13th August 2006, 17:19 | #4122 | Link |
Just found a problem with NTCS source in the new version.
I did 2 tests with the exact same NTCS source. In the old version (2.27)everything is fine: [2006-08-13 17:15:53] Found NTSC source. [2006-08-13 17:15:53] Source aspect ratio: 4:3 [2006-08-13 17:15:54] Color correction enabled. [2006-08-13 17:15:54] Analyzing source. [2006-08-13 17:24:17] Source is considered to be interlaced. In the new version (2.31) things go wrong: [2006-08-13 18:11:35] Found NTSC source. [2006-08-13 18:11:35] Source aspect ratio: 4:3 [2006-08-13 18:11:35] Source seems to be pure FILM. Output is very crappy (skipped deinterlacing I guess) and as you can see in the log it skipped the "analyzing source" step. Thanks. |
13th August 2006, 18:57 | #4124 | Link | |
I'm afraid we've to stop
Gordian Knot Family: Gordian Knot: website, download Auto Gordian Knot: Website and download, tutorial, FAQ |
13th August 2006, 20:31 | #4126 | Link |
Major Changes
Hi Len0x.
Thanks again for new version but i will be greatfull for you if you can also solve audio sync problem, which started after replacing besweet to azid/norm/lame Just put besweet and remove azid etc or make option for the user that what audio encoding tool he wants to use [BeSweet or azid/normalize/lame]. Also add one button in advance setting to call hidden options instead of Ctrl+F9 & Crtl+F11 etc Put .divx and .avi option back (in advance setting, its disabled for long time) Adding support for H-264 Total removal of agk_tmp folder can probably be controlled via hidden option now. Thanks in advance |
13th August 2006, 20:40 | #4127 | Link |
2.32b
I'm getting this error box.
http://wess.freeshell.org/doom9/autogkerror_232.jpg [8/13/2006 3:37:38 PM] AutoGK 2.32b [8/13/2006 3:37:38 PM] OS: Win2000 (5.0.2195).2 [8/13/2006 3:37:38 PM] Job started. [8/13/2006 3:37:38 PM] Input file: G:\dishrip\wj\Washington Journal. { NR } 8_6_2006 _ 7_00am.mpg [8/13/2006 3:37:38 PM] Output file: G:\dishrip\wj\Washington Journal. { NR } 8_6_2006 _ 7_00am.avi [8/13/2006 3:37:38 PM] Output codec: XviD [8/13/2006 3:37:38 PM] Audio 1: Audio Stream 0 MPEG [8/13/2006 3:37:38 PM] Subtitles: none [8/13/2006 3:37:38 PM] Format: AVI [8/13/2006 3:37:38 PM] Target quality: 35% [8/13/2006 3:37:38 PM] Custom resolution settings: fixed width of 640 pixels [8/13/2006 3:37:38 PM] Audio 1 settings: CBR MP3 with bitrate: 64Kbps [8/13/2006 3:37:38 PM] Standalone support enabled: ESS [8/13/2006 3:37:38 PM] Started encoding. [8/13/2006 3:37:38 PM] Demuxing and indexing. Clutch |
13th August 2006, 20:53 | #4128 | Link |
@mwvirk - 2.32 is the last version for this calendar year.
@clutch - you don't have correct version of avisynth installed...
13th August 2006, 21:00 | #4129 | Link | |
Clutch |
14th August 2006, 00:04 | #4131 | Link |
after installing auto gk 2.32b, all of the xvid files i have encoded before installation with either auto gk 2.27 or virtual dub will crash MPC when i try to play them.
however, the files i encode with auto gk 2.32b play fine. when i load the compression menu with virtual dub, i have 2 xvid mpeg-4 choices instead of the usual 1. the fourcc code on the duplicate is 'yv12'. this choice was not here before installation of auto gk 2.32b my previous xvid codec was the february 28 2006 bundled with auto gk 2.27. the xvid codec bundled with auto gk 2.32b is july 2006. to get my earlier files to play correctly, i had to uninstall xvid completely and then re-install my older version. the files i encoded with auto gk 2.32b using the july 2006 build of xvid play fine even after my re-installation of the feb 2006 build of xvid. i wonder why? |
14th August 2006, 16:48 | #4132 | Link |
i discovered my problem.
recently i installed the k-lite codec pack from august 13 2006, and it included some sort of divx settings manager that appears when you play ONLY divx movies, or so it seems! apparrently, it was trying to load itself when i played xvid movies after the installation of auto gk 2.32b. i disabled the settings manager by renaming it, so that it would fail to load. my xvid files all play fine now, with the july 2006 xvid codec bundled with auto gk 2.32b. however, i now have 2 xvid-mpeg 4 codec choices when i load the compression menu in virtualdub. the fourcc on 1 of the choices is 'yv12'. they appear to be the exact same codec, with the same information popup when i click 'about'. its the july 2006 build. other than that, everything is fine now. |
14th August 2006, 20:14 | #4133 | Link | ||
Hello Len0x, Most of the changes will not take much time to write a big program. >>> atleast you can put .divx option back. >>> delete tmp folder after encoding. >>> and solve audio sync problem. Quote:
looking for new beta release or say a perfect stable version. thanks again. Last edited by mwvirk; 14th August 2006 at 20:22. |
14th August 2006, 21:05 | #4134 | Link | |
Actually in reserve
This is kind of shouting (too loud for me). 1. Please see: http://forum.doom9.org/showthread.php?t=114681 2. I have not experienced a/v desynch for DVD rip without newer protections Arccos etc... in recent AGK releases. 3. For recent DVDRip I have 9 of ten perfect rips without desynch using Ripit4me (in movie mode). I suppose I made a mistake for N°10 (HP & Goblet of fire); give it a try: http://www.ripit4me.org/index.html And I used the Setarip_old trick to get the A/V back in synch: http://forum.doom9.org/showthread.ph...657#post856657 You may also refer to a neuron2 recent post regarding how to post (or not post) in this forum: http://forum.doom9.org/showthread.ph...219#post863219 If you don't like Len0x program, you are free to look elsewhere isn't it... Edit: added 1 important precision Did
Having a problem with AutoGK? Read & use the FAQ & MORE FAQ first Want to exchange on AutoGK? try doom10.org In reserve (inactive) for an undefined period of time. Last edited by BigDid; 15th August 2006 at 19:46. |
15th August 2006, 22:18 | #4137 | Link | ||
Moderator Emeritus
16th August 2006, 00:03 | #4138 | Link |
mwvirk... I have encoded many things with AGK and not seen any AV sync problems, but even if I did the last thing I would do is to post like you did.
I think you need to try some other things to see if AGK is the problem or your source is at fault.
EncodingBox DFI-LP RDX200 CF-DR AMD4200x2 @2.5GHz 2GB G.Skill HZ's x1650XT Corsair HX620 Eclipse62 LG GSA-H42N Lite0n SHM-165P6S Asus CRW-5232A Optiarc AD-5170A Sony e500's & Ducky 1087 via KVM |
17th August 2006, 16:14 | #4139 | Link |
Auto GK v2.32b
Thanks LenOx, excellent. Have also used to convert a home movie file to DivX so I could send it over the internet for relatives and friends far away. AGK worked without any problems. I had tried conversion with the "new" Dr DivX 2.0.0 and it kept crashing.
Thanks very much, Grumpy
There are three kinds of lies, white lies, damned lies and......statistics!! Mark Twain :D A man's got to know his limitations!! "Dirty" Harry Callaghan (Clint Eastwood) Grumpy Troll |
18th August 2006, 13:18 | #4140 | Link |
Thanks for the new release len0x. I know you said 2.32 would be the last release for this calendar year, but I'm gonna ask for a new feature anyways
One minor feature I have wanted for a long time is the ability to save/restore the job queue. It would be fine if this was done automatically (ie. always save on exit, and re-load on start). This is because I often queue up lots of jobs, but then might have to reboot (for whatever reason) before all jobs are finished. It's a pain to have to go through adding all jobs again. Thanks again for a great app! |
