Old 17th January 2016, 21:11   #1  |  Link
speedyrazor
VapourSynth pipe to ffmpeg
Hi, I have the below scripts for opening an HD Quicktime Prores file at 24fps with Multichannel audio in VapourSynth, resize and AssumeFPS to PAL. This is being piped to ffmpeg for 10-bit output back to Prores. I then need to process the audio, which I was going to open the source Prores in ffmpeg as a 2nd input and process it there (speed change the audio, map channels, change format, etc). My question is....
Is this the best, cleanest way to deal with the audio when my end result will be ffmpeg processing?
I am using VapourSynth portable and Python 3.5.1 embedded.
VapourSynth script, thanks to poisondeathray and sneaker_ger:
import vapoursynth as vs
core = vs.get_core()
ret = core.lsmas.LibavSMASHSource(source=r'movie.mov')
ret = core.fmtc.resample (clip=ret, w=720, h=576, css="444", kernel="spline36")
ret = core.fmtc.matrix (clip=ret, mats="709", matd="601")
ret = core.fmtc.resample (clip=ret, css="422")
ret = core.fmtc.bitdepth (clip=ret, bits=10)
ret = core.std.AssumeFPS(ret, fpsnum=25, fpsden=1)
ret.set_output()
ffmpeg script:
"C:\Program Files\python-3.5.1\VSPipe.exe" --y4m "script.vpy" - | "G:\ffmpeg\ffmpeg.exe" -f yuv4mpegpipe -i - -i "movie.mov" -map 0:v -map 1:1 -c:v prores -c:a pcm_s24le -y output.mov
speedyrazor is offline   Reply With Quote
Old 17th January 2016, 21:27   #2  |  Link
sneaker_ger
I don't see anything wrong with it.
Just two notes about l-smash works:
  • LWLibavSource() creates an index, you can use LibavSMASHSource() instead for mp4/mov. (Just like what we discussed for AviSynth)
  • you can leave out the "format" parameter in VapourSynth. It will automatically use the source format and can handle it natively.
Old 17th January 2016, 21:33   #3  |  Link
speedyrazor
Good tips, thanks. I will switch to LibavSMASHSource and remove the format (I have adjusted the above to show that). I see others keep referring to sox?
Old 17th January 2016, 21:37   #4  |  Link
sneaker_ger
Oh, I forgot about the audio. Of course you need to speed up the audio as well if you speed up the video. SoX with e.g. tempo filter is one solution. The other one would be to use AviSynth for audio - you already had that working IIRC?
SoX would work like that:
ffmpeg -i movie.mov -vn -f wav - | sox -t wav - -b 24 output.wav stretch 1.0427083333
Then use output.wav for muxing with video in ffmpeg.
Old 17th January 2016, 21:43   #5  |  Link
speedyrazor
Oh, I forgot about the audio. Of course you need to speed up the audio as well if you speed up the video. SoX with e.g. stretch filter is one solution. The other one would be to use AviSynth for audio - you already had that working IIRC?
I did indeed have that all working correctly in Avisynth, my only worry is now encoding speed, having to reed in the file twice, once for the video and once for the audio?
UPDATE: doesn't seem to be a problem, just ran a test (as above) on the server and it's averaging about 90fps. Nice!
I have written a Python application which runs upto 4 jobs at the same time, which I had running with Avisynth. So now just need to swap to VapourSynth and adjust the application a bit to incorporate the above script. Thanks for the help again.
Old 18th January 2016, 10:26   #6  |  Link
speedyrazor
Soooo....
If I use Vapoursynth for Video and Avisynth for audio, then pipe both into ffmpeg, how would the piping work, as I am new to piping into ffmpeg?
Old 18th January 2016, 10:30   #7  |  Link
jackoneill
unsigned int
jackoneill's Avatar
Originally Posted by speedyrazor View Post
Soooo....
In Linux it would be with at least one named pipe (`mkfifo`). But Windows doesn't have them, does it?
Programs (ffmpeg) have only one standard input, so you can't pipe two things into them. With named pipes, one (or both) of the things would look like a normal file.
Buy me a "coffee" and/or hire me to write code!
jackoneill is offline   Reply With Quote
Old 18th January 2016, 10:44   #8  |  Link
speedyrazor
That makes sense, thanks.
How would I deal with speed-changing the audio with no video in the Avisynth script?
Normally I would do this:
v = lsmashVideoSource("movie.mov")
a1 = lsmashAudioSource("movie.mov", track=2)
a2 = lsmashAudioSource("movie.mov", track=3)
a3 = lsmashAudioSource("movie.mov", track=4)
a4 = lsmashAudioSource("movie.mov", track=5)
a5 = lsmashAudioSource("movie.mov", track=6)
a6 = lsmashAudioSource("movie.mov", track=7)
a7 = lsmashAudioSource("movie.mov", track=8)
a = MergeChannels(a1,a2,a3,a4,a5,a6,a7)
AudioDub(v, a)
AssumeFPS(25, 1, true)
ResampleAudio(48000)
Which speed changes the audio.
How would I do this not referencing any video:
return a
Also, using Trim and BlankClip (need to add silence) with just audio, would this just work the same?
Old 18th January 2016, 16:18   #9  |  Link
speedyrazor
For pitch correction this seems to work:
a = a.TimeStretchPlugin(tempo = 25.0/(24000.0/1001.0)*100.0)
a = a.AssumeFPS(25, 1)
return a
But this does not seem to work for speeding up, fails with the below error:
a = a.AssumeFPS(25, 1, true)
a = a.ResampleAudio(48000)
return a
[avisynth @ 0510d000] Avisynth: division by zero at 0x0000251B in C:\Windows\SYSTEM32\avisynth.DLL
(\\10.0.1.103\folder\23.avs, line 9)
\\10.0.1.103\folder\23.avs: Unknown error occurred
Old 18th January 2016, 16:59   #10  |  Link
sneaker_ger
If there is no video AviSynth does not have a starting point. 25 fps is a video frame rate. Basically, "AssumeFPS(25, 1, true)" is telling AviSynth to "change speed of audio (and video) by factor 25/X". But since there is no video AviSynth does not know what "X" is. (It should probably output a better error message, though...)
But:
This does change speed! It just does not change the pitch. This is probably what you want to do.
See the documentation for info about tempo, pitch and rate parameters. If you want to change speed without preserving pitch you would use rate. Or you load a video (even a fake one with BlankClip()) and use AssumeFPS() or do a combination of AssumeSampleRate() and ResampleAudio().
Old 18th January 2016, 20:44   #11  |  Link
speedyrazor
Thanks, I will give that a try. Just our of interest (and I could stay in 64 bit throughout) what about Avisynth+, could I sue that for opening audio, changing audio, etc?
Old 18th January 2016, 20:53   #12  |  Link
sneaker_ger
Theoretically yes. But I don't know about a) compatibility with ffmpeg b) availability of 64 bit TimeStretch(Plugin) suited for multi-channel.
Old 20th January 2016, 15:20   #13  |  Link
speedyrazor
Hi, thanks for the help so far, its got me a long way, but now I am stuck again.
I am having trouble getting an ffmpeg pipe to work using VapourSynth and Python Popen commands (I know this may not be the place to ask this, but I am out of ideas). Running the pipe command on its own on Windows terminal it works correctly. Here is the python commands:
import subprocess
import os
from subprocess import Popen, PIPE, STDOUT
command1 = 'F:/ffmpeg/VapourSynth/VSPipe.exe --y4m C:/Users/myself/Desktop/script.vpy -'
command2 = 'F:/ffmpeg/ffmpeg.exe -f yuv4mpegpipe -i - -c:v prores -an //192.168.0.100/media/temp/OutMov.mov -report'
process1 = Popen(command1, stdout=PIPE, shell=False)
process2 = Popen(command2, stdin=process1.stdout, stderr=PIPE)
while True:
    line = process2.stderr.readline().decode('utf-8')
    print line
Running this with an ffmpeg report and printing stderr produces this:
pipe:: Operation not permitted.
Here is the ffmpeg report:
F:/ffmpeg/ffmpeg.exe -f yuv4mpegpipe -i - -c:v prores -an -y //192.168.0.100/media/temp/OutMov.mov -report
ffmpeg version N-77203-gb8e5b1d Copyright (c) 2000-2015 the FFmpeg developers
  built with gcc 5.2.0 (GCC)
  configuration: --arch=x86 --target-os=mingw32 --cross-prefix=/Users/myself/Desktop/Download/ffmpeg-windows-build-helpers-master/sandbox/mingw-w64-i686/bin/i686-w64-mingw32- --pkg-config=pkg-config --disable-w32threads --enable-gpl --enable-libsoxr --enable-fontconfig --enable-libass --enable-libutvideo --enable-libbluray --enable-iconv --enable-libtwolame --extra-cflags=-DLIBTWOLAME_STATIC --enable-libzvbi --enable-libcaca --enable-libmodplug --extra-libs=-lstdc++ --extra-libs=-lpng --enable-libvidstab --enable-libx265 --enable-decklink --extra-libs=-loleaut32 --enable-libx264 --enable-libxvid --enable-libmp3lame --enable-version3 --enable-zlib --enable-librtmp --enable-libvorbis --enable-libtheora --enable-libspeex --enable-libopenjpeg --enable-gnutls --enable-libgsm --enable-libfreetype --enable-libopus --enable-frei0r --enable-filter=frei0r --enable-libvo-aacenc --enable-bzlib --enable-libxavs --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libvo-amrwbenc --enable-libschroedinger --enable-li  libavutil      55. 10.100 / 55. 10.100
  libavcodec     57. 17.100 / 57. 17.100
  libavformat    57. 19.100 / 57. 19.100
  libavdevice    57.  0.100 / 57.  0.100
  libavfilter     6. 20.100 /  6. 20.100
  libswscale      4.  0.100 /  4.  0.100
  libswresample   2.  0.101 /  2.  0.101
  libpostproc    54.  0.100 / 54.  0.100
Splitting the commandline.
Reading option '-f' ... matched as option 'f' (force format) with argument 'yuv4mpegpipe'.
Reading option '-i' ... matched as input file with argument '-'.
Reading option '-c:v' ... matched as option 'c' (codec name) with argument 'prores'.
Reading option '-an' ... matched as option 'an' (disable audio) with argument '1'.
Reading option '-y' ... matched as option 'y' (overwrite output files) with argument '1'.
Reading option '//192.168.0.100/media/temp/OutMov.mov' ... matched as output file.
Reading option '-report' ... matched as option 'report' (generate a report) with argument '1'.
Finished splitting the commandline.
Parsing a group of options: global .
Applying option y (overwrite output files) with argument 1.
Applying option report (generate a report) with argument 1.
Successfully parsed a group of options.
Parsing a group of options: input file -.
Applying option f (force format) with argument yuv4mpegpipe.
Opening an input file: -.
[AVIOContext @ 006d9800] Statistics: 0 bytes read, 0 seeks
I am stumped. What am I doing wrong?
Old 20th January 2016, 16:16   #14  |  Link
speedyrazor
Please ignore my above post, it turned out to be a file path permisssions issue.
Old 29th January 2016, 14:54   #15  |  Link
dipje
Why the matrix 709 to 601?
As long as you feed YUV into ffmpeg it doesn't touch it and you won't get any color shift. All the stories about ffmpeg and colorshift and stuff is when you let it do any rgb <-> yuv conversion (it will default to 601 then, even if someone expects it to use 709). As long as you feed it YUV and encode in YUV, no color change. And hd-material prores is expected to be in 709.
And is there really a need (I think I don't see it but what do I know) to do the video and audio in one pass? Why not encode the video, encode the audio (with avisynth or whatever you want) into a separate .wav file and then mux them together?
If your input file is huge there might be some extra disk access, but you won't notice it as long as you're reading from a normal file I guess. If you're reading straight from a memory card, or you want a process to run on a server with 32+ instances at the same time running then disk access might be a factor, but otherwise I don't see a reason to do it in one go.
dipje is offline   Reply With Quote
