Old 12th April 2015, 14:19   #101  |  Link
Reel.Deel
Originally Posted by kotuwa View Post
What is the difference between putting two functions in two lines vs in one line with a period/dot (.)
Performance-wise differences,
And differences in Qulaity and Lossyness...
There should be no difference. It's just 2 different ways of achieving the same thing.
Old 12th April 2015, 16:26   #102  |  Link
creaothceann
The first version is the short form of
last = Crop(last, 0, 10, 0, -10)
last = Spline64Resize(last, 1280, 720)
...and the second version is the short form of
last = Spline64Resize(Crop(last, 0, 10, 0, -10), 1280, 720)
The difference is that in the second version, the implied (hidden) variable "last" is not modified between the lines. Consider this example:
Version
PointResize(Width * 2, Height * 2)
PointResize(Width / 2, Height / 2)
Result_1 = last
Version
PointResize(Width * 2, Height * 2).PointResize(Width / 2, Height / 2)
Result_2 = last
Clip "Result_1" will have the same content as the result of "Version", but clip "Result_2" will be half the size of "Version" because "Width" and "Height" refer to clip "last" when not prefixed with a clip variable name.
Expanded to its full form the example looks like this:
a = Version
b = PointResize(a, a.Width * 2, a.Height * 2)
c = PointResize(b, b.Width / 2, b.Height / 2)
Result_1 = c
d = Version
e = PointResize(PointResize(d, d.Width * 2, d.Height * 2), d.Width / 2, d.Height / 2)
Result_2 = e
Btw. an easy way to add a blur effect would be this:
BilinearResize(int(Width * 0.75), int(Height * 0.75)).BilinearResize(Width, Height)
creaothceann is offline   Reply With Quote
Old 16th October 2017, 21:30   #103  |  Link
ale_x
Hi.
I used this function recently
ExtractU().dither_resize16()
But I got an error "there is no function named ExtractU"
by the way, I'm using Avynth + .
Thanx =)
ale_x is offline   Reply With Quote
Old 16th October 2017, 21:52   #104  |  Link
Groucho2004
You're probably using an older version of AVS+ that does not have that function. Update to the latest version (r2508).
Old 17th October 2017, 10:40   #105  |  Link
ale_x
Thank u very much =).
Old 17th October 2017, 15:13   #106  |  Link
real.finder
I think last posts should move to https://forum.doom9.org/showthread.php?t=174120
My Avisynth Stuff
Old 26th December 2017, 07:25   #107  |  Link
ilko
Q : is there a way to enumerate variables in avs ?
I'm trying to do something similar to the following batch script :
set /a count=1
set var=video%count%
echo the resulting var is "video1"
set /a count+=1
echo we add 1 to the initial count so it's now 2
echo then we set the var gain
echo the var is now "video2"
pause
My BLog
ilko is offline   Reply With Quote
Old 26th December 2017, 10:39   #108  |  Link
RT_Stats:- https://forum.doom9.org/showthread.p...light=RT_Stats
RT_VarExist(string)
 Given the name (string) of the variable that you want to test for existence, returns true if exists, else false.
 Eg, #a=32
    RT_Debug(string(RT_VarExist("a")))  # would output 'false' to debugview unless '#a=32' uncommented. {Defined(a) would fail with error}.
    return colorbars()
Could also simulate (for Globals) with Try/Catch in script (within a function, and return as result).
EDIT:
Function VarType(String GlobalName) {
    Try {
	g = Eval(GlobalName) # Fail here if not exist
        res=    g.IsBool   ? 1
            \ : g.IsInt    ? 2
            \ : g.IsFloat  ? 3
            \ : g.IsString ? 4
            \ : g.IsClip   ? 5
            \ : 0
    } Catch (msg) {
        res = 0 # Not Exist
    return res
Function VarTypeName(Int TypIx) {Assert(0 <= Typix <= 5,"VarTypeName: Bad Typix") Return Select(TypIx,"NOT_EXIST","Bool","Int","Float","String","Clip")}
Global G_i = 666   # Comment Me Out
Type = VarType("G_i")
TypeName=VarTypeName(Type)
MessageClip("Global G_i Type = "+String(Type) + " : TypeName='"+TypeName+"'")
EDITED:
EDIT: RT_VarExist just returns result of an Avisynth function, would do equivalent of VarExist on local of that name, and if failed then on Global of that name.
We cant test locals in script within a separate function, you would need to inline script try/catch in-situ if required for local.
EDIT: Something like
    Try {Dummy=Eval(LocalName) LocalExist=True} Catch(msg) {LocalExist=False} # Dummy, avoid assign anything to Last
avisynth, faq
