Old 18th April 2004, 23:11   #61  |  Link
Dallemon
i said it didnt work....
Okay, does that work for you?
i hate to say this... but no
Dallemon is offline   Reply With Quote
Old 18th April 2004, 23:27   #62  |  Link
scharfis_brain
brainless
scharfis_brain's Avatar
then tell me your error-message, word by word and char by char!
are you just to lazy to write, or do you want to make me angry?
Don't forget the 'c'!
Don't PM me for technical support, please.
scharfis_brain is offline   Reply With Quote
Old 18th April 2004, 23:31   #63  |  Link
Dallemon
just doing it to piss you off... j/k
sry i missunderstood you
DEdgeMask: Needs YV12 data
(C:\AviSynth 2.5\scripts\restore24.avs, line 25)
(C:\AviSynth 2.5\test.avs, line 13)
Old 18th April 2004, 23:43   #64  |  Link
scharfis_brain
brainless
did you tried applying
work.converttoyv12().dedgemask(...)
within the restore24-code?
you have to use converttoyuy2(interlaced=true) before all deinterlacing and restore24'ing because the built in deinterlacers need it.So do not change the external things.
Old 18th April 2004, 23:46   #65  |  Link
Dallemon
no i havent tried that since i would concider myself a noob at this still (2nd project) (and the first one wasnt this troublesome )
so i wouldnt think to mess around in other ppls scripts, but im gonna try what you suggested and report back
EDIT: yay it works (i think), well it didnt complain about anything ^^
so should i just add what filters i wanna use after the "restore24(tomsbobsoft(last),bobmatcher(last))"?
and thx a lot for the help
EDIT2: would this be a valid script?
setmemorymax(340)
import("C:\AviSynth 2.5\scripts\restore24.avs")
import("C:\AviSynth 2.5\scripts\bobmatcher.avs")
loadplugin("C:\AviSynth 2.5\plugins\masktools.dll")
loadplugin("C:\AviSynth 2.5\plugins\avisynth_c.dll")
loadcplugin("C:\AviSynth 2.5\plugins\smartdecimate.dll")
loadplugin("C:\AviSynth 2.5\plugins\tomsmocomp.dll")
loadplugin("C:\AviSynth 2.5\plugins\kerneldeint.dll")
loadplugin("C:\AviSynth 2.5\plugins\mpeg2dec.dll")
loadplugin("C:\AviSynth 2.5\plugins\mpeg2dec3.dll")
mpeg2source("C:\KORN_LIVE_DISC1\VIDEO_TS\KoRn - Live.d2v",CPU=4,iPP=true)
KernelDeint(order=1,threshold=1,sharp=true)
VagueDenoiser(1.5,1,7,true,false,false)
Crop(6,4,708,570)
LanczosResize(640,352)
Undot()
EDIT3: just want to say sry for being so n00bish but i havent worked with "import" before :/ so i just wanna be sure
EDIT4: and if this script is ok, kan i then just start the encoding process? (i.e. open the avs in vdm and do the first pass, then second)
Old 19th April 2004, 00:10   #66  |  Link
scharfis_brain
brainless
do NOT place a deinterlacer after Restore24.Restore24 returns a well deinterlaced, non combed video!
at first, you shouldn't apply any filtering at all.
just let the last line be restore24(...)
then open this avs into vdub and scroll to a place with good motion, mark this part (maybe a minute or so) and encode only this part with a encoder of your choice (doesn't matter).
then open this encoded file and analyse it containing blends and stutters. if it is okay, you can set up your filtering.
Old 19th April 2004, 00:14   #67  |  Link
Dallemon
heh thx, got a point there
would have been a waste of time if it was b0rked
thx a lot for your help and for being so tolerant
EDIT: it worked no problems at all
Old 22nd April 2004, 02:23   #68  |  Link
J-Wo
Wow this is one of the most confusing posts I have ever seen! Took me forever to navigate through the various pages, discover which code worked, and also track down all those odd avs plugins I have never used before.
Okay, after a lot of fiddling around I *finally* got this script to work. I have PAL source with interlacing, but I'm not certain what the best method was to remove the combs. I tried various permutations of fielddeinterlace, greedyhma, and smoothdeinterlace. All of them did a good job of removing the combing, but what I was left with was blended fields. They were most noticeable during motion scenes as "motion blur" or "ghosting".
Anyway I was referred to this thread from another forum. After getting Restore24 to work (based on Shariff_Brain's mods) I notice that my video *does* have less interlaced frames, but the ones that aren't have MUCH larger combing than before. It's like the wrong fields were added together or something. I'm not very technical so I can't quite explain how to describe it!
Can anyone make some suggestions to me? Any modifications to the restore24 I should try? Or perhaps try a different filter altogether?
BTW my source is an AVI from a PAL DVD. However the original material I know is american, thus NTSC. Not too sure if the interlacing came from the PAL DVD itself or from the person who made the AVI into 25 fps.
J-Wo is offline   Reply With Quote
Old 22nd April 2004, 04:31   #69  |  Link
J-Wo
I loaded up my movie in virtualdub and started to examine the interlacing frame by frame. What I notice is a pattern that starts with 1 frame progressive, 1 frame interlaced which repeats a total of 5 times, or 5x(1p,1i) followed by a long stream of ~11-13 interlaced frames, giving a pattern something like this:
p i p i p i p i p i i i i i i i i i i i i i
If I add a simple SeparateFields() to my script, I notice that the fields themselves exhibit combing, and that these combs appear much larger with SeparateFields than without.
Does this make sense to anyone? Hoping someone can help me!
Old 22nd April 2004, 05:27   #70  |  Link
scharfis_brain
brainless
no chance here, getting something good out of this file, if even separatefields() shows combing.
your video has been resized. This made the interlacing go worse.
forget fixing this one. get the dvd and be happy.
Old 22nd April 2004, 06:15   #71  |  Link
J-Wo
darn, I was afraid you might say that. As I mentioned earlier, a simple fielddeinterlace(blend=true) does a perfect job of getting rid of the combing, but then what I'm left with is a lot of blended frames and ghosting. Do you think I could use unblend or your script for unblendpattern?
Old 22nd April 2004, 06:29   #72  |  Link
scharfis_brain
brainless
forget it. your avi is broken due to false image resampling.
before any unblending you have to deinterlace (without introducing new blending like blend=true does).
And I doubt, that kerneldeint / kernelbob will give a acceptable result.
Old 25th April 2004, 19:04   #73  |  Link
Lefungus
Lefungus's Avatar
Amazing filter !
I used to think blended interlaced PAL crap was impossible to recover, but i'm proven wrong
It's not perfect yet though, extremely slow and it miss sometimes, but it surely is promising !
Some old avisynth filters
Lefungus is offline   Reply With Quote
Old 24th February 2006, 16:58   #74  |  Link
Uanime5
I've already changed the main avs file to so that it reads 'aviSource' and made other relevent changes to it. How can I modify 'bobmatcher.avs' so it accepts avi files? The current bobmatch.avs I have is
# Test-Mask-Deinterlacer (for Restore24)
function Tomsbobsoft(clip c)
{   input=c.separatefields.tomsmocomp(1,-1,1)
   a = getparity(input) ? input.selectodd : input.selecteven
   b = getparity(input) ? input.selecteven : input.selectodd
   a=stackvertical(a.crop(0,0,0,0-a.height),a.crop(0,0,0,-0))
   output = getparity(input) ? interleave(b,a) : interleave(a,b)
   output.assumeframebased
# Pre-Deinterlacer for Bobmatcher
# can also be used as standalone-bobber
# Kernelbob, using kernel-interpolation for achieving
# a higher resolution at slow-, and nonmoving locations
function kernelbob(clip a, int th)
{   ord = getparity(a) ? 1 : 0
   f=a.kerneldeint(order=ord, sharp=true, twoway=true, threshold=th)
   e=a.separatefields.trim(1,0).weave.kerneldeint(order=1-ord, sharp=true, twoway=true, threshold=th)
   interleave(f,e).assumeframebased
# TMCbob, uses tomsmocomp-interpolation for getting
# diagonal lines with reduced stairstepping
function TMCbob(clip c)
{   ord = getparity(c) ? 1 : 0
   c = c.SeparateFields.TomsMoComp(1,-1,0)
   c = stackvertical(c.crop(0,0,0,1-c.height),c,c.crop(0,c.height-1,0,0))
   evn  = c.SelectEven
   odd  = c.SelectOdd
   evn = (ord == 0) ? evn : evn.crop(0,0,1,0).addborders(0,0,0,1)
   odd = (ord == 1) ? odd : odd.crop(0,0,1,0).addborders(0,0,0,1)
   interleave(evn,odd).crop(0,0,0,-2).assumeframebased()
# Hehe, the TV-Simulator:
function TVdeint(clip clip, float kell)
   clip=clip.addborders(0,4,0,4)
   input=clip.converttoyuy2().separatefields()
   blank=blankclip(selecteven(input))
   even=interleave(selecteven(input),blank).weave()
   odd =interleave(selectodd(input) ,blank).weave()
   output=interleave(even,odd)
   kell = (kell < 0 ) || (kell > 1) ? 0 : kell
   (kell == 0) ? output : output.blur(0,kell).levels(0,1,255-int(128*kell),0,255)
   crop(0,4,0,-4)
# And finally: the bobmatcher
function bobmatcher(clip fg, int "md", int "deintth", bool "showmask", bool "showmatch", bool "domatch",float "matchth", int "bobmethod")
#   add borders to prevent the border-bug of motionmask
   fg.AddBorders(8,0,8,0)
   x1=last .ConvertToYV12(interlaced=true)
#   set vars
   md      = default(md,3)
   deintth      = default(deintth,3)
#   maskedtmc   = default(maskedtmc,true)
   matchth      = default(matchth, 0.3)
   showmask   = default(showmask,false)
   showmatch   = default(showmatch,false)
   domatch      = default(domatch,true)
   bobmethod   = default(bobmethod,128)
#   create bobbing motionmask
   evn     = x1.motionmask(md,deintth)
   odd     = x1.doubleweave.selectodd.motionmask(md,deintth)
   mask    = interleave(evn,odd)
#   create bobbed clip
#   bobmethod = 0 only uses kernelbob for getting the interpolated data
#   bobmethod = 255 only uses TMCbob
#   bobmethod = 1..254 uses a weighted mix of kernelbob and TMCbob for getting
#         the interpolated data, 128 creates a 1:1-blend (default)
   bobx    = (bobmethod == 0  ) ? x1.kernelbob(5) :
      \ (bobmethod == 255) ? x1.tmcbob() :
      \ layer(x1.coverttoYUY2.kernelbob(5),x1.coverttoYUY2.tmcbob(),"add",level=bobmethod)
   bobx    = showmask ? bobx.coloryuv(gain_v=-48) : bobx
#   create doubleweaved clip
   douw   = x1.doubleweave
   douw   = showmask ? douw.coloryuv(gain_u=48) : douw
#   calculate smartbobbed streams:
#   using previous field to get the interpolation of the current field
global   out1   = maskedmix(douw,bobx.trim(1,0),mask)
#   using next field to get the interpolation of the current field
global   out2   = maskedmix(douw,bobx,mask).trim(1,0)
#   setup mask for matching
global   mask1   = mask.converttoyv12
global   mask2   = mask1.trim(1,0)
#   if masks are to similar (No Matching), blend both bobbed streams together for best output
global   outnomatch = overlay(out2,out1,opacity=0.5,mode="blend")
#   create debug messages
global   outnomatch = showmatch ?
                    \outnomatch.subtitle("Using          Both          Fields - No Matching") : outnomatch
global  out1 = showmatch ? out1.subtitle("Using Previous            Field")     : out1
global  out2 = showmatch ? out2.subtitle("Using                   Next Field")  : out2
#   do the matching
global   outmatch = domatch ? ConditionalFilter(out1, out2, "averageluma(mask1)",
         \ "<", "averageluma(mask2)") : outnomatch
#   disable matching, if lumadifference between the prev-mask and the next-mask is smaller than p*100 percent
global   p     = matchth
   o6 = ScriptClip(blankclip(out1), "outx")
   o8 = FrameEvaluate(o6, "global outx = ((AL1*(1+p) > AL2) && (AL2 > AL1*(1-p))) ? outnomatch : outmatch")
   o9 = Frameevaluate(o8,"global AL1 = averageluma(mask1)")
   out= Frameevaluate(o9,"global AL2 = averageluma(mask2)")
#   do some final things to get the output in sync with other bobbers
   out = bobx.trim(0,-3) + out.assumeframebased().trim(2,0)
   out.Crop(8,0,-8,0)
However I have a problem with the two lines ' interleave(evn,odd).crop(0,0,0,-2).assumeframebased()' and
' \ layer(x1.coverttoYUY2.kernelbob(5),x1.coverttoYUY2.tmcbob(),"add",level=bobmethod)'.
The error message is:
Interleave: the videos must be of the same size
How can I solve this problem?
Uanime5 is offline   Reply With Quote
Old 24th February 2006, 17:05   #75  |  Link
scharfis_brain
brainless
Do mot mess with that old stuff. it has no use anymore and has been replaced by other - much better - algorithms
Old 25th February 2006, 21:36   #76  |  Link
Uanime5
Where can I find the a better algorithm?
Old 3rd April 2006, 16:26   #77  |  Link
stg
My thoughts exactly. I am a n00b what comes to video encoding, I have those problematic DVD's with "stuttering", and looking for an easy way to fix them -> convert them to XviD.
I tried that restore24 script without success, after first fighting with those incompatible versions, put everything together, all I got was errors after errors.
I would appreciate if someone could point me a guide which not only has links to compatible plugin etc. versions, but also explains the procedure step by step so even I can understand it
stg is offline   Reply With Quote
Powered by vBulletin® Version 3.8.9
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
