Old 25th May 2003, 15:46   #21  |  Link
The Shemeta
@Sirber
Do you need help testing? i would like to try it too , if this is possible.
The Shemeta is offline   Reply With Quote
Old 25th May 2003, 16:05   #22  |  Link
zedude
of course this is possible
visit rmfactory homepage to get the latest version , bug reports will be helpfull ,thank you
pardon my frenglish...
zedude is offline   Reply With Quote
Old 25th May 2003, 20:53   #23  |  Link
The Shemeta
@Zedude
what i meant was the new beta, not the old one! now i am messing around with the old one & i have problems with the VobSub subtitles. the program doesn't encode the movie. that's for now. after more testing i will write you back guys!
later
Old 26th May 2003, 01:46   #24  |  Link
Sirber
retired developer
Sirber's Avatar
@zedude
Will you update your website?
Detritus Software
Sirber is offline   Reply With Quote
Old 26th May 2003, 08:15   #25  |  Link
zedude
@ sirber and the shemeta
i did a little update , and i'll try to do it daily from now on...
please use pms to contact me
see you...
Old 7th June 2003, 14:41   #26  |  Link
Sirber
retired developer
Sirber's Avatar
New features:
AVI input support
Batch encoding (by modifying producer commandline)
Detritus Software
Old 9th June 2003, 22:22   #27  |  Link
Sirber
retired developer
Sirber's Avatar
Now that the new producer is out, RMFactory can use the new features.
Anamorphic + Q80 will be so cool!!
Detritus Software
Old 10th June 2003, 00:37   #28  |  Link
zedude
i just uploaded a new version that enables ehq mode with the latest producer (discuss here)
link for rmfactory 0.3
Old 16th June 2003, 07:27   #29  |  Link
phrentec
waprout?
phrentec's Avatar
i followed throught the links to get to the download and in the end it seems that it's a dead download link. are there any other mirrors to it that i may try because i haven't been able to get it? thanks.
phrentec is offline   Reply With Quote
Old 16th June 2003, 08:41   #30  |  Link
Synaps
@ phrentec
Try again, for me 2 links works fine !
Synaps is offline   Reply With Quote
Old 16th June 2003, 21:14   #31  |  Link
phrentec
waprout?
phrentec's Avatar
okay i tried again but the download still doesn't work. however i just tried HELIX PRODUCER GUI 0.2f http://tfc69.hopto.org/ and it serves the same purpose that i was looking for.
Old 19th October 2003, 11:46   #32  |  Link
Valky
Valky's Avatar
I wonder why this software hasn't never worked with MipSmooth.dll avs-filter? I haven't had any other problems with this and this is the easiest software to use if you wanna made your own avs-scripts and just encode them to RealMedia.
Valky is offline   Reply With Quote
Old 20th October 2003, 01:57   #33  |  Link
Sirber
retired developer
Sirber's Avatar
bug if output rez isn't divisible by 4
Detritus Software
Old 20th October 2003, 02:50   #34  |  Link
bilu
bilu's Avatar
Downloading http://perso.wanadoo.fr/zedudeishere...tory_RC1.2.exe
from that thread now...
First-time testing for me
Bilu
bilu is offline   Reply With Quote
Old 21st October 2003, 18:36   #35  |  Link
Valky
Valky's Avatar
Unfortunately, this mipsmooth-bug is in that too. This tool would have been so easy to use when testing avs-scripts without this one
Old 19th November 2003, 21:35   #36  |  Link
C0mPr355
On2 dungeon crawler
I cannot download the latest as the web page is not up
anyone can you send me the app?
I know nuhtzing!
C0mPr355 is offline   Reply With Quote
Old 19th November 2003, 21:40   #37  |  Link
The Shemeta
send it to you how?
Old 19th November 2003, 21:45   #38  |  Link
C0mPr355
On2 dungeon crawler
nm got it...
I know nuhtzing!
Old 17th December 2003, 23:53   #39  |  Link
wata
it been a long time
can we have english support for the latest version (v2.00)
wata is offline   Reply With Quote
Old 18th December 2003, 02:37   #40  |  Link
Kb_cruncher
replecant
Kb_cruncher's Avatar
I just installed RMFactory2 and it crashes on startup with a "RMFactory has encountered a problem and needs to close ,we are sorry for any inconvenience"
Is this a known issue or is there something i am doing wrong?
"There are no such things as problems,only solutions"-my father
Kb_cruncher is offline   Reply With Quote
