Old 29th August 2016, 12:58   #1  |  Link
magiblot
Eurobeat Fan
Irregular scrolling in IVTC'ed video (anime)
Hi. I'm trying to rip an anime movie from a PAL DVD. As expected, the source video runs at 25 fps and is interlaced. I have used this script to return the footage to 23.976 fps and deinterlace:
mpeg2source("VTS_04_1.d2v")
AnimeIVTC(mode=2, bbob=4, edimode="EEDI3", normconv=true)
(QTGMC is very slow, so I just use it for encoding. For previewing, i use AnimeIVTC(mode=2, normconv=true).)
The result looks pretty well, except for two things:
* Very little ghosting, usually in the first frame after a scene change.
* Irregular motion in scrolling scenes:
This second problem is what bothers me the most, but I don't know how to fix it, because I'm still new to inverse telecining.
For what I have seen, the cause of this could be the source. Motion in those scenes doesn't look irregular, but it can be observed that frames get blurry intermittently (in the original VOB files).
I have uploaded a sample of the source for you to be able to give a look at it:
https://mega.nz/#!Y8E1zJqa!K3SmYp5g6...VSvIUuNxZyfkqU
I would be grateful if you could give me a hand with this, as I still don't have the knowledge and experience enough to fix it on my own.
Thank you!
magiblot is offline   Reply With Quote
Old 29th August 2016, 16:10   #2  |  Link
TheFluff
Excessively jovial fellow
I will repeat to you the first encoding advice I ever got, when I asked a very similar question over a decade ago. The words are burned into my memory even today:
1. Locate trashcan
2. Place DVD in trashcan
3. Order NTSC equivalent
It was good advice then, and it is good advice now (except these days there's usually a bluray you can get instead). There is really no reason spending inordinate amounts of work on trying to improve hopelessly ruined sources when there are better alternatives easily available on the market.
Also, the style of advice so influenced me that I'm still trying to live up to the spirit of it even today.
Old 29th August 2016, 16:54   #3  |  Link
real.finder
sanimebob()
srestore(29,970)
for motion, because the original was 30 or 60 in it
and NTSC DVD will be better for you as TheFluff said
My Avisynth Stuff
Old 29th August 2016, 17:43   #4  |  Link
magiblot
Eurobeat Fan
Thanks TheFluff for your advise. However, if I intend to make a new rip of this movie, I have no other choice than using this PAL source as of now: I can't find an uploaded ISO of the NTSC release (which means I am not going to pay for more material).
There are some other rips avaiable, but as I have stated in my first post, I still have little knowledge about inverse telecining, and therefore this project is useful to me because I can learn from it. I have two options:
* Keep believing that inverse telecine can be performed just by tweaking Anime_IVTC parameters, and in case it doesn't work, blame the source.
* Ask the doom9 guys and see what they come up with. Then, understand why their methods are effective against the problem and get an idea of how the whole thing works. Later, I will be able to solve similar problems on my own and tell others how it's done.
Still, I can understand that in this case the most reasonable solution would be getting an NTSC source. In fact, I already have another rip that will probably look better. But my main purpose is to learn, because I believe in Avisynth potential, and I want to know how far I can go with it.
And thanks real.finder for your suggestion. I'll give it a try in a moment.
EDIT: Where do I get sanimebob() from? I am already using the version of Anime_IVTC linked in your signature, I think.
Old 29th August 2016, 18:01   #5  |  Link
real.finder
sanimebob()
My Avisynth Stuff
Old 29th August 2016, 19:33   #6  |  Link
magiblot
Eurobeat Fan
Originally Posted by real.finder View Post
sanimebob()
srestore(29,970)
Oh, you're right! It is fixed now! Then, I guess the problem is that my source comes from a NTSC version and not from the original master. That's why it's a bad source.
By the way, let me ask something not related to IVTC: is there any Avisynth filter that causes this effect?:
Old 29th August 2016, 19:47   #7  |  Link
TheFluff
don't go there, that shit looks like a circa 2005 anime dvd rip that was way overfiltered by some teenager who thought the warpsharp look was awesome
those who cannot remember the past are condemned to repeat it
Old 29th August 2016, 20:34   #8  |  Link
Motenai Yoda
Motenai Yoda's Avatar
why no mention the blinddehalo3 too?
powered by Google Translator
Motenai Yoda is offline   Reply With Quote
Old 29th August 2016, 21:37   #9  |  Link
magiblot
Eurobeat Fan
Yeah it does, right? Then you'll be pleased to discover (but not as much as the fans of the anime) that the picture at top right position is a snapshot of the Blu Ray release!
https://www.youtube.com/watch?v=CBukrYgCT1Q
Then we realized that the masters of that season were allegedly lost...
Old 29th August 2016, 21:52   #10  |  Link
real.finder
the "teenager" now work for some usa BD Companies for anime
they did same thing in death note BD
My Avisynth Stuff
anime, anime_ivtc, avisynth, ivtc, pal
