Old 28th December 2002, 21:38   #21  |  Link
kxy
The text looks fine in your tool box, it appears only after I saved to a text file.
I am using the latest IE.
This happens to all the movies. But I will use minority report as an example, I use allmovie.com to get the chapter info, since it is the only place that have the chapter atm.
I have attatched the ifo file for testing purposes.
http://www.allmovie.com/cg/avg.dll?p=avg&sql=RE|31163
http://service.bfast.com/bfast/click...24&bfmtype=dvd
http://www.blockbuster.com/bb/dvd/de...31163,00.html?
kxy is offline   Reply With Quote
Old 28th December 2002, 21:52   #22  |  Link
Emp3r0r
Emp3r0r's Avatar
Updated Version
@kxy: thanks for your testing, this build should fix that bug.
[update]Newer Version Below[/update]
ChapterGrabber - add names to your chapters | AtomSite - open source AtomPub server
Emp3r0r is offline   Reply With Quote
Old 30th December 2002, 06:54   #23  |  Link
kxy
New problem, the movie is called father's day
This is the chapter format
0. Scene Index
1. "Young Boy." [2:51]
2. I don't find/I sue. [3:26]
3. "My son needs me." [2:28]
4. Try on fatherhood. [1:40]
5. Tip Top Towing. [4:26]
6. Asleep at wheel. [2:04]
7. Maudlin at marina. [4:48]
8. Comparing notes. [2:53]
9. In Sacramento. [4:22]
10. Four for the road. [3:53]
11. Toes and whirls. [3:14]
12. Complex goings-on. [3:24]
13. Rude awakening. [4:46]
14. Toilet gone south. [1:15]
15. Coffee crashout. [3:20]
16. The lower depths. [:39]
17. New travel plans. [2:00]
18. Reluctant flyer. [3:30]
19. Reno reunion #1. [2:04]
20. Running wild. [3:49]
21. Dad stories. [5:34]
22. Reno reunion #2. [4:16]
23. "I need this kid." [1:48]
24. Happy now? [2:09]
25. The awful truth. [3:57]
26. Piercing questions. [1:04]
27. Headbusters. [2:28]
28. Fly down from Reno. [1:22]
29. Nice family. [2:47]
30. Truth twice over. [2:46]
31. Did good. [2:57]
32. From the beginning. [1:34]
33. In driver's seat. [1:45]
This is the chapter that is from the ifo
CHAPTER01=00:00:00.000
CHAPTER01NAME=Chapter 1 -
CHAPTER02=00:02:51.500
CHAPTER02NAME=Chapter 2 -
CHAPTER03=00:06:18.467
CHAPTER03NAME=Chapter 3 -
CHAPTER04=00:08:46.467
CHAPTER04NAME=Chapter 4 -
CHAPTER05=00:10:26.867
CHAPTER05NAME=Chapter 5 -
CHAPTER06=00:14:53.200
CHAPTER06NAME=Chapter 6 -
CHAPTER07=00:16:57.200
CHAPTER07NAME=Chapter 7 -
CHAPTER08=00:21:45.200
CHAPTER08NAME=Chapter 8 -
CHAPTER09=00:24:38.266
CHAPTER09NAME=Chapter 9 -
CHAPTER10=00:29:00.532
CHAPTER10NAME=Chapter 10 -
CHAPTER11=00:32:54.065
CHAPTER11NAME=Chapter 11 -
CHAPTER12=00:36:08.265
CHAPTER12NAME=Chapter 12 -
CHAPTER13=00:39:33.232
CHAPTER13NAME=Chapter 13 -
CHAPTER14=00:44:20.066
CHAPTER14NAME=Chapter 14 -
CHAPTER15=00:45:35.599
CHAPTER15NAME=Chapter 15 -
CHAPTER16=00:48:56.533
CHAPTER16NAME=Chapter 16 -
CHAPTER17=00:49:36.033
CHAPTER17NAME=Chapter 17 -
CHAPTER18=00:51:36.133
CHAPTER18NAME=Chapter 18 -
CHAPTER19=00:55:07.033
CHAPTER19NAME=Chapter 19 -
CHAPTER20=00:57:11.433
CHAPTER20NAME=Chapter 20 -
CHAPTER21=01:01:00.466
CHAPTER21NAME=Chapter 21 -
CHAPTER22=01:06:34.599
CHAPTER22NAME=Chapter 22 -
CHAPTER23=01:10:51.399
CHAPTER23NAME=Chapter 23 -
CHAPTER24=01:12:40.133
CHAPTER24NAME=Chapter 24 -
CHAPTER25=01:14:49.233
CHAPTER25NAME=Chapter 25 -
CHAPTER26=01:18:46.700
CHAPTER26NAME=Chapter 26 -
CHAPTER27=01:19:51.233
CHAPTER27NAME=Chapter 27 -
CHAPTER28=01:22:20.067
CHAPTER28NAME=Chapter 28 -
CHAPTER29=01:23:42.367
CHAPTER29NAME=Chapter 29 -
CHAPTER30=01:26:30.034
CHAPTER30NAME=Chapter 30 -
CHAPTER31=01:29:16.934
CHAPTER31NAME=Chapter 31 -
CHAPTER32=01:32:14.634
CHAPTER32NAME=Chapter 32 -
CHAPTER33=01:33:49.601
CHAPTER33NAME=Chapter 33 -
CHAPTER34=01:35:35.401
CHAPTER34NAME=Chapter 34 -
If your tool is used, then it goes like this
CHAPTER01NAME="Young Boy." [2:51]
CHAPTER02NAME=I don't find/I sue. [3:26]
CHAPTER03NAME="My son needs me." [2:28]
CHAPTER04NAME=Try on fatherhood. [1:40]
CHAPTER05NAME=Tip Top Towing. [4:26]
CHAPTER06NAME=Asleep at wheel. [2:04]
CHAPTER07NAME=Maudlin at marina. [4:48]
CHAPTER08NAME=Comparing notes. [2:53]
CHAPTER09NAME=In Sacramento. [4:22]
CHAPTER10NAME=Four for the road. [3:53]
CHAPTER11NAME=Toes and whirls. [3:14]
CHAPTER12NAME=Complex goings-on. [3:24]
CHAPTER13NAME=Rude awakening. [4:46]
CHAPTER14NAME=Toilet gone south. [1:15]
CHAPTER15NAME=Coffee crashout. [3:20]
CHAPTER16NAME=The lower depths. [:39]
CHAPTER17NAME=New travel plans. [2:00]
CHAPTER18NAME=Reluctant flyer. [3:30]
CHAPTER19NAME=Reno reunion #1. [2:04]
CHAPTER20NAME=Running wild. [3:49]
CHAPTER21NAME=Dad stories. [5:34]
CHAPTER22NAME=Reno reunion #2. [4:16]
CHAPTER23NAME="I need this kid." [1:48]
CHAPTER24NAME=Happy now? [2:09]
CHAPTER25NAME=The awful truth. [3:57]
CHAPTER26NAME=Piercing questions. [1:04]
CHAPTER27NAME=Headbusters. [2:28]
CHAPTER28NAME=Fly down from Reno. [1:22]
CHAPTER29NAME=Nice family. [2:47]
CHAPTER30NAME=Truth twice over. [2:46]
CHAPTER31NAME=Did good. [2:57]
CHAPTER32NAME=From the beginning. [1:34]
CHAPTER33NAME=In driver's seat. [1:45]
As you can see, the chapter is off by one, the first chapter should really start at chapter 2, and so forth.
Old 31st December 2002, 22:05   #24  |  Link
Emp3r0r
Emp3r0r's Avatar
@kxy: do you think this will be a common problem (ie: will it happen in more than a few situations)? The obvious way to fix it would be to manually change the copied chapter numbers. Otherwise I must add some kind of shift names function (wouldn't be hard) but I'm not so sure it is needed. Is it?
Old 2nd January 2003, 03:08   #25  |  Link
kxy
Maybe instead matching it to number 1 of the chapter, you can match it with the last chapter and go backwards. You think that will be a good idea?
Old 2nd January 2003, 06:31   #26  |  Link
Emp3r0r
Emp3r0r's Avatar
I made a new version that did as you say but then realized that wouldn't work with the way I am importing the chapters because it relies on the actual number of the chapter. I'll release the source of the C# class I have once I fix this issue.
[edit]Soucecode now available below![/edit]
PS: BTW KISS == Keep It Simple Stupid
Old 2nd January 2003, 17:55   #27  |  Link
Apfelstruhdl
Dead Member
Apfelstruhdl's Avatar
i can't start your prog i always get error:
the aplication couldn't be started right (0xc0000135)
(i hope u understand that)
i am using xp do i need to have something installed in order to use your proggy??
btw i really like the idea of your prog.
P.S. are there more tools for ogm. for example a tool where you can make an setup file for OGMuxer or a commandline?
i thought of programming my own tool but i can only programm in VB and i'm really not very expirienced.
ao if there's such a tool already maybe somebody could post a link.
höhöhö hehehe muh muh möhh
Apfelstruhdl is offline   Reply With Quote
Old 2nd January 2003, 18:10   #28  |  Link
BoNz1
BoNz1's Avatar
i can't start your prog i always get error: the aplication couldn't be started right (0xc0000135)
The reason why you get this is error is because the .net framework is not installed. Get it from m$ it is about 20MB.
BoNz1 is offline   Reply With Quote
Old 2nd January 2003, 22:30   #29  |  Link
Emp3r0r
Emp3r0r's Avatar
Thats correct, you need to download .NET Framework or install Service Pack 1 for XP.
Old 3rd January 2003, 13:44   #30  |  Link
Apfelstruhdl
Dead Member
ok thx
and what about other support tools. does anybody know some...?
Old 28th January 2003, 16:08   #31  |  Link
Apfelstruhdl
Dead Member
could you add support for an european site with ean numbers?? as almost no european dvd can be found at the site your using...
Old 29th January 2003, 05:27   #32  |  Link
Emp3r0r
Emp3r0r's Avatar
can you recommend some sites?
Old 29th January 2003, 12:01   #33  |  Link
Apfelstruhdl
Dead Member
ok i'll try to find some
Maybe somebody already knows a site which offers chapter info + european ean numbers??
Old 21st February 2003, 13:32   #34  |  Link
Bluedan
Bluedan's Avatar
Any updates?
I get the same error as Apfelstruhdl, though SP1 is installed, and I cannot remember that I was asked if I wanted .NET to be installed or not.
Ideas?
Is it hard to craete a non-net dependend version, Emp3rOr?
I'm probably misconfused...
Bluedan is offline   Reply With Quote
Old 25th February 2003, 07:19   #35  |  Link
Emp3r0r
Emp3r0r's Avatar
I could turn this program into a webpage, but then you'd have to upload your IFO file. I apologize for the lack of updates, I've been very busy with school and work.
Old 25th February 2003, 12:52   #36  |  Link
Bluedan
Bluedan's Avatar
Acknowledged.
Just wanted to make sure, that you know that your party is still onboard.
Meanwhile I simply like to get this working on my machine...
BTW, do you remember a European site dealing with region 2 chapter info?
A couple times and more than a few, region 1 based sites (blockbuster; B&N) seem to provide 10 more chapters entries per movie than stated by the IFO of my version.
Old 26th February 2003, 13:26   #37  |  Link
Apfelstruhdl
Dead Member
I searched for a site. But couldn't find one.
Is it a must to use the ean code for identifying a dvd or would a name be enough??? and then i u would get more than one hit maybe a selection option?
anyway if somebody knows a european side providing chapter info let us know
Old 12th April 2003, 22:19   #38  |  Link
Emp3r0r
Emp3r0r's Avatar
New Update
I did some minor changes:
- fixed "file handle not closing upon save" bug
- updated import from internet to import movie title
- added some keyboard shortcuts
Download [edit]newer version below[/edit] (13 KB)
@Apfelstruhdl: I'll work on a selection option
Old 5th June 2003, 02:34   #39  |  Link
Animaniac
Animaniac's Avatar
I can't find this tool anywhere, can someone mirror it. Thanks. ^_^
Animaniac is offline   Reply With Quote
Old 5th June 2003, 17:24   #40  |  Link
Hiro2k
New Container Mod
The newest Link is not working for me
Hiro2k is offline   Reply With Quote
