Old 26th March 2017, 10:55   #1  |  Link
Faiakes
madVR + Image Downscaling + DXVA2 = Only blue and black colours on video
As the title says:
Win10, x64, build 15063
Nvidia Driver 378.78
MadVR settings:
Image Downscaling = DXVA2 (all other options play fine)
File = 2160p downscaling to 1440p
General
Unique ID                   : 206732627496310403037341376730639651890 (0x9B87417AA5B6EE65233568BDC9B05432)
Complete name               : D:\Downloads\Fleabag S01E01 (2160p x265 10bit Joy).mkv
Format                      : Matroska
Format version              : Version 4 / Version 2
File size                   : 10.8 MiB
Duration                    : 28 s 920 ms
Overall bit rate            : 3 120 kb/s
Writing application         : Lavf57.25.100
Writing library             : Lavf57.25.100 / Lavf57.25.100
Video
Format                      : HEVC
Format/Info                 : High Efficiency Video Coding
Format profile              : Main 10@L5@Main
Codec ID                    : V_MPEGH/ISO/HEVC
Width                       : 3 840 pixels
Height                      : 1 604 pixels
Display aspect ratio        : 2.40:1
Frame rate mode             : Constant
Frame rate                  : 25.000 FPS
Color space                 : YUV
Chroma subsampling          : 4:2:0
Bit depth                   : 10 bits
Writing library             : x265 1.9+3-63308f7658c3:[Windows][GCC 5.2.0][64 bit] 10bit
Encoding settings           : wpp / ctu=64 / min-cu-size=8 / max-tu-size=32 / tu-intra-depth=1 / tu-inter-depth=1 / me=1 / subme=2 / merange=57 / no-rect / no-amp / max-merge=2 / temporal-mvp / no-early-skip / rdpenalty=0 / no-tskip / no-tskip-fast / strong-intra-smoothing / no-lossless / no-cu-lossless / no-constrained-intra / no-fast-intra / open-gop / no-temporal-layers / interlace=0 / keyint=250 / min-keyint=25 / scenecut=40 / rc-lookahead=20 / lookahead-slices=8 / bframes=4 / bframe-bias=0 / b-adapt=2 / ref=3 / limit-refs=3 / no-limit-modes / weightp / no-weightb / aq-mode=1 / qg-size=32 / aq-strength=1.00 / cbqpoffs=0 / crqpoffs=0 / rd=3 / psy-rd=2.00 / rdoq-level=0 / psy-rdoq=0.00 / signhide / deblock / sao / no-sao-non-deblock / b-pyramid / cutree / no-intra-refresh / rc=2 / pass / bitrate=4000 / qcomp=0.60 / qpmin=0 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ipratio=1.40 / pbratio=1.30
Default                     : Yes
Forced                      : No
Color range                 : Limited
Color primaries             : BT.709
Transfer characteristics    : BT.709
Matrix coefficients         : BT.709
DURATION                    : 00:00:28.920000000
Audio
Format                      : AAC
Format/Info                 : Advanced Audio Codec
Format profile              : HE-AAC / LC
Codec ID                    : A_AAC
Channel(s)                  : 6 channels
Channel(s)_Original         : 23 channels
Channel positions           : Front: 9, Side: 4, Back: 10
Sampling rate               : 48.0 kHz / 24.0 kHz
Frame rate                  : 23.438 FPS (1024 spf)
Compression mode            : Lossy
Delay relative to video     : -84 ms
Language                    : English
Default                     : Yes
Forced                      : No
DURATION                    : 00:00:28.836000000
Faiakes is offline   Reply With Quote
color, downscaling, x265
