Old 28th August 2016, 11:25   #1  |  Link
EruPii
Chroma bug in anime
Hello,
I have an anime DVD source which looks like interlaced video but it's not. The problem is the same as in this archived thread: http://forum.doom9.org/showthread.php?t=163937. I tried the code Didée wrote in it but didn't help (after encoding the source the result will be crappy with only chroma frames).
I bobbed the source and saw that the chroma is swapped between frames. Can't we solve the problem somehow if we Bob it or use SeparateFields, swap the chroma of the frames and use Weave or change the frame rate back to 29.970 fps in any other way?
I attached wrong frames from the bobbed source. Also, the source can be downloaded here: https://mega.nz/#!cc53iYCb!rg_42zzJw...NnEFtQK2HpG4co
Thank you for your answer in advance.
EruPii is offline   Reply With Quote
Old 28th August 2016, 15:59   #2  |  Link
real.finder
try this
orig = last
sanimebob()
chroma_rep()
getparity(orig) ? interlaced60or50 : interlaced60or50(bff=true)
My Avisynth Stuff
Old 28th August 2016, 22:11   #3  |  Link
ChiDragon
ChiDragon's Avatar
You should've cut a sample using DGIndex or another tool instead of posting the entire 800MB episode.
The problem is that they took the hard-telecined source and encoded it in progressive mode, BTW:
Format                         : MPEG-PS
File size                      : 842 MiB
Duration                       : 23mn 25s
Overall bit rate mode          : Variable
Overall bit rate               : 5 024 Kbps
Video
Format                         : MPEG Video
Format version                 : Version 2
Format profile                 : Main@Main
Format settings, BVOP          : Yes
Format settings, Matrix        : Custom
Format settings, GOP           : Variable
Duration                       : 23mn 25s
Bit rate mode                  : Variable
Bit rate                       : 4 700 Kbps
Maximum bit rate               : 9 800 Kbps
Width                          : 720 pixels
Height                         : 480 pixels
Display aspect ratio           : 4:3
Frame rate                     : 29.970 fps
Standard                       : NTSC
Color space                    : YUV
Chroma subsampling             : 4:2:0
Bit depth                      : 8 bits
Scan type                      : Progressive
Scan order                     : Top Field First
Compression mode               : Lossy
Bits/(Pixel*Frame)             : 0.454
Time code of first frame       : 00:00:00:00
Time code source               : Group of pictures header
GOP, Open/Closed               : Open
GOP, Open/Closed of first fram : Closed
Stream size                    : 788 MiB (94%)
ChiDragon is offline   Reply With Quote
Old 29th August 2016, 17:05   #4  |  Link
FranceBB
FranceBB
FranceBB's Avatar
@chidragon... exactly.
Interlaced source encoded as progressive, with the chroma expanded between fields. There isn't much you can do to fix it...
Old 29th August 2016, 21:46   #5  |  Link
real.finder
this code can (in most frames)
MPEG2Source("hhws_ep37.d2v")
orig = last
sanimebob()
chroma_rep(10)
FrameCache(10)
# next lines from http://forum.doom9.org/showpost.php?...50&postcount=6 with some edit
luma   = AnimeIVTC(1,chroma=false,mchroma=false,o3025cfr=true)
chroma = vinverse().Srestore(omode="PP3", cache=10)
# manual sync: figure out which frame (previous,current aka p,c) of 'chroma' clip is most similar to current frame of 'luma' clip
# 46*log(|x-y|+1) uses the full [0,255]-range and scales little differences better than |x-y|*2
diffp = mt_lutxy(luma,chroma.selectevery(1,-1),"x y - abs 1 + log 46 *")
diffc = mt_lutxy(luma,chroma,                  "x y - abs 1 + log 46 *")
# average difference between compared frames
mp = mt_lutf(diffp,diffp,"avg",expr="x")
mc = mt_lutf(diffc,diffc,"avg",expr="x")
# build conditional masks based on the caculated comparisons
maskp = mt_lutxy(mp,mc,"x y < 255 0 ?")
# finally merge the luma of the tfm with the chroma of the srestore clip accordingly to the binary mask
mt_merge(luma,chroma.selectevery(1,-1),maskp,luma=true,Y=2,U=3,V=3)
tdecimate(1)
smam(filter=daa3mod())
The result http://www.solidfiles.com/v/RqQ2WmWMLq3Gk
My Avisynth Stuff
Old 31st August 2016, 11:57   #6  |  Link
EruPii
Yup, I know my source sucks much a**, but it's my only source.
Thanks real.finder, I'll try your code as soon as I can.
Old 16th September 2016, 23:06   #7  |  Link
EruPii
It's almost good, the problem is that I get these kind of frames in part of the video. Maybe chroma_rep doesn't work fully correctly. Does somebody have some kind of solution for this? Thank you for your reply in advance.
Old 16th September 2016, 23:25   #8  |  Link
GMJCZP
GMJCZP's Avatar
Try this: Here
By law and justice!
Flea Market
GMJCZP is offline   Reply With Quote
Old 17th September 2016, 10:21   #9  |  Link
EruPii
I'm using that script real.finder pasted here which contains the script you linked here. My problem is with this code block:
orig = last
sanimebob()
chroma_rep(10)
FrameCache(10)
I think the function in bold characters might not work correctly, even with its default parameter values. When I commented it out, that frame was correct, but some frames directly after scene changes were wrong.
Old 18th September 2016, 01:47   #10  |  Link
real.finder
orig = last
sanimebob()
chroma_rep(10)
FrameCache(10)
yes, it will not work in 60i, it work only in pure Telecine
that why I add other code in bottom
My Avisynth Stuff
Old 18th September 2016, 21:06   #11  |  Link
EruPii
Oh, thanks. But could you tell me where I can get "Hqdn3dY"? I googled it but I got no download links.
Old 18th September 2016, 21:14   #12  |  Link
Dont know about hqdn3dY (The Y is unknown to me), but Hqdn3d can be found here:- http://avisynth.nl/index.php/Externa...oral_Denoisers
EDIT: I dont see hqdn3d in this thread anyway (apart from your prev post [with/without the Y]).
"Some infinities are bigger than other infinities", but are any of them infinitely bigger ???
Old 18th September 2016, 22:17   #13  |  Link
EruPii
This line needs hqdnd3dy:
smam(filter="daa3mod()")
Old 19th September 2016, 06:22   #14  |  Link
real.finder
http://web.archive.org/web/201602211...ins/Hqdn3dY.7z
but it's not the last one but work here
My Avisynth Stuff
Old 19th September 2016, 07:49   #15  |  Link
EruPii
Thanks!
Old 21st September 2016, 12:24   #16  |  Link
real.finder
I upload the last one I have in Attachments
My Avisynth Stuff
Old 22nd September 2016, 15:48   #17  |  Link
EruPii
Thanks. I put the line
into the script, but when I try to pan or encode the source Avisynth returns with an error: RequestLinear: internal error (frame not cached)! after some frames. What can I do against it?
Old 22nd September 2016, 16:30   #18  |  Link
real.finder
this should not happened since I add FrameCache(10)
anyway this is normal http://forum.doom9.org/showpost.php?...1&postcount=81
My Avisynth Stuff
anime, chroma, chroma bug, dvd
