Old 22nd August 2016, 20:32   #1  |  Link
DenKudo
IVTC Problem
Hello!
I'm trying to backup - encode some of my anime and I'm having difficulties with IVTC processing. It's a hybrid anime with OP and ED progressive 29.97 and everything else is hard telecined with some postprocessing effects. I decided to encode OP and ED separately, so that's not a huge problem. I'm just having difficulties with IVTC. I've tried many scripts, but none of them work smoothly - there is some "shimmering" motion on panning and the annoying "mouth flaps". Here is a sample clip of the footage: https://mega.nz/#!TZl3gSTY!Lqf-VVor6...kYdR0y5-j8NSBQ
I've used TFM().Tdecimate() but there are still a lot of interlaced frames left, which is especially annoying on panning. I've fiddled with the settings but to no avail. I've even tried Anime IVTC but got nowhere. YATTA is very time consuming so I would rather use a script.
Interesting thing is that VLC player plays the file just fine with no noticable artifacts (with internal IVTC), so i'm curious about the algorithm used in VLC.
Well, if you have any suggestions I would be happy and grateful to hear them
DenKudo is offline   Reply With Quote
Old 23rd August 2016, 01:54   #2  |  Link
burfadel
Have you tried the latest yadifmod2?
Old 23rd August 2016, 02:24   #3  |  Link
Sparktank
47.952fps@71.928Hz
Sparktank's Avatar
yadifmod2
http://forum.doom9.org/showthread.php?t=173316
Win10 (x64) build 19041
NTSC | DVD: R1 | BD: A
AMD Ryzen 5 2600 @3.4GHz (6c/12th, I'm on AVX2 now!)
Old 24th August 2016, 08:55   #4  |  Link
manono
With a simple:
TFM().TDecimate(Mode=1)
I found no problems. Some aliasing (maybe the 'shimmering' you mentioned) but no IVTC problems. Have you checked the sample, or is the episode itself having the problem? The reason I ask is that maybe you changed the field order when separating out the beginning and ending and you should add an AssumeTFF/BFF.
Old 24th August 2016, 12:51   #5  |  Link
DenKudo
Originally Posted by manono View Post
With a simple:
The problem is not limited to the sample and it persists through the whole episode. As I mentioned, when I play the sample or the whole VTS in VLC with IVTC enabled, the "shimmering" is gone and I don't think VLC has antialising filter automatically enabled in its core IVTC.
Manono, is this what you call aliasing? https://mega.nz/#!7YdGQIDT!Ht893hgh-...B9oxhpuijZbOsQ
Simple TFM + tdecimate and AAA doesn't get rid of it.
Old 24th August 2016, 12:57   #6  |  Link
DenKudo
Yadifmod also doesn't get rid of the issue, I'm using this script:
clip1=last.nnedi2()
dt=last.yadifmod2(edeint=clip1)
TFM(clip2=dt,pp=3)
TDecimate(mode=1)
Old 24th August 2016, 18:02   #7  |  Link
FranceBB
Broadcast Encoder
FranceBB's Avatar
tfm(mode=1,pp=5,slow=2,micmatching=2,clip2=tdeint(mode=2,type=3))
tdecimate()
Old 24th August 2016, 19:26   #8  |  Link
DenKudo
tdecimate()
I tried that also, but it still doesn't work. The output is not smooth, just look at the panning scene with the teacher, when the students raise their hands - the faulty frames still persist (example frame is in my previous post).
Any other suggestions?
Old 24th August 2016, 20:14   #9  |  Link
manono
I don't know what the picture is showing. I don't know what VLC Player does as I don't use it.
You stated in your opening post there was interlacing left after the IVTC and that is simply not true. See if you like this any better, but since I don't understand your problem (except for some aliasing), I don't know if this helps.
QTGMC()
BlendBob()
TDecimate(Mode=1)
https://www.dropbox.com/s/zndxk804kh...Test2.mp4?dl=0
Old 24th August 2016, 21:20   #10  |  Link
DenKudo
QTGMC()
BlendBob()
TDecimate(Mode=1)
Since I know this anime is older and butchered with postprocessing I don't know if it's actually possible to perfectly restore it to 23.976 fps. I was just trying to say that only tfm+tdecimate is probably not enough, that's all.
I'm aware of the script you posted with QTGMC and it does work to some extent, but it introduces some interpolated/blended frames and is pretty slow, but thank you nonetheless. I just stated that VLC does IVTC on the fly and is amazing for this source, while I haven't found an avisynth script that does the same and I wonder if it actually can be done.
Old 24th August 2016, 22:51   #11  |  Link
real.finder
I didn't see the sample yet, but I have sanimebob you can try it
edit: I see it now, the panning move in 60i (I think)
try this
AnimeIVTC(1,0,5, ediandnn=3, repwithtdeint=true, tfmm=0, micmatching=0, o3025cfr=true).TDecimate(1)
smam()
edit: about vlc and IVTC, in frame by frame I see the same artifact in just using tfm in avs, maybe you use post processing in vlc? but in real time play seems fine
See My Avisynth Stuff
Old 25th August 2016, 08:32   #12  |  Link
kuchikirukia
qtgmc(inputtype=1) will take care of the pan. It will cause ghosting and kill small movements elsewhere, though, so only use it where you need it.
kuchikirukia is offline   Reply With Quote
Old 25th August 2016, 16:08   #13  |  Link
DenKudo
Thank you for all the suggestions, but none of the scripts work. I officialy am over this butchered anime
Old 25th August 2016, 20:31   #14  |  Link
real.finder
this is not work? http://rgho.st/private/7wZtrymrf/f2f...fa5dcd97da9b8a
Old 26th August 2016, 18:34   #15  |  Link
DenKudo
Originally Posted by real.finder View Post
I get a lot of errors with that script, do you know what could be wrong?
I get this message: Script error: AnimeIVTC does not have a named argument "ediandnn"
If I delete that and turn it into AnimeIVTC (mode=1) I get this error:
Script error: QTGMC does not have a named argument "lsb"
Any help?
Old 26th August 2016, 18:43   #16  |  Link
http://avisynth.nl/index.php/AnimeIVTC
II) Function descriptions
General settings
Interlaced or progressive credits
Mode=1 (Hard telecined)
Mode=2 (Field-blended)
Mode=3 (Double hard telecined)
hybrid Mode=4 (Hybrid)
AnimeIVTC (clip i, int "mode", int "aa", int "precision", int "killcomb", int "cache", bool "ifade", float "sfthr"*, bool "sfshow"* , bool "chrfix" , bool "blend" , bool "normconv" , int "pattern" , int "pass", bool "rendering" , int "bbob", int "cbob", string "edimode", int "degrain", int "omode" , int "cthresh"* , int "blockx"* , int "blocky"* , int "MI"* , int "tfmm"* , int "pp"* , int "metric"* , int "micmatching"* , int "i1", int "i2", int "e1", int "e2", int "e3", int "p1", int "p2" , bool "dchr"* , bool "palf"* , bool "tcfv1"* , bool "nvfr"* , bool "real30p"* , bool "autoAssuf"* , int "ediandnn"* , bool "o3025cfr"* , int "overlap", int "pel", int "search", bool "nnedi3pel"** , string "credconv" , bool "mode22"* , clip "ediext* , string "bob4p"* , clip "extbob"* , string "extbobf"* , bool "repwithtdeint"* , float "dark", int "thin", int "sharp", int "smooth", bool "stabilize", int "tradius", int "aapel", int "aaov", int "aablk", string "aatype")
* in mod ver. only.
** nnedi2pel in original ver..
says "* in modified version. only."
EDIT: Here, modified version:- http://forum.doom9.org/showthread.php?p=1673928|
Old 26th August 2016, 20:33   #17  |  Link
DenKudo
I'm using the mod version (http://pastebin.com/UFKyeZjj) but I still get the error.
EDIT: after using this version (http://forum.doom9.org/attachment.ph...1&d=1444791968) apparently I get this error: QTGMC does not have a named argument "lsb" but I think that correlates with smam()
Old 26th August 2016, 21:10   #18  |  Link
AzraelNewtype
AzraelNewtype's Avatar
That's from a newer modded QTGMC too. I think this is the latest. Most of that work isn't on this forum anymore.
AzraelNewtype is offline   Reply With Quote
Old 26th August 2016, 21:11   #19  |  Link
DenKudo
I'm still having this annoying Script error: QTGMC does not have a named argument "lsb"
Any help?
Old 26th August 2016, 21:15   #20  |  Link
DenKudo
Thank you for this. But now a new script error: MDegrain1 does not have a named argument "lsb".
anime, avs script, ivtc
