#1 | Link |
DVD Decrypter 3.2.0.0 Released
Change Log DVD Decrypter 3.2.0.0 (29/02/2004) Added: Lock volume during ISO Write or Erase Added: Disable Media Change Notification for currently selected drive Added: 'Untested' support for Double Layer +R media burning Added: Stream information in filenames for File mode Demuxing Added: CSS code now checks all VOBs in VTS set if the key for a single file cannot be found Added: CSS code now detects the presence of CSS in supposedly unencrypted VOBs Added: Quick drive letter change on destination path - in context menu Added: Command Line switch '/SHUTDOWN' for ISO Write mode Added: Region mismatch dialog box now displays the drive region and the disc region to make the problem easier to see Added: A lot more 'status' message to show the user what the program is doing at all times Added: A workaround for NEC drives that don't have their regional code set - they don't follow the specs Added: Code to put the system tray icon back in the system tray if 'explorer.exe' crashes Added: '% complete' for more of the 'lengthy' operations (Synchronising Cache, Finalising Disc etc) Added: 'Question' event sound to the 'File Replace' dialog box Added: ISO Read mode now uses the Filesystem specified capacity for the disc capacity when reading from DVD+RW media Added: ISO Read mode now silently (almost) terminates when it reaches the end of the disc before it originally thought it would Added: Setting 1x for 'Set Read Speed' will put Pioneer DVDROM drives into 'Quiet' mode. 'Max' will put them into 'Performance' mode Added: 'Vendor Specific' inquiry information is now shown in the device 'capabilities' page accessed via the device context menu Added: Support for XBOX images that have had their ISO filesystems removed Changed: CSS code has been rewritten to cope with strange happenings and should error out a lot less now Changed: Stream Processing in File mode - Shows information for more streams (i.e. DTS) Changed: CSS code I/O Debug mode logging to make it more useful in identifying problem Changed: I/O Debug mode logging to make it more useful in identifying problem Changed: VOB CSS 'Encrypted' flag is no longer removed if the program hasn't actually decrypted the file Changed: NSIS installer has been updated to be more 'user friendly' for reinstalls etc Changed: SPTI Device detection code has been cleaned up - code for NT4 no longer effects 2000 (and newer) OS's Changed: ISO Write mode code to hopefully make it more stable Changed: Sectors are no longer skipped in basic IFO/File modes due to 'Pack Header Not Found' errors Changed: Logic behind getting the free disc space. It no longer uses the root folder but instead the one you've actually selected Changed: Source device drop down list now shows 8 devices before scrolling Fixed: A problem in the Image File 'Format' detection code where it could error out trying to load small images Fixed: Set Read Speed - previous version always set it to 'Max' regardless of the actual setting Fixed: ISO Write mode displayed 'Decrypt' as the button tooltip instead of 'Write' Fixed: File mode stream processing via CLI no longer includes unwanted streams in the VOB Fixed: 'Set Hardware Read Error Reties' should no longer cause certain machines/drives to hang Fixed: A problem comparing drive/disc regions that could lead to a 'mismatch' when one didn't really exist Fixed: Misalignment of a few controls within the Settings Fixed: Tab order of a few controls within the Settings Fixed: Issues with PCM demux in IFO/File modes Fixed: Issues with PCM information in File mode stream processing dialog Fixed: A small problem with the IFO parsing code that could lead to the wrong video resolution being displayed Fixed: A bug where the Device Buffer thread could cause a 'Divide By Zero' error Fixed: NEC (and alike) drives no longer display 2.3x and 3.9x for supported write speeds in ISO Write mode Fixed: 'Pack Header Not Found' entries in the log caused by a previous 'Read Error' Fixed: A nasty bug in ISO Write mode when converting 2352 sectors to 2336 ones Fixed: A nasty bug in ISO Write mode when converting 2336 sectors to 2352 ones Fixed: A logic error when setting the write speed for 'Erasing' a disc Fixed: Copy + Paste issue in ISO label change dialog Fixed: A problem ('Failed to set Write Parameters') when burning on 'older' CD drives Fixed: A problem with file splitting code in File mode |
#2 | Link |
Author of ImgBurn
![]() Join Date: Oct 2001
Thanks but I'm sure we dont need to duplicate the 'News' page here in the forums do we?
Surely everyone who comes here will already visit www.doom9.org too? - right?
The Official ImgBurn Website |
#3 | Link |
Re: DVD Decrypter 3.2.0.0 Released
Change Log
DVD Decrypter 3.2.0.0 (29/02/2004) Added: Command Line switch '/SHUTDOWN' for ISO Write mode thanks a ton...many users will benefit. CLI is sweet. Added: Region mismatch dialog box now displays the drive region and the disc region to make the problem easier to see hopefully less confusion for those not well version in regions I suppose. Added: '% complete' for more of the 'lengthy' operations (Synchronising Cache, Finalising Disc etc) cool...it helps as those you use DVD-R takes about 90secs for it to finalize. Added: Support for XBOX images that have had their ISO filesystems removed hmm...I'll have to check into this on the dvddecrypter forums. Never had a problem backuping up custom made xbox .isos. Changed: ISO Write mode code to hopefully make it more stable never had a problem with stability.
www.mrbass.org DVDShrink | DVD2DVD | DVDFAB | Mac guides |
#5 | Link |
Author of ImgBurn
No, it doesn't.
Someone just sent me a 10 meg example of an image they'd got from somewhere and said my program wouldnt accept it. I found out that it wouldn't accept it because a special tool had been used on it to remove the ISO file system - supposedly it makes the games load quicker... I dunno. XBOX uses a different filesystem you see - or at least I think it does. lol Anyway, I fixed it so it can burn these images too.
#6 | Link | |
as for using dvddecrypter you can rip to an xbox .iso and burn that .iso if it's already on a DVD-R. Just can't use it to read an original since it's written backwards and no dvd-rom player can read those except in an xbox.
#9 | Link |
It's explained to some extent in the thread DVD Decrypter from a HD folder.
