Old 5th August 2003, 08:27   #1  |  Link
pk24
anyway of removing licenses from a asf file ?
not sure if this is in the correct topic but here goes
got a few asf files on my h-drive , but when i play these it says aquiring license , license aquired etc , if i try play on a friends comp it asks for a username / pass ( to the site i got em from ) so im presuming if i cancel my membership i cant watch these files anymore
is there anyway to remove these licenses , by either cutting the files or converting em ?
if anyone wants a sample of one of these files to work with PM me
cheers for any help
pk24 is offline   Reply With Quote
Old 5th August 2003, 13:24   #2  |  Link
Sirber
retired developer
Sirber's Avatar
You could try to render them using AVISynth and open it in VDub...
Detritus Software
Sirber is offline   Reply With Quote
Old 8th August 2003, 07:20   #3  |  Link
pk24
k think best way to do this is to play in windows media player and capture whats playing with a program .. anyone any ideas on a program that can caputer what media player is playin
Old 9th August 2003, 11:23   #4  |  Link
communist
Camtasia can do it.
www.techsmith.com
communist is offline   Reply With Quote
Old 17th August 2003, 20:08   #5  |  Link
pk24
get real choppy playback when using camtasia or similar prog
Old 19th August 2003, 18:09   #6  |  Link
mf
mf's Avatar
Try graphedit.
mf is offline   Reply With Quote
Old 8th October 2003, 08:42   #7  |  Link
pk24
still tryin to suss this in anyone has any ideas , id be gratefull
Old 8th October 2003, 08:56   #8  |  Link
Atamido
Seņor Member
Atamido's Avatar
Did you try either Sirber's or mf's suggestions? If so, what were the results?
Atamido is offline   Reply With Quote
Old 20th October 2003, 13:27   #9  |  Link
pk24
ok im still stuck on this problem , i did get graphedit and avisynth , but to be honest im a bit lost on how to use these progs
if anyone can help me with a quick guide that would be great
Old 20th October 2003, 14:02   #10  |  Link
pk24
ok i got graphedit , clicked render mediafile , opened my asf file
and got this error msg
could not construct graph from this file
-have you installed all necessary filters
-note render option cant render grf files
error code (0xc00d00c8)
trying avisynth i get same error code
Old 20th October 2003, 16:01   #11  |  Link
Atamido
Seņor Member
Atamido's Avatar
You could try playing the file in Media Player Classic and see if you can use GraphEdit to 'Connect to Remote Graph'. But, I suspect that since the DRM would be enabled on this file, you would not be able to connect it.
Old 20th October 2003, 16:52   #12  |  Link
pk24
u suspect correctly , the file will only play in windows media 9
the only way i can see of keepin these films is outpit to my standalone dvd recorder and copy them this way , seems a shame theres not a better way to do this
Old 21st October 2003, 01:00   #13  |  Link
Ramirez
Ramirez's Avatar
Try AsfTools.
Ramirez is offline   Reply With Quote
Old 27th October 2003, 13:14   #14  |  Link
battyice1847
asf problems
Have you tried Virtualdub v1.3C? If you have the correct filters installed, you should be able to open the file and re-encode it with the codec of your choice. good luck
battyice1847 is offline   Reply With Quote
