Go Back   Doom9's Forum > Video Encoding > (Auto) Gordian Knot
Old 29th October 2003, 09:21   #21  |  Link
dihelson
What am I doing Wrong???
Hello,Friends,
I'd like to know what am I doing wrong.
I cant OPEN the AVI files which I captured using VirtualDub in this software VCFtoAVS.
My capture was made across many Hard Disks, and so, the files are named:
E:\capture1.00.avi
F:\capture1.02.avi
G:\capture1.03.avi
and so on...
I open the first file in VD very nice, I see all the capture, and then I save the VCF file.
When I open VCFtoAVS and try the BROWSE buttom it simply doesn't open my first AVI file. WHY ???
In time:VCFtoAVS version 1.9
VirtualDubMod version 1.4.13
Thanks in advance,
Dihelson Mendonca
dihelson is offline   Reply With Quote
Old 30th October 2003, 13:51   #22  |  Link
Shayne
Shayne's Avatar
UnalignedSplice(AVISource("part1.avs"), AVISource("part2.avs"),AVISource("part3.avs"))
# Same - AVISource("d:\capture.00.avi") + AVISource("d:\capture.01.avi") + AVISource("d:\capture.02.avi")
one of these 2 should work in your avs file
Shayne is offline   Reply With Quote
Old 7th June 2006, 09:53   #23  |  Link
akoten
Download is unavailable
the given DL link is dead. Could you pls give a working one?
AKo
akoten is offline   Reply With Quote
Old 7th June 2006, 14:42   #24  |  Link
Koti
Always trying
Koti's Avatar
http://forum.doom9.org/showthread.ph...386#post774386
dl link on this page
Koti is offline   Reply With Quote
Old 7th June 2006, 19:23   #25  |  Link
Darksoul71
Can you blush ?
Darksoul71's Avatar
@akoten: Thatīs only a scaled down version of the old VCF2AVS.
If you would like to have the "old" version then drop me a PM.
cu,
D$
Darksoul71 is offline   Reply With Quote
