Old 11th September 2002, 15:36   #41  |  Link
trbarry
trbarry's Avatar
About resize, does anybody know if last bug of simpleresize.dll concerning chroma/luma shift has been solved?
Haven't find any post by trbarry talking about this... yet.
Sorry, some other stuff came up and I confess I haven't done anything on that. I'll try to get back to it soon.
But SimpleResize is just an optimized bilinear resize without the triangle filter. This means it goes faster but does not filter and is then (duh) best when you don't need any filtering. So if you had overly sharp material already (uncommon) then it could create aliasing artifacts if you downsized a lot. And of course it passes through all the noise, but also all the detail.
I think the more sophisticated (but slower) algorithms like BiCubic and Lanczos3 are general purpose and can do a much better job when upsizing, filling in gradients smoothly. SimpleResize probably wouldn't upsize very well, at least at ratios bigger than (swag) 1.5:1 or so. But of course for encoding purposes we are usually downsizing.
Anyway, I promise to go look for the chroma shift bug.
- Tom
trbarry is offline   Reply With Quote
Old 11th September 2002, 15:59   #42  |  Link
Blight
Software Developer
Blight's Avatar
I wonder how my factor resizing would look in comparison, sadly, it's impossibly slow (around 400ms/frame) and I don't think I could incorporate delphi code into avisynth without someone translating headers.
Yaron Gur
Zoom Player . Lead Developer
Blight is offline   Reply With Quote
Old 11th September 2002, 16:42   #43  |  Link
Marc FD
XviD fan
Marc FD's Avatar
delphi is easy to translate in C.
(i'm a former delohi user )
Marc FD is offline   Reply With Quote
Old 11th September 2002, 16:56   #44  |  Link
Blight
Software Developer
Blight's Avatar
Here's the function I wrote, rather crude but give it a shot.
procedure ImageFactorResize(SrcBitmap,DestBitmap : TBitmap; DestX,DestY,dWidth,dHeight : Integer);
var
  Speed1            : Integer;
  Speed2            : Integer;
  Speed4            : Integer;
  PixR              : Integer;
  PixG              : Integer;
  PixB              : Integer;
  SX,SY             : Integer;
  X,Y               : Integer;
  PixXShl           : Integer;
  PixYShl           : Integer;
  PixXRnd           : Integer;
  PixYRnd           : Integer;
  PicWidth          : Integer;
  PicHeight         : Integer;
  PixCount          : Integer;
  PixXPos           : Integer;
  PixYPos           : Integer;
  P                 : ^TMyScanLine;
  PL                : Array[0..4095] of ^TMyScanLine;
  PDif              : Integer;
begin
  // Calculate memory used for each line display for quick scanline seeks (dest image)
  PL[0] := SrcBitmap.Scanline[0];
  PL[1] := SrcBitmap.Scanline[1];
  PDif  := Integer(PL[1])-Integer(PL[0]);
  // Pre-Calculate scanline positions for source image
  For Y := 2 to SrcBitmap.Height-1 do Integer(PL[Y]) := Integer(PL[Y-1])+PDif;
  // Pre-Calcualte some repeated math
  PicWidth     := SrcBitmap.Width  shl 2;
  PicHeight    := SrcBitmap.Height shl 2;
  PixXShl      := (PicWidth  shl 8) div dWidth;
  PixYShl      := (PicHeight shl 8) div dHeight;
  PixXRnd      := Round(PicWidth  / dWidth);
  PixYRnd      := Round(PicHeight / dHeight);
  PixCount     := PixXRnd*PixYRnd;
  // Calculate memory used for each line display for quick scanline seeks (source image)
  P            := DestBitmap.Scanline[DestY];
  PDif         := Integer(DestBitmap.Scanline[DestY+1])-Integer(P);
  // scale the image
  For Y := 0 to dHeight-1 do
  Begin
    PixYPos := (Y*PixYShl) shr 8;
    For X := 0 to dWidth-1 do
    Begin
      PixR         := 0;
      PixG         := 0;
      PixB         := 0;
      PixXPos      := (X*PixXShl) shr 8;
      For SY := 0 to PixYRnd-1 do
      Begin
        Speed1 := ((PixYPos+SY) shr 2);
        For SX := 0 to PixXRnd-1 do
        Begin
          Speed2 := (PixXPos+SX) shr 2;
          Inc(PixR,PL[Speed1]^[Speed2].MRed);
          Inc(PixG,PL[Speed1]^[Speed2].MGreen);
          Inc(PixB,PL[Speed1]^[Speed2].MBlue);
        End;
      End;
      Speed4 := X+DestX;
      P^[Speed4].MRed   := PixR div PixCount;
      P^[Speed4].MGreen := PixG div PixCount;
      P^[Speed4].MBlue  := PixB div PixCount;
    End;
    Inc(Integer(P),PDif);
  End;
end;
Oh, and there's the factor value in here somewhere, I think it's the shr 2, you can up the quality by doing shr 3, shr 4 (which increase the sub-picture calculation), etc...
This is more accurate than biliniar for downscaling, but not for upscaling. Very CPU intensive
Yaron Gur
Old 11th September 2002, 19:24   #45  |  Link
Marc FD
XviD fan
Marc FD's Avatar
Argh.
I'm really bad when it comes to resamplers... never really etudied the stuff.
and this is only a portion of code....
so i don't understand it really...
I think i should do a benchmark a day between all these resampling algos to find wich is best for each purpose.
BTW, vlad, you integrated the Lanczos3 in the resampling-engine of your avisynth version, or you just added the filter ?
Old 11th September 2002, 22:30   #46  |  Link
Defiler
Asker of Questions
Blight: What programming language is that? Delphi?
It looks a little like Ada.
"The real trick to optimizing color space conversions is of course to not do them." --trbarry, April 2002
Defiler is offline   Reply With Quote
Old 11th September 2002, 22:58   #47  |  Link
Dark-Cracker
Dark-Cracker's Avatar
i am not sure your resize filter will be faster even if u translate it in c , try to use asm else it will be very slow .
if u are interested i think u could find the source of the lanczos aviutl filter on the site web indicated by nic (scroll up) and it seems to me there is an another filter resize with source code called "icubic convolution algorythm" perhaps this will help u to make a quick filter resize.
AutoDub v1.8 : Divx3/4/5 & Xvid Video codec and .OGG/.MP3/.AC3/.WMA audio codec.
AutoRV10 v1.0 : Use RealVideo 10 Codec and support 2 Audio Streams and Subtitles.
Dark-Cracker is offline   Reply With Quote
Old 13th September 2002, 11:23   #48  |  Link
Blight
Software Developer
Blight's Avatar
This is Delphi (Visual Pascal), and even if I converted it to ASM+MMX+SSE+SSE2 it would probably be a lot slower than bicubic as the amount of calculations is very high.
It basically does a sub-pixel calculation on a factor level, at a factor of 2 of splits a pixel into a 4x4 grid, at a factor of 3, an 8x8 grid, a factor for 4 a 16x16 grid.
Factor of 4 looks nice when downscaling. But even if optimized up the wazoo would probably take over 250ms per frame.
Yaron Gur
Old 13th September 2002, 11:47   #49  |  Link
Didée
Confirmation
Matrix: Kung-Fu Scene (Neo vs. Morpheus), MPEG-quant 2, 640*256, 4min23s
Bilinear:              59776 kB
Bicubic 0.333/0.333:   61580 kB
SimpleResize:          65782 kB
Bicubic 0.0/0.5:       67102 kB
Bicubic 0.0/0.75:      69638 kB
Lanczos3Resize:        69804 kB
Bicubic -0.2/0.6:      70670 kB
Bicubic -0.333/0.666:  73056 kB
Bicubic -2.0/1.5:     125194 kB  <-- Just for fun
So, Lanczos is my favorite, if there are enough bits available for a sharp downscaling.
Because, where Bicubic 0/0.75 starts producing halos, Lanczos3 deals alot better for me.
Old 13th September 2002, 13:13   #50  |  Link
ookzDVD
DVD Rebuilder!
ookzDVD's Avatar
Yes,
the lanczos3 produce the sharper image than the neutral bicubic,
I just finish the _Monsters_Inc_ and the result is superb.
@Nic,
thanks for the lanczos3.dll
slower than the build-in modified avisynth, but it produce sharper
image imho, as you could see the aigo's screenshot.
ookzDVD is offline   Reply With Quote
Old 13th September 2002, 14:31   #51  |  Link
Dark-Cracker
hi,
for those who are interested to make some tests u can find my tool (autodub) here : http://forum.doom9.org/showthread.php?s=&threadid=24678
test the v1.6 it come bundle with the lanczos filter and u can make a compressibility test of course it support the codec divx3/4/5 & xvid
bye.
Old 13th September 2002, 16:21   #52  |  Link
Marc FD
XviD fan
Marc FD's Avatar
Just a question :
- why do you all want to sharpen your image when you downsize ?
If i want the best image possible, i would keep 720x...
I don't see why you need to downsize if you want to achieve a bigger filesize.
I thinked the problem in ripping was to get a low enough file to put it on 1-2 CDs.
I think i've missed something.... let's re-read the whole doom9 forum....
Old 13th September 2002, 16:34   #53  |  Link
drizztcanrender
drizztcanrender's Avatar
Originally posted by Marc FD
Just a question :
Well in my encodes, lanczos3 doesn't increase the filesize,not more than sharp bicubic at least.And encodes on full resolutions are hard to make,even with 2 cds.At least for my eyes some resizing looks better than none...
drizztcanrender is offline   Reply With Quote
Old 13th September 2002, 17:12   #54  |  Link
Marc FD
XviD fan
Marc FD's Avatar
for my eyes
That's the reason why RV9 as so many adepts.
It "looks" so good.
But i'm not a serial ripper.
pratically, you're right.
theorically, not.
Old 13th September 2002, 18:30   #55  |  Link
drizztcanrender
A lot of stuff have a theoretical advantage but they don't have much practical significance.And the encoding procedure is indeed based on a theoretical background but it all comes down to practical results.So, imho,if it looks better then it is better.After all isn't that what we are trying to do?Make our film content look better?
The only problem of course would be the effect that lanczos3 resize would have in compressability and therefore in the final filesize.But, in my tests, lanczos resize and (even)sharp bicubic encodes have the same final filesize and display almost the same compressability and lanczos3 resize looks better,at least with divx5(it really needs the extra sharpening effect to diminish the blurring of divx5 encodes).
Old 13th September 2002, 19:57   #56  |  Link
FuPP
TotalEclipseOfTheBrain
FuPP's Avatar
Why downresizing ?
@MARC :
Quote :
if i want the best image possible, i would keep 720x...
In some case, we HAVE to resize (cf svcd , vcd, cvd specifications...). We don't all encode with XVID
FuPP is offline   Reply With Quote
Old 13th September 2002, 21:50   #57  |  Link
vlad59
Vlad, the Buffy slayer
vlad59's Avatar
@iago (= serial tester )
Thanks a lot for the testing.
With your screenshots it's clear the Nic's filter provide sharper picture (IrfanView 300%) and also greater compressibility. I was right to be doubtful about my Lanczos implementation in avisynth (it was too easy).
I think I should remove the dll.
Vlad59
Convolution3D for avisynth 2.0X : http://www.hellninjacommando.com/con3d
Convolution3D for avisynth 2.5 : http://www.hellninjacommando.com/con3d/beta
vlad59 is offline   Reply With Quote
Old 14th September 2002, 15:09   #58  |  Link
droolian01
Hi there.
I've been using the lanczos3 resise for my last few encodes and i like the results. Now i know there is a bicubic directshow filter for keeping sharper output during full screen playback, i wonder if it is possible to produce al anczos3 directshow filter.
OK - please please please can one of you brainy programmers do this, i think it would really improve fullscreen playback
Waiting with baited breath
droolian01 is offline   Reply With Quote
Old 14th September 2002, 16:00   #59  |  Link
Koepi
Koepi's Avatar
I'm mostly impressed by the nice color representation of lanczos3. Now it's really easy to beat some group releases as the filter is the right one
But "from hell" looks so nice now, I'm trying zoolander as well with it. I'm so glad that I stepped back from simple resize... I like the speed of it, but the resulting picture has too many downscaling artefacts (like aliasing from "thin lines" [ the bamboo-stick in rush hour 2 where chirs tucker and jacky chan are hanging on for example looks horrible with simpleresize])
To bad that compressability lowers about 10%-15%...
Best regards,
Koepi
Koepi is offline   Reply With Quote
Old 14th September 2002, 16:08   #60  |  Link
int 21h
Still Laughing
int 21h's Avatar
I've noticed also SimpleResize making jagged artifacts. I tried using it only once for a SVCD and the quality was horrible. My only guess is that it has issues doing very large downscaling.
int 21h is offline   Reply With Quote
