Old 13th October 2015, 14:41   #1  |  Link
EruPii
Progressive credits on interlaced video
Hello everyone,
I'm having trouble with an anime source which has progressive credits on an interlaced video. Is there a way to IVTC the source ignoring the credit text somehow?
Here is my source. It's the opening sequence of the anime.
Thanks for your help in advance.
EruPii is offline   Reply With Quote
Old 13th October 2015, 17:00   #2  |  Link
kuchikirukia
If TFM is destroying the kanji, it's sometimes the post-processing. Try setting pp=0.
kuchikirukia is offline   Reply With Quote
Old 13th October 2015, 22:52   #3  |  Link
EruPii
It doesn't really work. I'm trying this code now.
LoadPlugin("c:\Program Files (x86)\MeGUI\tools\dgindex\DGDecode.dll")
mpeg2source("vob/rmexeb_ep01.d2v")
ConvertToYV12(interlaced=true)
deint = TDeint(order=1, type=3, full=false)
TFM(pp=1, clip2=deint, display=true)
#TDecimate(mode=1)
In the ending sequence, there are motions TFM telecides wrong. I've attached screenshots and the ending sequence VOB too.
Motion of the original source:
And the motion of the TFMed source:
Old 14th October 2015, 02:06   #4  |  Link
Desbreko
Desbreko's Avatar
That can happen when the progressive credits change on a frame of animation that's combed from being telecined, making TFM think that the frame shouldn't be field matched because it'll cause combing in the credits. All you can really do about it is force the correct field match with an override file and then post-process deinterlace the credits.
Twitter, AviSynth scripts
Desbreko is offline   Reply With Quote
Old 14th October 2015, 12:02   #5  |  Link
EruPii
I guess that's the only way to make the field matching right. Thanks for the help, guys.
anime, interlaced video, ivtc, progressive credits
