Old 17th April 2003, 18:38   #201  |  Link
sh0dan
Retired AviSynth Dev ;)
sh0dan's Avatar
@milan: Sorry about the older libraries - I just copied the libraries from the last build, because I didn't know where to get them. I don't have access to the system that compiles this, as I'm on my backup computer at home.
I think someone with the proper setup should do a binary - I'll update the one on the site, when you post it.
Regards, sh0dan // VoxPod
sh0dan is offline   Reply With Quote
Old 19th April 2003, 02:16   #202  |  Link
Kamui-Dash
Droids Of Talon
This is pretty dumb but I was wondering if any1 got 2pass working from jobcontrol? I usually gets PARSE ERROR. Does any1 knows what this means?
Kamui-Dash is offline   Reply With Quote
Old 19th April 2003, 11:53   #203  |  Link
grabengulli
I try to compile the libavcodec_enc.dll but i have had an error:
ffvfw\src\ffmpeg\libavcodec\ratecontrol.c(131) : error C2520: conversion from unsigned __int64 to double not implemented, use signed __int64
what can i do?
thanks,
GrGu
grabengulli is offline   Reply With Quote
Old 19th April 2003, 15:26   #204  |  Link
athos
what can i do?
thanks,
GrGu
Do you compile with gcc? what version?
I suggest you use gcc for this (libavcodec, mplayer and libmpg2), as parts of the code is hand-optimized in assembler. If you use VC++, these parts will be unoptimized, or rather only the usual automatic optimizations by the compiler. I have compared using gcc and intel c++ compiler in vc++, and gcc is a lot faster thanks to the assembly parts.
athos is offline   Reply With Quote
Old 22nd April 2003, 09:52   #205  |  Link
grabengulli
I have tried it with gcc and all works fine. Thanks.
Grgu
Old 22nd April 2003, 14:25   #206  |  Link
milan
@kempfand
I wanted that registry entry to be added by installer, but then ffvfw was reported twice by VirtualDub and other VFW software so I decided to not do this.
@sungey
Stats files produced by ffvfw should be compatible with those produced by XviD. However ffvfw doesn't fill kblk, mblk and ublk fields. If needed I could fix that.
@grabengulli
Which Visual C++ version are you using? I just tested it with VC6+SP5+Processor pack and it compiles fine. Of course GCC is preferred compiler for libavcodec, but I want it to be compileable using VC too.
@Bach, @Kamui-Dash
I'll check that immediately.
ffdshow homepage: http://ffdshow.sourceforge.net/tikiwiki/
ffdshow download: http://sourceforge.net/projects/ffdshow/
milan is offline   Reply With Quote
Old 22nd April 2003, 14:46   #207  |  Link
milan
@Bach
I'm not able to get that error. Please try to capture debug data using DebugView (www.sysinternals.com), maybe there will be something useful.
@Kamui-Dash
Which version of VirtualDub are you using? ffvfw state data are quite long (usually about 1500 bytes) and maybe not every VirtualDub version is able to handle that. I just tested VirtualDubMod 1.4.13 and it works fine.
BTW I updated ffvdub and had similar problem storing the filter data to allow scripting support. The buffer supplied by VirtualDubMod was not big enough.
Old 22nd April 2003, 18:36   #208  |  Link
Blight
Software Developer
Blight's Avatar
milan:
are you keeping tabs on the ffdshow thread? there are a few bugs I've reported that could use resolving.
Yaron Gur
Zoom Player . Lead Developer
Blight is offline   Reply With Quote
Old 23rd April 2003, 07:51   #209  |  Link
milan
I'm now focused more on ffvfw. I know about ffdshow issues which need to be solved, but I'd like to do that after ffvfw release.
Old 23rd April 2003, 21:33   #210  |  Link
Kamui-Dash
Droids Of Talon
I used a vdub ver where i first copied the vdub files in nandub folder than vdubmod in it afterwards. The problem has been solved after I installed vdub in its own folder.
Old 24th April 2003, 18:23   #211  |  Link
JasonFly
JasonFly's Avatar
What does really mean Divx3 when choosing the encoder setting.
Does it mean that the movie will be encoded whith ffvfw and will only have a div3 fourcc or does it mean that you can encode in divx3 with ffvfw?
JasonFly is offline   Reply With Quote
Old 25th April 2003, 10:32   #212  |  Link
milan
When selecting Divx3 ffvfw uses libavcodec to encode video to DivX 3 compatible format. You should be able to decode it by the original DivX 3.11 codec. Same goes to MSMPEG4v2, however older versions of libavcodec produced buggy streams.
Old 25th April 2003, 10:37   #213  |  Link
grabengulli
Originally posted by milan
@grabengulli
I use VC6+SP5 but without the Processor pack . Only with MASM & NASM.
Old 25th April 2003, 10:47   #214  |  Link
milan
Then try to install the processor pack or at line 69 of ffvfw/src/ffmpeg/libavcodec/common.h (applies to current CVS) change
# define uint64_t_C(c) (c ## ui64)
to
# define uint64_t_C(c) (c ## i64)
However I don't know how it will affect the encoding, but I guess it should be OK. Even in ffmpeg CVS the i64 suffix is present, I changed it only in ffvfw CVS copy of libavcodec.
Old 26th April 2003, 17:04   #215  |  Link
LigH
LigH's Avatar
Nitrogen's mirror seems to be dead, but the greek Pathfinder is still alive:
http://homepages.pathfinder.gr/ffvfw
Old 27th April 2003, 11:03   #216  |  Link
unixfs
A short report
using ffvfw-20030325.exe (15/4 release crashes when using mpeg2enc)
I made a couple of short two-pass encoding of a black and white movie and a cartoon, using mpeg2enc-mpg1 and the following settings:
resolution: 352x288, search-radius 32, 4x4: 2, 2x2: 2, no alt-curve, payback proportionally, 772 kb/s, output to an external file.
I compared the output of both with the corresponding encodings made using libavcodec's MPEG1; to me it seems that mpeg2enc's results are
quite superior, but are much slower (roughly 9 fps during both passes on my Athlon XP 1500+). Surely it's a good solution for making VCDs without using TMPG.
@milan: as far as I know mpeg2enc doesn't support 2-pass encoding natively, is it a feature that you added? It's great!.
Can it be made faster?
Thanks very much for you excellent work.
unixfs is offline   Reply With Quote
Old 28th April 2003, 14:49   #217  |  Link
milan
I didn't performed any comparison of libavcodec mpeg1 encoding and mpeg2enc. I added mpeg2enc because I wanted to have an MPEG2 encoder in ffvfw and when Nic released his mpeg2enc compile I tested it and it seemed quite good to me.
I don't know if I can make it faster. Maybe it'd be useful to replace mpeg2enc quantization and DCT routines with those from libavcodec, but I don't think I'm capable of doing this now.
mpeg2enc two pass encoding uses the XviD two pass code. I find it very flexible and using it for Theora too. However this code doesn't have option for setting minimum bitrate which would be probably useful for MPEG1/2 encoding.
In MJPEGtools CVS log I saw that the mpeg2enc developers are implementing their own two pass encoding routines.
Old 28th April 2003, 20:34   #218  |  Link
sungey
another encoding dude..^^
sungey's Avatar
EDIT : wrong forum ... sorry
-- SunG --
" The more knowledge you give, the more knowledge you gain. Its different from wealth. "
sungey is offline   Reply With Quote
Old 29th April 2003, 16:32   #219  |  Link
grabengulli
to
I have tried it but it dosn't work. I have had the same error like before. I think this is an error at Visual Studio on my PC and not in the Source Code, because yesterday I had the same error in an other Source Code.
GrGu
Old 30th April 2003, 16:46   #220  |  Link
downloada
hi,
i don't know if this has been posted in this thread before (if it's been, than sorry!), but i have a problem with the 2003-03-25-version of ffvfw.
since i installed that version, everytime i open the "compression"-dialog in vdub/vdubmod, an error message saying msvcrtd.dll was missing pops up twice, the same thing happens when clicking on ffvfw in that dialog. i don't have that .dll on my pc and i couldn't find it on the net, so i don't know what would happen if i put that dll in my windir.
i didn't encode with it (just installed it because it was needed for one ffdshow-version), but it's impossible to do an automated encode via gordianknot with this errormessage, because i have to click it away twice. for now, i have uninstalled it and everything works fine, so it has to be a problem with ffvfw.
cu
downloada is offline   Reply With Quote
