#1 | Link |
C64
New Filter: AudioGraph
Richard Ling sent me this filter (2.0x), which will display the audio waveform on top of the video.
Give it a try. http://www.avisynth.org/users/warpen...l_20030808.zip (very well documented source included!) |
#2 | Link |
Retired AviSynth Dev ;)
![]() Join Date: Nov 2001
Nice filter - good for syncing sound!
I had a little time, so I made a AudGraph for AviSynth 2.5. My additional notes: - No YV12 support. - Should support multiple channels. - YUY2 mode made a bit more eyepleasing, IMO. - - It makes the graph a bit more blocky. - - YUY2 mode is converted to greyscale. Not that well tested - provided without any kind of warranty. Source is of course included.
Regards, sh0dan // VoxPod Last edited by sh0dan; 27th August 2007 at 13:05. |
#4 | Link |
AviSynth Enthusiast
I too would like to be able to see the channels separated.
In the meantime, though: Code:
# AudioGraphWrapper # # Wrapper function to AudioGraph. Displays each channel separately # below the video. Each channel is displayed below the preceding # channel. # # PARAMETERS: # frameRadius # channelHeight - the height to add to the bottom of the clip for each # channel; # (default: 100) # function AudioGraphWrapper(clip c, int frameRadius, int "channelHeight", \ int "curChannel") { assert(c.AudioChannels() > 0, "AudioGraphWrapper: clip has no audio") channelHeight = default(channelHeight, 100) curChannel = default(curChannel, 1) bottom = AudioDub(c.BlankClip(height=channelHeight), c.GetChannel(curChannel)) bottom = bottom.AudioGraph(frameRadius) c = StackVertical(c, bottom) return (curChannel == c.AudioChannels()) \ ? c \ : c.AudioGraphWrapper(frameRadius, channelHeight, \ curChannel=(curChannel + 1)) } Last edited by stickboy; 17th August 2003 at 01:38. |
#5 | Link | |
AviSynth Enthusiast
When I try to use AudioGraph in conjunction with Tone, I get an access violation.
AudioDub(BlankClip(pixel_type="yuy2"), Tone()) AudioGraph(1) Quote:
#8 | Link |
Redownload the file - I fixed the filter.
Or use ConvertAudioTo16bit() before Audiograph. Bug was a simple underscore (_) too much.
Regards, sh0dan // VoxPod Last edited by sh0dan; 18th March 2004 at 11:30. |
#12 | Link |
Just wanted to say that some japanese guy added YV12 support. It's based on the original version, thus not on Sh0dan's modifications: Viewaudio. Yes, it's from 2003
![]() LoadPlugin("ViewAudio.dll") ViewAudio(clip, int frames, int top, int height, bool fill, int channel) frames : ‘OŒ‚•\ŽƒtƒŒ[ƒ€”‚Žw’ (default : 2) top : •`‰ŠJŽn y •W (-1 ‚‚‚ clip ‚‰‚•\Ž, default : -1) height : •`‰—ˆ‚̍‚‚ (default : 80) fill : •`‰—ˆ‚“h‚‚‚‚‚? (default : true) channel : •`‰‚‚‰ƒ`ƒƒƒ“ƒlƒ‹ (-1 ‚‚‚‘Sƒ`ƒƒƒ“ƒlƒ‹•\Ž, default : -1) channel=-1 all channels are drawn, i think ![]() |
#13 | Link | |
Resize Abuser
Posting in here, in order to follow advice from IanB. Deleted my original post from this thread http://forum.doom9.org/showthread.php?t=123195
Bug Found: This code fails after 30 seconds of playback Code:
colorbars() BilinearResize(720,480) AudioGraph(10) Quote:
Open script MPC VirtualDub doesn't fail, or maybe i didn't wait long enough; over 5 min worked. AviSynth Version: 2.58 build sept 19 2007 MPC Version: 6.4.9.1 This code works in MPC Code:
colorbars() AudioGraph(10) Computer Specs Below
Mine: KenBurnsEffect/ZoomBox CutFrames Helped: DissolveAGG ColorBalance LQ Animation Fixer |
#14 | Link |
Resize Abuser
Feature Request:
Display Audio Spectrogram. http://en.wikipedia.org/wiki/Spectrogram My current way of doing this, which is not perfect at all.
Example Code Code:
Global W = 640 Global H = 480 Global F = 29.97 Global D = 0 Global R = 48000 Global PicLen = Round(F*5) Global Resizer = "BlackmanResize" Global BlankPic = BlankClip(1, W, H, "RGB32", F, stereo=true, audio_rate=R).Loop() NewTone() Function NewTone() { sound = WavSource("Before-After.wav").SSRC(R) #305 Frames pic = ImmaRead("spectrogram3300.jpg").AssumeFPS(F).ConvertToRGB32() a = pic.ZoomBox(-1, 0, 0, 0, W, H, IgnoreAR=1, ResizeMethod=Resizer).Subtitle("Before After",align=2, size=48).Loop(PicLen) a = a.AudioDub(BlankPic.Trim(0, a.Framecount()-1).KillVideo()) b = pic.Loop(Round(PicLen/3)).KenBurnsEffect(-1, 0, 0, 0, -567, 200, 757, -95, W, H, 4, useZoomBox=2, ResizeMethod=Resizer, endPZframe=Round(PicLen/3)-Round(PicLen/4)) b = b.AudioDub(BlankPic.Trim(0, b.Framecount()-1).KillVideo()) c = pic.Loop(305).KenBurnsEffect(-567, 200, 757, -95, 2461, 200, 3927, -95, W, H, 4, useZoomBox=2, ResizeMethod=Resizer) c = c.AudioDub(sound) d = pic.Loop(Round(PicLen/3)).KenBurnsEffect(2461, 200, 3927, -95, -1, 0, 0, 0, W, H, 4, useZoomBox=2, ResizeMethod=Resizer, startPZframe=Round(PicLen/4)) d = d.AudioDub(BlankPic.Trim(0, d.Framecount()-1).KillVideo()) e = pic.ZoomBox(-1, 0, 0, 0, W, H, IgnoreAR=1, ResizeMethod=Resizer).Subtitle("Before After",align=2, size=48).Loop(PicLen*2) e = e.AudioDub(BlankPic.Trim(0, e.Framecount()-1).KillVideo()) a+b+c+d+e } ![]() Also, does anyone have a better way to add the audio, other then blankclips with audiodub?
Mine: KenBurnsEffect/ZoomBox CutFrames Helped: DissolveAGG ColorBalance LQ Animation Fixer Last edited by mikeytown2; 16th May 2008 at 03:43. Reason: Use ZoomBox for static parts |
#15 | Link | |
And CacheAudio in the same dll might be useful. Code:
ViewAudio.dll v0.3.01 Copyright (C) 2002, 2003 minamina http://nullinfo.s21.xrea.com/ ================================================== ============================== Avisynth Plugin - View Audio (YUY2 and YV12 Only) - Description Speech display filter for Avisynth Modes for YUY2 and YV12 mode Avisynth 2.5 only Richard Ling's work AudioGraph add voice capabilities to the reference frame around the display capabilities Thanks to Mr. Richard Ling - How LoadPlugin ( "ViewAudio.dll") ViewAudio (clip, frames, top, height, fill, channel) frames: before and after the specified number of frames displayed (default: 2) top: start drawing y coordinate (-1, then at the bottom of the clip, default: -1) height: The height of the drawing area (default: 80) fill: you fill the drawing area? (default: true) channel: Channel voice to draw (-1 Tokino Tamotsu View Channel, default: -1) - Examples ViewAudio () ViewAudio (1, 0) ViewAudio (height = 200) ================================================== ============================== Avisynth Plugin - Cache Audio - Description Audio cache filter for Avisynth Avisynth 2.5 only AudioSource random access are weak when used as an aid to edit - How LoadPlugin ( "ViewAudio.dll") CacheAudio (clip, MaxFrame, BlockFrame) Specify the maximum number of frames MaxFrame cache (default: 1000) -1: For all frames (need lots of memory. Time-consuming at first view) BlockFrame specify the number of frames read at once (default: 100) -1: MaxFrame use the same value (requires a lot of memory. Time-consuming at first view) - Examples CacheAudio () CacheAudio (10000, 300) CacheAudio (MaxFrame = 20000) ================================================== ============================== - History 2003/11/03 v0.3.01 CacheAudio added 2003/10/06 v0.2.02 is wrong, correct the problem check the maximum number of frames displayed 2003/09/22 v0.2.01 also change the voice frame can be displayed around 2003/03/16 v0.1.01 Avisynth 2.5 support YV12-mode Born 2002/12/15 v0.0.01 |
#16 | Link | |
Unavailable
Well, I've just discovered that the waveform generated by AudioGraph() can be made "more visible" (or "more annoying", depending on the point-of-view) by using PointResize(). Example script:
http://cid-5acf098e0ebae8d5.skydrive...nnel-Theme.avi Last edited by Midzuki; 27th February 2010 at 08:01. Reason: updated script, added URL to example video |
#17 | Link |
I apologize for bumping an old thread ....
![]() But, an update to this plugin was made by Ihor Bobalo some time ago but only source code provided. Includes new parameters "_graph_scale", "_middle_colour", and "_side_colour". Can anyone be kind enough to compile the updated version, x86/x64 if possible? Source code is here: https://sourceforge.net/p/audiograph...AD/tree/trunk/ |
#18 | Link | |
Broadcast Encoder
When I have time, I might fork the source and bring everything to GitHub and then play a bit with it 'cause so far it supports pretty much nothing... I didn't try it. Try it.
Broadcast Encoder Avisynth memes Videotek - Audacity XP LUT Collection - FFAStrans SafeColorLimiter - AAA Last edited by FranceBB; 20th June 2020 at 17:03. |
#19 | Link |
Reel.Deel,
What does AudioGraph() have that Wonkey_Donkey WaveForm() dont have ? [apart from maybe YUY2, I think].
#20 | Link |
I'll do it unless wonkey's WaveForm() supersedes and replaces that plugin.
Groucho's Avisynth Stuff |
