Old 15th August 2015, 18:44   #61  |  Link
karl_lillevold
karl_lillevold's Avatar
2015/08/15: New version "HelixRC" by MLJ
Download: HelixRC3
Thanks to MLJ for providing this update!
Changelog
RC3 1.2/1.3 by MLJ (2015/07/23):
-Modified I420 Codec for IYUV Colorspace (same as I420) and added the "iyuvvfw.dll" Codec for both Versions.
-The IYUV Codec stays now in 12 Bit and does not upscale to YUY2 anymore to other 12 Bit Codecs.
-The IYUV Codec now reports itself as "Helix IYUV 420 Codec" instead of "Helix IYUV YUV Codec".
-Fixed decoding Intel I420/IYUV Videos (32/64 Bit) with the Helix Codecs and works both ways now for encoding and decoding.
-Fixed decoding Drastic YCbCr I420/IYUV/YV12 Videos (32 Bit) with the Helix Codecs and works both ways now for encoding and decoding.
-Fixed decoding Arksoft IYUV and ATI YV12 Videos (32/64 Bit) with the Helix Codecs for encoding and decoding.
-Fixed Problems with Empia/Afa/SynTek and other Capture Drivers.
-Fixed Problems with Osprey/ATI/Matrox/Intel/Aurora/DVS and other popular Videoboards.
-Solved minor Problems with HonesTech HDV Encoder, MainConcept, Craaft Cinema, Cinegy, Microsoft and Pegasus encoders.
-Solved Problems with the FourCC Codec install Order in the Registry.
-Solved Problems with DirectX, Direct Draw, Active Movie, Direct2D, Direct3D and OpenGL FourCC Mapping from I420 to IYUV. (Conforms now to the Microsoft White Paper for YUV Formats in Windows)
-The new INF-File restores the native 32 Bit Windows Codecs if the Helix Codecs are uninstalled and removed from the System.
-Other 64 Bit Codecs for I420/IYUV/YV12 are no longer replaced by the Helix Codecs and can co-exist now with the Helix Codecs.
Download: HelixRC3
This information is provided "AS IS" with no warranties, grants no rights, and reflects my personal opinion.
karl_lillevold is offline   Reply With Quote
Old 2nd February 2016, 05:03   #62  |  Link
VempX
Thanks for this.
It's very helpful for me.
VempX is offline   Reply With Quote
Old 2nd March 2016, 18:24   #63  |  Link
karl_lillevold
Update 2016/02/08
MLJ has been so kind as to provide another update to the Helix YUV codecs. Thanks!
Download: HelixRC3
The Changelog is as follows:
Changelog RC3: (Update Version with IYUV Codec)
1.2 / 1.3 (08/02/2016)
The I420 Codec upsamples to YUY2 if the IYUV codec is selected and
is meant to work this Way.
The IYUV Codec now reports itself as "Helix IYUV YUV Codec" again
instead of "Helix IYUV 420 Codec".
Fixed Problems with Osprey/ATI/Matrox/Intel/Aurora/DVS/Aja and
Fixed Problems with the Phillips MoviePlus and PixelPlus Drivers.
Fixed Problems with LogiTech and other Webcam Drivers.
Craaft Cinema, Cinegy, Cyberlink, Microsoft and Pegasus encoders.
Direct3D and OpenGL FourCC Mapping from I420 to IYUV and conforms now
to the Microsoft White Paper for YUV Formats in Windows.
The Helix Codecs can now co-exist with the Drastic Codecs if the User
installed the Drastic YCbCr Codecs and the Helix Codecs afterwards.
Note:
If you install the Helix Codecs first and afterwards the Drastic Codecs
then the Helix Codecs are DISABLED ! Remember, first the Drastic Codecs
and THEN the Helix Codecs.
Other Fixes:
The Problem with the original EXE-Version was, if the User removed
the Helix Codecs from the System the original Codec for I420 was
not restored and has been fixed in this Release.
Old 14th December 2016, 22:22   #64  |  Link
karl_lillevold
Hello again, MLJ has provided another update to the Helix YUV codecs (Dec 2016). Thanks!
I have updated the 1st post in this thread with the archive's ReadThis.txt (with some edits to make it fit within the forum's 16,000 character post size limitation). The download link is the same as before.
Old 17th December 2016, 15:50   #65  |  Link
CruNcher
CruNcher's Avatar
Hey karl
It is about Time
