Old 24th November 2024, 01:33   #1  |  Link
jay123210599
ffmpeg 709 Colors
This is the information for a video I have. If I make a png image sequence out of it using ffmpeg and/or Shutter Encoder, will the images have the 709 colors from the video?
Format                                   : AVC
Format/Info                              : Advanced Video Codec
Format profile                           : High@L4.1
Format settings                          : CABAC / 4 Ref Frames
Format settings, CABAC                   : Yes
Format settings, Reference frames        : 4 frames
Format settings, Slice count             : 4 slices per frame
Codec ID                                 : V_MPEG4/ISO/AVC
Duration                                 : 23 min 43 s
Bit rate mode                            : Variable
Bit rate                                 : 38.7 Mb/s
Maximum bit rate                         : 40.0 Mb/s
Width                                    : 1 920 pixels
Height                                   : 1 080 pixels
Display aspect ratio                     : 16:9
Frame rate mode                          : Constant
Frame rate                               : 23.976 (24000/1001) FPS
Bit depth                                : 8 bits
Scan type                                : Progressive
Bits/(Pixel*Frame)                       : 0.779
Time code of first frame                 : 00:59:59:00
Stream size                              : 6.42 GiB (96%)
Default                                  : No
Forced                                   : No
jay123210599 is offline   Reply With Quote
Old 24th November 2024, 05:37   #2  |  Link
FranceBB
Broadcast Encoder
FranceBB's Avatar
Yes it will, however please note that it will convert the range from Limited TV Range to Full PC Range during the yv12 to rgb24 conversion.
Here's a simple yv12 limited tv range output generated to simulate your source:
ColorBars(848, 480, pixel_type="YV12")
And here's the mediainfo of the corresponding PNG file:
General
Complete name                            : New File 000000.png
Format                                   : PNG
Format/Info                              : Portable Network Graphic
File size                                : 3.54 KiB
Format                                   : PNG
Compression                              : Deflate
Format settings                          : Linear
Width                                    : 848 pixels
Height                                   : 480 pixels
Color space                              : RGB
Bit depth                                : 8 bits
Compression mode                         : Lossless
Stream size                              : 3.54 KiB (100%)
Notice how it has been converted from YV12 to RGB24, so from 4:2:0 8bit to RGB24 8bit.
BT709 is indeed still there and preserved, but given that Studio RGB (i.e RGB Limited TV Range) isn't really a thing outside of broadcast environments, pretty much any software that converts to RGB will make the picture Full PC Range. In the 8bit case we're going from 16-235 to 0-255. As a side note, the reason why Studio RGB is only used in broadcast and isn't really widespread is that SDI cables need some codes to carry stuff like the timecode and other sync codes, so you wouldn't be able to carry the whole 255 values.
Anyway, this can be easily simulated like this:
Converttoyv24(matrix="PC.709")
TurnRight.Histogram.TurnLeft #luma
Crop(0, 0, -0, -480)
Subtitle("Original Video Limited TV Range")
video=last
ImageSource("D:\New File (22)000000.png")
Subtitle("Screenshot Full PC Range")
screenshot=last
StackVertical(video, screenshot)
As you can see, the first one, the original video, never exceeds the 235 top and only ever goes down the 16 bottom in one specific section on the right hand side dedicated to the super black. In other words, it's 8bit limited tv range. On the other hand, the second one, the screenshot, happily hits the 255 ceiling (i.e white) and 0 bottom (i.e black) as it's 8bit full pc range. Again, this kind of conversion is pretty safe and there aren't any issues unless you actually have out of range values (i.e things going above 235 or 0.7V and below 16 or 0.0V) 'cause when your 235 gets mapped to 255 anything above 235 is automatically lost as it can't be mapped above 255. In any case, in a properly graded and encoded limited tv range file there shouldn't be anything going out of range in the first place 'cause every TV is RGB Full PC Range anyway and it would perform the exact same conversion anyway, so any out of range highlight would be clipped out. This is exactly why I always tell all my coworkers to be extremely careful during live events and to always perform soft highlights rollback to dim them and make them fall within the 0.0-0.7V range.
Old 24th November 2024, 05:50   #3  |  Link
poisondeathray
1) It depends on your commandline
2) For a source without colorimetry flags, unless otherwise specified, ffmpeg will use bt601 by default, not 709, for the YUV=>RGB conversion
Old 24th November 2024, 13:22   #4  |  Link
jay123210599
This is the my command line:
So does both ffmpeg and Shutter need colorimetry flag in order to get the 709 colors? What about for making gifs, webps, and apngs?
Old 24th November 2024, 13:42   #5  |  Link
Z2697
You should extract all planes individually and encode them to grayscale PNG. Absolute perfect color retention.
Z2697 is offline   Reply With Quote
Old 24th November 2024, 15:13   #6  |  Link
GeoffreyA
You can try the following and see if it helps:
ffmpeg -colorspace bt709 -color_trc bt709 -color_primaries bt709 -color_range tv -i input.mkv output%d.png
Usually, I set that on all input, file or pipe, because most content is BT.709. If you're using a batch file, use two percentage signs on Windows.
GeoffreyA is offline   Reply With Quote
Old 24th November 2024, 15:42   #7  |  Link
Z2697
I'd rather use zscale
Faster and better.
The only benefit of swscale IMO is it can handle more obscure pixel formats.
Old 24th November 2024, 17:05   #8  |  Link
poisondeathray
Beware the problem with ffmpeg using -colorspace etc..., or with colorimetry tagged files and using png output - is the output png still has gAMA and cHRM tags. This causes the colors to be displayed inconsistently in different programs . A browser may display certain colors, a picture viewer something else. Different source filters can display different colors. A long standing ffmpeg issue with several open tickets and discussion
For untagged files, I would use zscale too. If using swscale, beware it uses a "fast" less accurate conversion unless you use -sws_flags full_chroma_int+accurate_rnd
Old 24th November 2024, 17:51   #9  |  Link
jay123210599
So yes, that and Shutter Encoder need colorimetry flags from videos in order to get the 709 colors? The same goes for making gifs, webps, and apngs?
Old 24th November 2024, 19:44   #10  |  Link
poisondeathray
Not sure, I don't use shutter encoder . It depends on what commands it's passing to ffmpeg, and/or other operations it's performing. Maybe it has some logic that makes assumptions about a given resolution and colorimetry. You can test it.
Old 24th November 2024, 19:50   #11  |  Link
GeoffreyA
Z2697, poisondeathray, I do use zscale for actual conversion or scaling; no contest, it leaves swscale in the dust. However, I found that using those switches before the input merely sets the values for the internal structures, as far as I can tell from the debug log, and doesn't do any conversion (the auto-inserted swscale filter).
Old 25th November 2024, 14:23   #12  |  Link
jay123210599
So what should I do for ffmpeg and Shutter Encoder to get the 709 colors when making images out of this type of video? Leave it as it is or add the flags to the video beforehand or during the conversion?
Old 25th November 2024, 16:20   #13  |  Link
poisondeathray
1) If you leave it as-is, the default YUV to RGB conversion uses Rec601
2) For non colorimetry flagged sources - you control the conversion by specifying the input matrix as 709 using zscale or swscale. Use the sws scale switches mentioned above if you care about less error when using swscale.
eg
-vf zscale=min=709,format=gbrp
3) If you add the colorimetry flags to the source, or for sources with colorimetry flags already present , the ffmpeg PNG's will display incorrect colors in many programs, including browsers (!) - because of gAMA and cHRM tag issue. Other formats like GIF are not affected
Old 25th November 2024, 17:19   #14  |  Link
jay123210599
But why would there be gAMA and cHRM tag issues? So other formats like AVIF, JXL, WEBP, JPG, GIF, and APNG will automatically get the 709 colors, even if the colorimetry flags are not present in the source?
Old 25th November 2024, 19:30   #15  |  Link
poisondeathray
Ask a ffmpeg developer . There are tickets for this already.
The gAMA, cHRM tag issue is specific to PNG . Even if the underlying YUV to RGB conversion in ffmpeg is correct, the PNG can have problems being displayed in programs
The most consistent PNG display is no gAMA, cHRM tags - it essentially displays the same everywhere
It's easy to verify this, if you strip the gAMA, cHRM tags, the PNG now displays correctly in browsers and other programs.
No .
see #2 in the post above "For non colorimetry flagged sources..."
Also point #2 in my first reply "For a source without colorimetry flags, unless otherwise specified,..."
Nothing is guaranteed to be automatically correct in ffmpeg-land. You should always verify your workflow, because there are a bunch of "gotchas"
Jpeg is different because there are YUV variants, subsampled variants, RGB variants. Also, it is supposed to use full range 601 (pc 601) - as per the jpeg spec , not Rec709, not limited range. Common conversions should be handled correctly automatically in ffmpeg already (because jpeg is/was so common, all the bugs have been fixed), but you can test and verify . Obscure input formats might need some other switches for the correct conversion
AVIF isalso different because they have pixel format variations as well, possible different conversions. For example a YUV AVIF wouldn't need any changes to matrix, because the input is YUV. You aren't converting to RGB in that case
Webp lossless is RGB only, but lossy web is YUV. So you have to control the YUV to RGB conversion for lossless webp for the correct colors, otherwise bt601 is used
GIF is actually PAL8 , not sure if the conversion is correct, you have to test
Old 25th November 2024, 20:40   #16  |  Link
SeeMoreDigital
Life's clearer in 4K UHD
SeeMoreDigital's Avatar
Why can't us regular folk create Jpeg 2000 images as used with DCP (Digital Cinema Package)/DCI?
Old 25th November 2024, 22:35   #17  |  Link
hello_hello
Probably mostly due to patents.
https://en.wikipedia.org/wiki/JPEG_2000#Legal_status
Or maybe partly due to obsolescence.
https://en.wikipedia.org/wiki/JPEG_XL
JPEG_XL has a lossless mode. It seems to compare with PNG for compression only it's much slower (unless it's the IrfanView implementation or something peculiar to my setup).
Old 25th November 2024, 22:43   #18  |  Link
poisondeathray
Compression wise JPEG-XL is much better than png at the highest compression levels, but much slower
Here are some compression tests on a single image anime frame (notice the thread starter... he had multiple login handles that all got banned on that site for basically rehashing the same questions over and over... just saying....)
https://forum.videohelp.com/threads/...es#post2722950
Old 25th November 2024, 22:48   #19  |  Link
hello_hello
jay123210599,
SMPlayer can save screenshots of frames as it plays a video as png, webp or jpeg. I haven't messed around with it much but you can increase the playback speed by a fair amount so you shouldn't have to do it in real time. I'd be willing to give SMPlayer the benefit of the doubt in respect to always saving the images with the correct colors. Here's a few jpegs with a section of the rec.709 video they were taken from. Test.zip (6.9 MB)
Old 25th November 2024, 23:02   #20  |  Link
No .
this is not fix by ffmpeg.
even if the meta data is correct programs will interpret them wrong.
one of these is literally the windows picture "app" it will assume that your display is gamma 2.2 so not the same issue where HDR assumes sRGB for SDR sources but similar.
well ffmpeg could fix interpreting bt 1886 as something around 2.0 by using the bt 709 encoding function for what ever reason. i don't hold my breath on that...
stripping is the way to go!
doesn't this work for like 15 years or so:
https://developer.nvidia.com/nvjpeg2...get_os=Windows
i guess i simply don't know about a DCI limitation?
colorspace, ffmpeg, ffmpeg gui, image-quality
