOBID:01, CELLID:01
    mpeg2source("D:\D2VAVS\V01B.D2V")
    trim(0,16336)
    ConvertToYUY2()
    ResampleAudio(44100)
I'm using DVD-RB v0.23 beta.
2COOL
Old 24th March 2004, 05:22   #137  |  Link
djan
- DVDRB User -
Same as I had before. You know how I corrected my problem ? I just installed AviSynth 2.54. Try it, maybe you can correct it too. Hope chance.
- CaN -
Old 24th March 2004, 06:02   #138  |  Link
SLA
It should work fine, if the mpeg2dec3 plugin is installed correctly. For some reasons it doesn't work properly in many cases. A workaround would be to add Loadplugin("*pathwithpluginname*") to the top of your .avs
SLA is offline   Reply With Quote
Old 24th March 2004, 06:35   #139  |  Link
2COOL
2COOL's Avatar
Update:
OK. It is confirmed that I am using AviSynth 2.54 and DVD2AVIdg. I downloaded both from Doom9 links. Anyways, I was working backwards and analyzing some files prior to Rebuild process. Inspecting the D2Vs files, I found them to be fine because I saw what needed to be seen. But, when I viewed the M2Vs, all I got was the same as my post VTS_01_1.VOB, which was the message
It seems something went wrong in the Encode process. With further investigation, I noticed that I didn't have any D2V extensions in my File Types so I added that and pointed to my "DVD2AVIdg.exe" in my AviSynth plugin directory. After starting from scratch, I viewed my first M2V file and I now have my video clip in question.
Don't know if this was the big fix by adding the D2V extension and association but will test again when I have deleted the D2V extension in File Types.
2COOL
Old 24th March 2004, 08:29   #140  |  Link
robgarib
I have encoded 2 dvd with Dvd Rebuilder.
In both cases i don't have any error during the process and the result is a video_ts folder of 4.30 gb with very good quality.
When i test the files on hard disk with power dvd everything is ok but when i burn them on a dvd+rw for testing on a dvd case (philips dvd 612) i don't hear any audio in any language.
These are my settings:
Dvd 1:
Ocean Eleven pal italian-english
dvd rebuilder 0.21
Cce 2.67.00.23 trial + eclcce
Avisinth 2.54 + dvd2avi dg
Dvd 2:
Spiderman disk 1 pal italian-english
dvd rebuilder 0.22
Avisinth 2.54 + dvd2avi dg + alternative Mpeg2Dec3
robgarib is offline   Reply With Quote
