Old 1st February 2007, 18:20   #41  |  Link
karl_lillevold
karl_lillevold's Avatar
Thanks for the archive.org link. I have (finally) included this in the first post in this thread.
This information is provided "AS IS" with no warranties, grants no rights, and reflects my personal opinion.
karl_lillevold is offline   Reply With Quote
Old 27th March 2007, 23:54   #42  |  Link
karl_lillevold
Hmm, it seems the archive.org zip files are corrupted.
If anyone knows if AutoRV10 with the latest update (b8) is hosted anywhere, please post it here.
Old 28th March 2007, 09:45   #43  |  Link
Dark-Cracker
Dark-Cracker's Avatar
i can't get in toutch with my webmaster , so if someone know where i can host the binaries, i will be glad to upload them again, and post the new release too
Bye.
AutoDub v1.8 : Divx3/4/5 & Xvid Video codec and .OGG/.MP3/.AC3/.WMA audio codec.
AutoRV10 v1.0 : Use RealVideo 10 Codec and support 2 Audio Streams and Subtitles.
Dark-Cracker is offline   Reply With Quote
Old 29th March 2007, 12:49   #44  |  Link
DarkZell666
aka XaS
DarkZell666's Avatar
@Dark-Cracker: check your PM's
Q9300 OC @ 3.2ghz / Asus P5E3 / 4GB PC10600 / Geforce 8600 GTS
DarkZell666 is offline   Reply With Quote
Old 13th April 2007, 23:40   #45  |  Link
Dark-Cracker
hi everybody
sorry for the long time without news i was busy with my job, however i still work sometimes on autorv10.
here is a new release with a few bugfix and a rewritten audio part with better support for DTS streams, and no more problems with tempory audio file bigger than 2gb.
http://benjapi.free.fr/autorv10/down...oRV10_v1.1.zip
you can see a picture of the new audio part here :
http://benjapi.free.fr/autorv10/down...rv10_audio.JPG
there is probably a few bugs introduced with the audio changes so feel free to report bugs or improvement request.
Bye.
Old 18th April 2007, 15:52   #46  |  Link
Dark-Cracker
Does some people are interested in a better support of HD source (Blu-Ray, HDTV, HDDVD) in autorv10 ?
If you have some suggestion, request on HD support feel free to post them i will try to see how i could add this.
Bye.
Old 18th April 2007, 17:04   #47  |  Link
karl_lillevold
This looks very interesting. I will try it out as soon as I can.
One question: in your audio screenshot, the source file is a WAV file. If you choose an AC3 file, will this then be included in the Avisynth script for encoding, without first transcoded to WAV?
I wish there had been a way to easily mux AC3 into the RM file, but for this purpose one probably still has to use Matroska..
Old 18th April 2007, 23:56   #48  |  Link
Dark-Cracker
yes if you choose and AC3 or DTS file autorv10 will use the NicAudio plugin to open it directly from the .avs file no more tempory wav file. And of course you could still apply some transformation like to downmix the 5.1ch file to a 2.0 channel file and also the possibility to upmix a 2.0 file in a 5.1ch audio stream.
And you also have an audio preview in stereo mode.
I have made a bunch of tests but if you found a strange beheviours feel free to post a msg
Bye.
Old 17th June 2007, 14:42   #49  |  Link
adrianmak
does AutoRV10 not support mp3 audio ?
When I input a mp3 audio and click "play" button, it said
m2AudioMPASource: MPEG Layer III is not yet supported
adrianmak is offline   Reply With Quote
Old 26th February 2009, 04:56   #50  |  Link
BluDRed
BluDRed's Avatar
Nice tool mate, just gave it a test run. However I think I may have stumbled onto a bug. I added an AC3 audio file to mux at the end, and it didn't mux , I did add ac3enc.dll just in case it needed that to mux the audio file in. I shall have to try muxing in an mp3 next time, but for now Im going to persevere with adding on this ac3. Any thoughts anyone?
BluDRed is offline   Reply With Quote
Old 26th February 2009, 06:19   #51  |  Link
BluDRed
BluDRed's Avatar
Thought this might be some good info to share with this thread. Thanks to a mr. gastorgrab, there is a way of adding audio to RMVB files with the use of virtualdubmod!
for this you will need:
1 virtualdubmod (a recent version should be used for muxing in audio)
2 AVISynth (I don't think it matters how recent the version is)
3 RealAlternative media splitter fully installed
In the virtualdubmod program folder, there is a directory named "Templates", which is filled with .avst files.
You will need to create a .avst file with notepad, that looks like this:
#ASYNTHER RealMedia 23.976fps
[DirectShowSource("%f",23.976)]
The movies frame rate is important as virtualdubmod will now only open RMVB files with a frame rate of 23.976, however this can be changed to suit your needs. When I am done here, I intend on creating template .avst files for all frame rates.
Now startup VirtualDubMod -> File -> Open video file.
Select to view all files, then at the bottom left of the window, a click down menu will be available to you. Select the template you just created then continue to open our desired RMVB file.
From after opening your RMVB vid, audio can be muxed in.
Let me know how this works for you guys.
EDIT. Im having trouble with muxing in using direct stream, seems to be un-compressing the RMVB file, find a way of integrating the RMVB codec into virtualdubmod to get keep the file compressed by the looks of things.
Old 1st March 2009, 20:16   #52  |  Link
BluDRed
BluDRed's Avatar
MKVMerge GUI muxes audio into RMVB files, although the output file is MKV. Good thing is there's no change to the quality of the video during the process, so a success!... am I the only person viewing this thread these days?
Old 1st March 2009, 22:26   #53  |  Link
IgorC
More probably. Most of people have moved to H.264 some years ago. Better quality, better compatibility and faster playback.
IgorC is offline   Reply With Quote
Old 3rd March 2009, 19:30   #54  |  Link
roozhou
Unfortunately this is not the truth. In my coutry many people are still using Easy RealMedia Producer and this helps rmvb to dominate videos over Internet.
Yes x264 can beat rv10 qualitywise but there is no "Easy MP4 Producer". ERP or RealProducer itsself contains video/audio filters, rv40 encoder, aac/he-aac encoder and rm muxer. It uses directshow to decode and does not require .NET, avisynth or anything not shipped with Windows.
roozhou is offline   Reply With Quote
Old 4th March 2009, 02:40   #55  |  Link
IgorC
Originally Posted by roozhou View Post
In my coutry many people are still using Easy RealMedia Producer ...
Realland?
Old 5th March 2009, 04:13   #56  |  Link
iwod
Realland?
Well Asia, especially CJK, are still using a lot of RV10
iwod is offline   Reply With Quote
Old 5th March 2009, 08:18   #57  |  Link
IgorC
I have my theory about why RV10 is popular in Asia.
White and yellow people have different visual perception and also different genetic vision defects.
For example 80% of Chinese have myopia (at least -0.5 dpt). It's my case too as I'm half blood asian. I don't see difference without glasses between H.264 and RV10 at distance more than 1m.
While myopia hasn't massive character for white people but hyperopia which origins preferences for more details (even maybe with some slight artifacts)
Old 5th March 2009, 17:17   #58  |  Link
roozhou
Very interesting theory. Though I believe RV10 is popular here because it is easier to create and play. Compared to the crappy vfw encoders (DivX and xvid), RealProducer wins on both convenience and quality. When x264 was born rmvb had already conquer the internet.
Old 8th March 2009, 06:12   #59  |  Link
iwod
Yes. i think rmvb is still relatively good at smaller bitrate compare to x264. Especially for anime.
