Old 29th July 2003, 13:29   #21  |  Link
AmiRage
Of course ... without ripping/demuxing no encoding.
You waited 6 days for an answer without simply trying ...
AmiRage is offline   Reply With Quote
Old 29th July 2003, 17:22   #22  |  Link
Selur
Selur's Avatar
Robot4Rip does the ripping&co, so it really might help to do the ripping before the encoding,..
Old 30th July 2003, 00:57   #23  |  Link
loni_blues
I was wondering if we shouldn´t use compressibility instead of bitrate (900 kBit/s) as a reference for choosing XviD´s settings. I believe compressibility relates to quality better than bitrate. Shouldn´t we use a certain compressibility value such as I don´t know, 60%?
Please enlighten me on this matter,
Regards,
Loni Blues
loni_blues is offline   Reply With Quote
Old 30th July 2003, 07:25   #24  |  Link
Selur
Selur's Avatar
And then, what about the people who need a specific maximal bitrate (e.g. for streaming) or a specifig filesize or like me prefer to do high quality, high bitrate encodes with a custom matrix and so don't really care about compressibility ?
I think bitrate is the way to stay with, I personally don't see that we would gain something though this.
Cu Selur
Old 30th July 2003, 17:02   #25  |  Link
DDie
DDie's Avatar
I still think that indicating the bits per pixel value is more helpful if there isn't a standard resolution recommended.
DDie is offline   Reply With Quote
Old 30th July 2003, 20:36   #26  |  Link
loni_blues
Yes, but doesn´t compressibility represent quality better? Doesn´t the quality you get depend more on the way a certain movie compresses than on the absolute number of bits/(pixel*frame)? What´s the use of a compressibility test, then?
Regards,
Loni Blues
Old 31st July 2003, 08:31   #27  |  Link
toraneko
toraneko's Avatar
@loni_blues
I agree with you
by now, what I do is :
1°) do a regular 1st pass
2°) in GK, adjust the desired file-size (afterwards) so that the compressibility test give me the percentage wanted (for instance 60 %)
3°) do a regular 2nd pass
I can bear it by now...
toraneko is offline   Reply With Quote
Old 26th August 2003, 05:37   #28  |  Link
CHAOSMAN33
any updates on the guide snowbeach? thanks
chaos
CHAOSMAN33 is offline   Reply With Quote
Old 26th August 2003, 13:01   #29  |  Link
snowbeach
Regional Support
snowbeach's Avatar
@CHAOSMAN33
After a long abstinence from this forum, because of having simply no time, I am "back" again... Though I still have not enough time!
But to answer your question: I think I am probably a bit out dated following the discussions at the forum, but I believe that no updates on the guide are needed until a new binary will come out.
Or is there somebody who disagrees?
snowbeach is offline   Reply With Quote
Old 27th August 2003, 10:18   #30  |  Link
Th3-S4int
I think the maximum of b-frame threshold changed from 90 to 60 (iam not 100% sure, but i think i read it some where, but i will test it soon wheater the comp. change)
Th3-S4int is offline   Reply With Quote
Old 7th September 2003, 23:43   #31  |  Link
mmebane
Originally posted by snowbeach
@CHAOSMAN33
I know Doom9 has a Robot4Rip guide, but if you add one into your guide, you would have a complete guide to DVD transcoding using the GordianKnot Rip Pack w/ XviD.
Also, you should add in exactly _which_ subtitle files are needed. After running Robot4Rip, the following subtitle-related files are output:
THE_GOONIES.idx
THE_GOONIES.rar
THE_GOONIES.sub.cc.raw
THE_GOONIES.sub.cc.srt
THE_GOONIES.sub.cc.unicode.srt
(at least, for The Goonies.)
You simply say "add your 2 subtitle files". Which 2?
Anyway, excellent guide, it really was the thing that made me able to do a good transcode!
mmebane is offline   Reply With Quote
Old 8th September 2003, 08:46   #32  |  Link
Selur
Selur's Avatar
@snowbeach: Will there still be a rip guide included in the next version of the guide ? Just asking because your files are hosted in germany afaik,..
(new copyright law=> could cause trouble)
Cu Selur
Old 9th September 2003, 11:44   #33  |  Link
t3ch
h4x0r of gibsons
t3ch's Avatar
Was wondering when a new version would come out, good job and thanks a bunch
Knowledge is power, power corrupts. Study hard, be evil.
t3ch is offline   Reply With Quote
Old 11th September 2003, 12:31   #34  |  Link
snowbeach
Regional Support
snowbeach's Avatar
@The Khan Artist
I will see if I am going to add the R4R section...
@Selur
Thanks for the info. I know. I am checking some webspace outside of Germany... But if somebody has some webspace to offer, he/she is welcome...
Old 11th September 2003, 19:38   #35  |  Link
t3ch
h4x0r of gibsons
t3ch's Avatar
I could probably host it for you (if you were being serious). About how much bandwidth does your site usually take up?
Old 13th September 2003, 15:26   #36  |  Link
snowbeach
Regional Support
snowbeach's Avatar
Many thanks to t3ch for hosting the guide at his webspace/domain (outside of Germany)!!!
See my sig...
Old 14th September 2003, 15:53   #37  |  Link
yeeyy
This is a good suggestion, thus make the guide more complete.
yeeyy is offline   Reply With Quote
Old 22nd September 2003, 10:52   #38  |  Link
ShaoMonk
Hello..
i didnt want to open another Thread.. just want to reply here..
which options do i need to change to get optimal desired size.
When i put the size i want in second pass box.. i dont get always the size i want.. for example.. i want to have the size of 1100 mb.. i put 1126400 into desired size box.. but i get always 900 mb.. how many times i rip.. is there an option.. which allows to calculate exactly for 2 cd rip.
My Options are almost same as this guide here.. except MPEG instead H.263.
hope to have an explanation for the exact option which has to do with the size.calculation.
greetz
ShaoMonk is offline   Reply With Quote
Old 22nd September 2003, 13:18   #39  |  Link
superdump
Posts: n/a
If the encode is quantiser 2 all the way through (use ffdshow's OSD) and you get a 900mb output then that is the best quality you will get with those settings. If you want to increase the filesize try using a high quality mpeg custom matrix such as HVS-Best. Also try removing any smoothing filters such as deen, fluxsmooth or convolution3d unless the source actually needs them. Finally increase the resolution (but not beyond the cropped resolution) or just use the cropped resolution without resizing it. This should beef up the filesize (and quality) a bit. Also, instead of doing a two-pass, save yourself some time and just do a constant quant 2 single pass for this particular encode to make sure it's producing the maximum filesize possible. If it's still undersized after this then... increase your audio bitrate.
