Old 23rd March 2018, 10:45   #1  |  Link
`Orum
DupStep, a duplicate frame detector & decimator (x64 only; alpha)
DupStep is a duplicate frame detector/decimator, currently in an "alpha" state. It was written from scratch by me, and is not based on any other similar filter, though it can emulate some. Although I normally don't release projects this early, I would like the community's help with regard to feedback, testing, and feature suggestions, so I'm making it available now.
Currently the project is only available for download via the attachment in this post.
Keep in mind I'm actively developing it and as it's still in alpha, thus many things are subject to big changes. Right now my priorities for upcoming releases are:
High priority:
- SSIM-based metric support
- Reduction kernel instead of atomics
- Frame prefetching for initial pass
- Linux support (probably via wine)
- Greatly improving the displayed information in the overlay (the 'show' parameter)
- Improve the dsstats.pl script to allow parameter input and computed stat output (currently only displays intermediate stats)
Medium priority:
- Cumulative error reduction
- Adding range-limiting support (Note: This is not the same as duplicate limiting!)
- RGB support
- VFR input
Low priority:
- 32-bit floating point color space support
- Dynamic threshold support
- Adding frame type support (see 'ptp' parameter) to other source filters (e.g. LSMASH, DSS2?)
Last but not least, the relevant links:
  • URLs for binary releases & code are unavailable while I work on new hosting for the project, sorry.
  • The post regarding the current release.
My filters: DupStep | PointSize
`Orum is offline   Reply With Quote
Old 23rd March 2018, 15:25   #2  |  Link
DJATOM
DJATOM's Avatar
Interesting. I wonder if it can be used to make VFR from QTGMC 60p output, since Tdecimate doesn't support 60p sections at mode 5. Anyway thanks for your efforts, will check it later.
Me on GitHub
PC Specs: Ryzen 5950X, 64 GB RAM, RTX 2070
DJATOM is offline   Reply With Quote
Old 2nd April 2018, 21:33   #3  |  Link
`Orum
v0.02
New release, with numerous bug fixes. Full changelog:
v0.02
Speed: OpenCL is now used for metric calculation, allowing for multi-threading on a CPU or using
  a GPU instead
Speed: All frames read during cache generation are now cached on the OpenCL device so they are
  only requested once from AviSynth
Added: New function "DS_dumpocl()" to list OpenCL platforms and devices with index
Param: Added parameters 'oclpi' and 'ocldi'
Param: Default 'cdepth' changed from 2 to 5
Param: Maximum value of 'cdepth' changed from 10 to 250
Param: dsstats.pl now features additional parameters; run "dsstats.pl -h" for information
Fixed: SSD metrics could be incorrect (lower than they should be) for 16-bit video
Fixed: Cache depth promotion was not working in some cases (affected ifmcm modes 1 & 2)
Fixed: Frame type cache was leaking a small amount of memory
Fixed: Cache was delivering incorrect frame deltas when within a radius of 'cdepth' of the final
  video frame, sometimes reading outside of buffer memory (undefined values)
Fixed: Cache had incorrect frame types when cdepth > 1
Other: Documentation updated regarding when 'ptp' should be disabled, and detailed new concerns
  regarding device memory usage during cache generation
Other: dsstats.pl now validates cache version
Other: Minor refactoring
It's also a little bit faster than the previous release when it comes to generating metrics:
Finally, if you're willing to test, please let me know if you get the same cache file data between the previous release and the current one, keeping the following in mind:
  • Set 'cdepth' to the same value on each release to make the comparison easier. Note that the default value of this parameter has changed.
  • Comparisons should be done with the dsstats.pl from v0.02 using metric-only dumping (-m). Redirect the output from each release to a csv file (e.g. "dsstats.pl -m -s v0.01.dsd > v0.01.csv") and see if they are identical for both releases.
  • Alternatively, if you don't want to install perl, either use a source filter other than FFVideoSource() or set cdepth=1 and compare the files directly (e.g. via a hashing algorithm or a bit-for-bit comparison)
  • 16-bit comparisons between v0.01 and v0.02 aren't valid, as v0.01 would generate incorrect metric results for 16-bit video in some circumstances. All other supported depths shouldn't have the problem.
I'm particularly interested to know if the results match between the two if you generate the cache on v0.02 using an AMD GPU. I have not tested DupStep with an AMD GPU as I don't have access to one at the moment.
Old 22nd April 2018, 13:03   #4  |  Link
`Orum
v0.03
Version 0.03 is released, the big changes being:
  • Completely dynamic cache depth, eliminating the 'cdepth' parameter as well as the hybrid 'ifmcm' modes. Now 'ifmcm' should almost always be set to '0' (the new default) which should give the best quality while being slower than the other modes only when changing parameters (and probably only slightly so at that, as metrics are now reused whenever possible).
  • The addition of block-based metrics, which are very useful in detecting slow fades of static images. SSBD (a block metric) is the new default metric.
  • New 'pco' parameter gives control of how planes are combined when using both luma and chroma.
  • Better default value for 'Cweight' parameter.
The full changelog for this release:
v0.03
Speed: Cache depth is now dynamic and generates/caches only what is needed for the current
  parameters/video
Speed: Cache data from file is always used when available and only recalculated when necessary
  (exception: changing block size recalculates all metrics)
Speed: OpenCL kernel should now be able to take advantage of SIMD instructions for platforms
  that support them
Speed: Avoids unnecessary memory copying when executing OpenCL kernels on a CPU
Added: New function "DS_cachefp()" to cache only frame priorities, allowing 'ptp' to be used
  even when (spatio)temporal filtering is used prior to metric generation
Param: Removed the 'cdepth' parameter as cache depth is dynamic on a per-frame basis now
Param: 'ifmcm' modes 1 and 2 removed and replaced by former modes 3 & 4
Param: Default mode for 'ifmcm' set to 0 (direct)
Param: Removed "raw" metrics (RSAD/RSSD)
Param: New 'metric' settings for block-based metrics
Param: Reordered the 'metric' settings to put squared metrics at lower values than their
  absolute counterparts
Param: Default 'metric' now set to SSBD (2)
Param: Automatic (negative) 'Cweight' uses new values based on empirical data, and no longer
  considers chroma subsampling factor as a factor
Param: New parameter 'pco' to set the plane combination operation
Param: Added 'blksize' parameter to set the block size for block metrics
Param: Added new option to prefer CPU to 'oclpi'; subtract 1 from old options if < -1 to get the
  equivalent new option index for them
Param: Default for 'oclpi' is now set to prefer CPU (-2)
Param: Reordered the parameters
Fixed: Potential overflow when calculating chroma metrics has been fixed
Fixed: A potential race condition that could lead to incorrect results was resolved
Fixed: Corrected a typo in dsstats.pl help (-h)
Fixed: Multiple known issues from v0.02 resolved
Other: Metrics are now all stored as floating point values, pre-normalized to resolution where
  appropriate (previously they were post-normalized, which could cause problems when resolution
  changed between cache generation and usage)
Other: Pixel metrics (SSPD/PAD) are no longer clamped after being scaled by chroma weighting,
  permitting more aggressive chroma weighting
Other: Version bump for cache file; there is no compatibility with caches from older versions
Other: OpenCL device memory usage reduced as it only ever needs to hold the two compared frames
Other: DS_dumpocl() now displays OpenCL version supported (both for platforms and devices)
Other: Significant refactoring
Old 1st May 2018, 15:57   #5  |  Link
leoenc
I'm getting an access violation exception when running the following script:
FFvideoSource("MVS000019427.mxf").ConvertToYUV420()
DupStep()
I tried with ocldi=1 but getting:
"DupStep: Requested device index out of range" even though I see it listed when running DS_dumpocl():
AVSMeter 2.4.7 (x64) - Copyright (c) 2012-2017, Groucho2004
AviSynth+ 0.1 (r2664, MT, x86_64) (0.1.0.0)
oclpi: 0 - ver: OpenCL 1.2 CUDA 9.1.84 - NVIDIA CUDA
ocldi: 0 - ver: OpenCL 1.2 CUDA - GeForce GTX 980 Ti
ocldi: 1 - ver: OpenCL 1.2 CUDA - GeForce GTX 780
oclpi: 1 - ver: OpenCL 1.2  - Intel(R) OpenCL
ocldi: 0 - ver: OpenCL 1.2 (Build 63463) - Intel(R) Core(TM) i7-6700K CPU @ 4.00GHz
Let me know if you need more information.
leoenc is offline   Reply With Quote
Old 2nd May 2018, 09:35   #6  |  Link
leoenc
Fixed by using DupStep(oclpi=-4).
Old 2nd May 2018, 09:58   #7  |  Link
leoenc
@`Orum,
What is the proper way to get a list of all the duplicated frames?
After running DubStep() and getting the dupstep.dsd file I ran:
perl dsstats.pl -s dupstep.dsd >stats.txt
Not sure how to decipher the data there to know which frames were considered duplicates.
Old 4th May 2018, 21:46   #8  |  Link
`Orum
Just a note on this, you should always set oclpi to a non-negative value when setting ocldi. While I mention this in the readme, I neglected to mention that it should be non-negative. I'll have an updated readme in the next release.
Specifically, in your case, it's due to the Intel CPU not supporting OpenCL atomics, but your nVidia GPU does. So just using oclpi=-4 (or -3) and not specifying ocldi is probably the best way to handle it (unless you really want it to run on your 780 instead of your 980, in which case I recommend setting both oclpi=0 and ocldi=1). The next release will be using a reduction kernel instead of atomics and should run on Intel CPUs/GPUs without issue.
@`Orum,
This is a bit complicated, because there's actually several ways to do this, but I'll focus on the simpler method. But before I get into that, I recommend you instead redirect the output to a ".csv" file instead of ".txt", and that you open the CSV file in a spreadsheet application, e.g. MS Excel or LibreOffice Calc. You may also want to dump only metrics (and not the priority cache) by using -m, e.g. "dsstats.pl -ms dupstep.dsd" (note: "-s dupstep.dsd" isn't necessary here as that's the default file if unspecified). Lastly, keep in mind the following assumes two things: you are using the current release, v0.03, and you are using ifmcm=0 (the default in v0.03).
Now, if you have not modified DupStep's parameters since the cache file was created, it's actually relatively simple to figure out. The first column is the frame number of the "earlier" or base frame in the comparison (i.e. the frame with the lower frame number), and the second column is the "delta" or forward distance from this frame that the metric is calculated from. If you add this delta to the first frame number, you'll get the frame number that the frame is compared to. For example (remember right now we're only looking at the first two columns, and for the sake of formatting for this forum I'll be using CSV format):
  • 0,1 - This means frame 0 is being compared to frame 1 (0+1=1). This will always be the first metric of any file, as DupStep always begins by comparing the first frame (frame 0) to the second frame (frame 1)
  • 37,8 - Frame 37 is being compared to frame 45 (37+8=45)
  • x,y - Abstracting this, frame x is being compared to frame (x+y)
So, how does this tell you what frames are being decimated? Well, in v0.03, DupStep only generates metrics as needed, which means it will keep increasing the delta until it exceeds the threshold. For example, consider the following output (again, only looking at the first two columns) from some of the test footage I run through DupStep:
frame,delta
0,1
1,1
1,2
3,1
3,2
5,1
5,2
7,1
7,2
9,1
9,2
11,1
Here, you'll see the first metric stored in the cache is 0,1, followed by 1,1. Any time the first number (the base frame number) changes, that means that the threshold was exceeded and the frame is not a duplicate. So, in this case, it means frame 1 was not a duplicate of frame 0.
However, look at the next two deltas: 1,1 followed by 1,2. This means that when comparing frame 1 to frame 2 (1+1), frame 2 was detected as a duplicate, because it then went on to calculate metrics between fame 1 and frame 3 (1+2).
Then it jumps to frame 3 as the base frame, because it discovered that frame 3 was not a duplicate of frame 1. So, in short, if you look at all the unique numbers of the base frames, you'll find almost all the frames that are non-duplicates, or in this case: frames 0, 1, 3, 5, 7, 9 and 11. The duplicate frames are almost everything else, or 2, 4, 6, 8, and 10 in this case. (Note, however, the frames returned by DupStep may not actually be those particular frame numbers if you have ptp=true (the default), as it tries to find the "highest quality" frame from a range of duplicates.)
Why almost, and what about frame 12? Well, this method will not tell you if the final frame is a duplicate or not, but it's much simpler as you don't need to do any math regarding the metrics. It does, however, require that you have not modified DupStep's parameters, as it does not delete metrics that are no longer used when you change the parameters, for performance reasons (otherwise they'd have to be recalculated if you reverted your change to the parameters).
If you're asking, "Well, how do I get the duplicates even if I change the parameters without deleting the cache, and how do I find out if the last frame is a duplicate?" the short answer is "You can using the numbers in the columns following the frame/delta columns, but it's complicated." While the math itself is relatively simple, it depends on parameters including your threshold, and if you're using an automatic threshold (i.e. negative) like I recommend, the calculation of the threshold itself is based on numerous other parameters.
In short, I recommend just waiting for a later release, as adding in display of the metrics within the video (the "show" parameter) is one of my high priority items. It probably won't be available next release, as I am focusing on getting SSIM metrics and a reduction kernel for that, but I am planning on them being in v0.05. Also, at some point in the future (probably with v0.05) I'll be adding in the capability to input your DupStep() parameters into dsstats.pl and have it spit out more useful information when you do.
Edit: You can also set show=1 to see which frame DupStep is returning from the footage you're giving it, and this method will work even if you change the parameters. However, if you want to get the range of duplicates, it's best to set ptp=false as well so it will always return the first frame of the range, and then by moving forward/backward one frame in its output, you can calculate which frames are duplicates.
Old 3rd June 2020, 08:45   #9  |  Link
bruno321
Thanks for developing this.
I notice the OpenCL requirement, and currently I can't run the script, "unable to find opencl program source".
What am I supposed to install, exactly?
bruno321 is offline   Reply With Quote
Old 6th June 2020, 22:25   #10  |  Link
`Orum
You need devices, drivers, and runtimes that support OpenCL 1.2 or later (1.1 or earlier may work, though I'd have to look through and check the code, and it's completely untested in a pre-1.2 environment). As what you need to install for this depends on your hardware, you're probably best off just googling, e.g. "nvidia opencl" or "intel opencl" (don't use the quotes when searching). For example, the runtimes you need for the latter are here.
Once installed you can list the available devices with DS_dumpocl(). If that fails, or there's nothing there, then you might want to try some further debugging with clinfo. Note that I am in no way involved in the clinfo project and can't offer support for it or vouch for anything beyond its existence.
Old 7th June 2020, 06:20   #11  |  Link
bruno321
I've an AMD Ryzen 3 3200G with integrated Radeon Vega 8 graphics. I installed the latest AMD Ryzen drivers. I'm getting the same problem. Here's what DS_Dumpocl() gives:
Dunno what else to install, I googled but didn't find anything too clear.
EDIT: Here's the clinfo output https://pastebin.com/qt38L9kn
Old 18th June 2020, 11:41   #12  |  Link
`Orum
Sorry for the late reply. Your graphics card is showing up as a device, so it should be working. Can you show me what all the parameters you're using with DupStep() are?
Additionally, where did you extract it to? Assuming you installed AviSynth+ to "C:\Program Files\AviSynth+", it should be in "C:\Program Files\AviSynth+\plugins64+". Also, make sure you extracted the "dskern" directory (and the files inside it, i.e. keep the same directory structure as it is in the archive) there as well, as it will not run without that.
Old 19th June 2020, 09:54   #13  |  Link
bruno321
That was my problem, thanks.
Old 20th June 2020, 10:37   #14  |  Link
`Orum
I'll compile the kernels inside the DLL in the future, so that it's easier to install. Might not happen in the next version (which is close to release), but if not then the version after it.
Old 27th December 2020, 21:29   #15  |  Link
fozter
Out of nowhere i cant use dupstep anymore, im getting these errors: "Enqueuing OpenCL read buffer failed" and "Creating OpenCL context failed"
I've read earlier post in this forum regarding drivers etc, but none of that seems to work for my part.
My line looks like this DupStep(oclpi=-4, thresh=-2.9) and i use a i7 4790k and a gtx 1070.
EDIT: Here is my output with DS_Dumpocl()
fozter is offline   Reply With Quote
dedup, deduplicate, duplicate, vfr
