Old 22nd February 2004, 05:33   #1  |  Link
morsa
the dumbest
Scale2X for Avisynth (Source available)
Well, here is my first filter.It isn´t an incredible thing and is slow as hell cause I've no idea about how to optimize it or port the mmx version of it.
It works nice for me with video images, didn't test it with anime (hope mf will do it).
By now it only works in RGB (24 or 32).
It gives better results when used with msharpen first.
Usage : NoName() (sorry no params).
That's all.
Ahh, please do not link directly to the file cause it's just a geocities page.
http://www.geocities.com/morsa200020...?1077427198530
P.S: In fact it is not meant to give a 2X image but to antialias the original resolution.For example you take a 640x480 image apply it 2 times and then resize it again to 640x480 with the resizer you like.
Feedback welcome...
morsa is offline   Reply With Quote
Old 22nd February 2004, 13:35   #2  |  Link
hanfrunz
hanfrunz's Avatar
Hello morsa,
where can we find de source code? How does your filter work?
Can't you use PointResize(1280,960) instead?
hanfrunz
hanfrunz is offline   Reply With Quote
Old 22nd February 2004, 17:42   #3  |  Link
Didée
Now, that was not really the question to become "senior member", hanfrunz
Old 22nd February 2004, 17:50   #4  |  Link
hanfrunz
hanfrunz's Avatar
why not? Do you understand the difference between his filter and pointresize?
hanfrunz
Old 22nd February 2004, 18:56   #5  |  Link
Didée
Oooops ... take my apologies, hanfrunz.
I only say the filter's name and packed it on HD without trying it out immediately ...
When I read "HQ2X" and morsa's comment about resolution antialiasing, I understood it would do some calculations to interpolate at the upscaled resolution.
Now I tried it, and it seems it is indeed a resolution doubler "only". (Well, I myself could not even code that...)
Hmmm... subtracting a NoName'd from a pointresize'd clip shows big differences, but side-by-side they look just the same.
Welcome to the seniors, hanfrunz
morsa?
- Didée
Old 22nd February 2004, 19:46   #6  |  Link
morsa
the dumbest
Well, it isn't supposed to be the same as Pointresize.
May be I did something wrong.
It has the effect of of affecting the strong edges of the image giving a kind of antialiasing effect.
Did anyone tried NoName twice and then downsample again to original resolution.Does it do the same as using Pointresize all the way?.
Today I'm going to try shifting the matrix to work only with the corners instead of left, wright, top and bottom pixels.
I tested it with a Monty Python episode which has subtitles and the subtitles really became better than the original ones.
Old 22nd February 2004, 20:36   #7  |  Link
MfA
Is this the same algorithm as the Scale2X used in emulators? As was said before, it will only work well on palletized pixel art ... which would explain why it works on subtitles Ill agree with mf here, you should really use hq2x instead if you want that kind of effect ... because of the thresholded difference comparison instead of the is-equal testing it will be more robust.
MfA is offline   Reply With Quote
Old 22nd February 2004, 21:01   #8  |  Link
morsa
the dumbest
Exactly, It Is the Scale2X.I chose it because HQ2X tends to blur too much the rest of the image that is not an edge.
I saw the comparison between both and I liked Scale more.
But, because this is just testing to get feedback from you (all) to see if this is worth the effort I will continue with this thing till it gets exhausted.
Old 22nd February 2004, 22:15   #9  |  Link
mf
mf's Avatar
NoName, now that's really a cheesy name, considering SangNom...
mf is offline   Reply With Quote
Old 22nd February 2004, 22:39   #10  |  Link
morsa
the dumbest
Suggestions welcome. (if someone has an idea how is the HQ2X implementation in C++ please explain it to me cause I can't understand exactly what it does.)
Old 23rd February 2004, 00:19   #11  |  Link
MfA
You could also try this algorithm ... although I would try 75:25 averaging for the first 3 mixing options.
Little harder (only a very little though) in YV12 instead of RGB space, except for the difference which you can just compute using luminance only, because of the subsampled chrominance planes ... but that is left as an excercise to the reader.
Or dont ... I was planning on trying it myself eventually, so ...
Old 23rd February 2004, 09:02   #12  |  Link
morsa
the dumbest
Hurray, THX to MfA!!!!!!!!!!!
It's done.
After reading the link carefully I noticed that I was just halfway to it.The problem with the first version was that (I'm really newbie about programming and I don't know most of the common operations with pixels, you know?) ,although I was using a diagonal way to read the pixels ,I wasn't taking their distance from the source pixel to accurately select the correct ones.
New version, faaaaarrrrrrrr better, although it only supports RGB24 and it doesn't interpolate but copy pixels following the rules of Scale2.
If anybody wants to test it go for it, if not wait for a better version coming soon.....
Bye!
My script for a source of 480x368:
ConvertToRGB24
sharpen(0.3,0.3)
NoName()
Lanczosresize(720,576)
Old 24th February 2004, 06:25   #13  |  Link
morsa
the dumbest
RGB32 and YV12 coming soon...
Old 24th February 2004, 09:34   #14  |  Link
morsa
the dumbest
Finally new version.
Supports RGB24, RGB32, YV12.
YUY colorspace not supported yet cause I have problems implementing it.
Old 24th February 2004, 11:32   #15  |  Link
Didée
Ah - now it looks like something!
Gave it a short try on some Window$ screenshots. Yummy! No chance to get something similar with (lanczos/bicubic)resize and/or Xsharpen and/or Warpsharp.
One thing I noticed: The placement of the image in the upsized frame is different between RGB and YV12 - and both are different from normal resize's placement.
And: when feeding an RGB with odd framewidth, then noname().noname() will crash.
Good work so far, thanks!
- Didée
Old 24th February 2004, 14:54   #16  |  Link
morsa
the dumbest
Thank you Didée!
Good feedback.
I know about the displacement of the image.It is a problem I got because it is still very beta but I wanted to release it to see if it is of use or not.
Those corrections will be made when I finish YUY2 support.I'm planning to add a deinterlacer mode, an enhanced source matrix , an antialiasing mode (no resize) and may be a 3X mode.
By now I'm thinking about using LUTs (HQ2X style).Suggestions?
P.S. Why do you want to use an odd frame width?
Another question: How fast is it? (mean fps)
Old 24th February 2004, 17:38   #17  |  Link
mf
mf's Avatar
*chemicals mix inside of mf's brain*
*smokey explosion from the chemical reaction*
OO, IDEA!
OptimalResize() - discriminating image types (natural, soft computer gfx, hard computer gfx) within single frames, and applying edge-directed, directional rounding, or hq2x interpolation, or an optional mix when unsure . That'd be fun .
Old 24th February 2004, 19:42   #18  |  Link
Wilbert
Did you also plan to add the source?
Old 24th February 2004, 19:46   #19  |  Link
morsa
the dumbest
of course!!!
why are you asking that?
Old 24th February 2004, 20:32   #20  |  Link
Wilbert
I wanted to look at the source code, but didn't see it. No problem if you add it in a later stage
