Old 22nd April 2004, 05:20   #41  |  Link
scharfis_brain
brainless
scharfis_brain's Avatar
1) kewl! does this work in 1-pass ?
2) okay, I'll try to explain it:
- lets assume I have a made bobbed (50fps or 59.94 fps) Video out of my interlaced content.
- this bobbed video gets analysed by deshaker.
- deshaker is creating a (progressive) logfile.
- then I can do my motioncompensation in avisynth with a bobbed video to my wishes using genmotion.
but I want to pass by the first three step. I want to feed deshaker with the interlaced video (thus creating an interlaced logfile), and then want to use genmotion on the bobbed (double framerate, progressive) version of the video.
Don't forget the 'c'!
Don't PM me for technical support, please.
scharfis_brain is offline   Reply With Quote
Old 23rd April 2004, 04:41   #42  |  Link
Fizick
AviSynth plugger
Fizick's Avatar
1. Yes (but i do not know what is "kewl" )
2. I answer later.
Old 23rd April 2004, 10:32   #43  |  Link
scharfis_brain
brainless
kewl = cool
same pronunciation, hehe
Old 23rd April 2004, 11:07   #44  |  Link
Didée
Originally posted by scharfis_brain
kewl = cool
Not quite the same.
cool = [ku:l]
kewl = [kju:l]
Old 23rd April 2004, 11:11   #45  |  Link
scharfis_brain
brainless
Okay, next time:
k(-j)ewl
Old 23rd April 2004, 15:22   #46  |  Link
scharfis_brain
brainless
fizick, if your new version of genmotion supports onepass gmc'ing,would this be some kind of master/slave structure?
some pseudoicode:
one=avisource("one.avi")
two=avisource("two.avi")
x=one.genmotion(analyse=true)  #where x is a variable containing movement information
output=two.genmotion(analyse=false,motiondata=x)
this means, I want to use the motioninformation of video one to move video two.
this is easily possible with the current 2-pass method, but would that be possible with your next version?
Old 23rd April 2004, 19:39   #47  |  Link
SoonUDie
I hope it is. It shouldn't be hard, fox example, to have the motion information from the first clip stored in a logfile like deShaker (except the file is generated at run-time).
Stuff was here at some point.
SoonUDie is offline   Reply With Quote
Old 23rd April 2004, 23:54   #48  |  Link
Fizick
AviSynth plugger
Fizick's Avatar
Yes, master and slave (or slaves).
Old 24th April 2004, 00:27   #49  |  Link
SoonUDie
Tsk tsk! That's not politically correct anymore in Los Angeles, where I am. The correct terms are primary and secondary.
(this is a joke!)
Old 24th April 2004, 23:36   #50  |  Link
Fizick
AviSynth plugger
Fizick's Avatar
O.K., I release new plugin. It has got name DePan -
tools for estimation and compensation of global motion (pan).
The DePan plugin must replace my experimental GenMotion C-plugin
(which uses motion data from VirtualDub Deshaker plugin log file).
The DePan works in one pass, but consist of server part (function)
and one or more clients parts (functions or its instances).
The server function estimates frames motion data and gives it to client functions on inquiry.
(to SoonUDie: I not quite understand you joke, but decided to use other, safe terminology )
Current version of DePan uses a special service clip as the motion data container.
DePan plugin functions:
DePanEstimate (server) - estimates frames global motion data and write it to special service clip
DePan (client) - make full or partial global motion compensation
DePanInterleave (client) - generates long motion compensated interleaved clip
DePanStabilize (client) - makes some motion stabilization
GenMotion() function is new DePan() function.
Note. The "offset" parameter of DePan() is extended version of "delta" parameter of GenMotion().
Features and limitations of current version of DePan plugin
1. Works only in YV12 color format.
2. Uses only pan motion (no zoom, rotation), but it gives advance in speed and stability.
3. The source clip must be same length as motion data clip.
4. Directly works only with progressive clips.
For interlaced sources, you must use Avisynth function SeparateFields,
with followed optional AssumeTFF, and following Weave (after motion compensation and denoising)
Plugin estimates and calculates motion from one field to neighbour (by time) field (from same or neighbour frame).
5. Not very fast, not assembler optimized.
You may download it from my site (link is on first page of thread).
It has beta (may be alpha) status.
Please, test all its bugs (i know some) and report to here.
Old 25th April 2004, 04:25   #51  |  Link
SoonUDie
Thanks! I'll try it out as soon as possible.
Old 25th April 2004, 11:43   #52  |  Link
scharfis_brain
brainless
the download link doesn't work
Old 25th April 2004, 13:08   #53  |  Link
SoonUDie
There's a typo in the link. It currently says
http://bag.hotmail.ru/genmotion/depan01.zip
when it should be http://bag.hotmail.ru/depan/depan01.zip
Old 25th April 2004, 13:30   #54  |  Link
scharfis_brain
brainless
already tried that!
I am always getting to a blueish site
Save File
but whatever I do, I am in loop, when clicking in the download-link of this blueish site
Old 25th April 2004, 13:32   #55  |  Link
scharfis_brain
brainless
I HATE Sites being not compatible with non-IE browsers!
Old 25th April 2004, 14:12   #56  |  Link
SoonUDie
Actually, I use Firefox, and I didn't have any problems... you just have to wait until the download starts on its own (10 seconds?).
Old 25th April 2004, 18:10   #57  |  Link
Fizick
AviSynth plugger
Fizick's Avatar
link corrected
Sorry, now i correct the link. It was one of bugs.
(By the way, I use Opera browser.)
Probably, I must make a mirror (what is the recomended for free?)
Old 27th April 2004, 14:07   #58  |  Link
scharfis_brain
brainless
depan 0.1 has a bug.
depan(offset=x) doesn't work for x being in the range of 1>x>-1
even the info=true screen disappears, if offset is between 1 and -1.
this means depan(offset=0.5) won't work.
Old 27th April 2004, 22:45   #59  |  Link
Fizick
AviSynth plugger
Fizick's Avatar
Released version 0.2, April 27, 2004 - bug for non-integer OFFSET values is fixed.
Old 27th April 2004, 23:10   #60  |  Link
scharfis_brain
brainless
thanks!
I'll try that out.
I hope, I can realease some kind of 'smoothpan' standards conversion function (NSTC <-> PAL) within the next days
(will be nearly the same code like the one I coded for morsa's 30p to 24p conversion)
