Old 14th March 2016, 19:40   #1  |  Link
yuv 8bit & 10bit = banding vs RGB csp
It's impossible to avoid banding using color space YUV even with x264 10bit without adding noise through video editor or similar things?
I did many tests with different settings like tune film, grain, input-range, forcing high bitrates as 20000, changing chroma with 8bit and 10bit. I put an image to show what I get:
played through MPC-HC.
with RGB csp its ok. YUV = banding. I play the video with different players like MPC-HC, VLC, Kmplayer...
It is more noticeable with images with big circular gradients (ringing issue)
I have doing some animations. It is ok to encode with csp RGB?
codexredestemp is offline   Reply With Quote
Old 15th March 2016, 21:04   #2  |  Link
/人 ◕ ‿‿ ◕ 人\
Try uisng madVR with MPC-HC, default EVR (and VLC and other crap) really suck at color conversions.
vivan is offline   Reply With Quote
Old 24th March 2016, 22:52   #3  |  Link
ангел смерти
foxyshadis's Avatar
They all look banded, even the original 8-bit RGB. You literally can't get rid of banding in 8-bit without dithering (or adding noise), YUV just makes it a little worse.
There are four boxes to be used in defense of liberty: soap, ballot, jury, and ammo. Please use in that order. ~ Ed Howdershelt
10bit, 8bit, banding, rgb, yuv
