Thread Tools Display Modes
Old 21st January 2004, 11:32   #41  |  Link
Abnormal1
@2Cool
Thanks for that(Sorry, I should have searched).
Anyway I had a quick glance and Dark-Cracker was right so I will just set the maximum to 99 instead of that extra code.
Abnormal1
Abnormal1 is offline   Reply With Quote
Old 17th November 2005, 17:51   #42  |  Link
nkarnold
Is there an updated version of the code anywhere, with the fixes and other problems found rolled into it ?
Ta
nkarnold is offline   Reply With Quote
Old 18th November 2005, 17:24   #43  |  Link
Inc
Squeeze it!
Inc's Avatar
http://forum.doom9.org/showthread.ph...738#post719738
Although it's written in Purebasic, you will see very easy the logic how to access the ifo file and so a port to delphi wouldn't be a problem imho.
Inc is offline   Reply With Quote
Old 18th November 2005, 18:40   #44  |  Link
iNFO-DVD
Author of avi.NET rip.NET
iNFO-DVD's Avatar
Just remember that these examples tell you the information for that video set, usually video sets contain multiple PGC's which can share an amount of the total so you MUST delve further to get the exact information for the PGC.
iNFO-DVD is offline   Reply With Quote
Old 7th December 2005, 04:24   #45  |  Link
feliz
heres my update
just some minor corrections
feliz is offline   Reply With Quote
Old 25th January 2006, 22:39   #46  |  Link
Rockas
Ridendo Castigat Mores
Rockas's Avatar
Why there was no approval on this last attachment?
None is as blind as those that don't listen.
www.dvdrebuilder.com
RME
Rockas Software
Rockas is offline   Reply With Quote
Thread Tools
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
