Old 25th May 2015, 01:41   #1  |  Link
luquinhas0021
The image enthusyast
best upscale algorithm
what is more accurate (retention of every detail): smart edge 2 or m spline (neural spline)? And why? Smart edge 2 creates details?
luquinhas0021 is offline   Reply With Quote
Old 25th May 2015, 01:53   #2  |  Link
LoRd_MuldeR
Software Developer
LoRd_MuldeR's Avatar
Please edit your question in accordance with rule #12!
http://forum.doom9.org/forum-rules.htm
Also, you should try to be as specific as possible. What exactly are you trying to achieve? What is nature of your source material?
Old 25th May 2015, 12:13   #3  |  Link
luquinhas0021
i`m talking about photo upscaling and single frame upscaling
Old 25th May 2015, 17:58   #4  |  Link
raffriff42
Retried Guesser
raffriff42's Avatar
Some algorithms might do a pretty nice job on some images, but none can be perfect, as the basic information is not present in the source. Therefore, there is no "best method." You must compare using your source material and make your own judgement.
Here's a good page for quickly comparing upscaling algorithms:
Video resize methods comparison (infognition.com)
Click on the top-left thumbnail, named "smiths.avi", then the right popup.
Then click the buttons to compare the different algorithms.
Here's another one:
Comparisons of Image Magnification Methods (general-cathexis.com)
Hover your mouse over the numbers placed around the outside of the large image.
raffriff42 is offline   Reply With Quote
Old 26th May 2015, 13:21   #5  |  Link
pandy
From math perspective: point resampling (Nearest-neighbor interpolation). All details are kept intact.
pandy is offline   Reply With Quote
Old 26th May 2015, 15:04   #6  |  Link
Motenai Yoda
Motenai Yoda's Avatar
Only if you are up-scaling by an exact multiple, ie 1.5x give you alternately 1 pixel wide column/right and a 2 pixel wide column/right.
anyway it adds steps that there aren't in source.
powered by Google Translator
Motenai Yoda is offline   Reply With Quote
Old 26th May 2015, 15:42   #7  |  Link
feisty2
I'm Siri
feisty2's Avatar
padding/addborders
they blow the frame size up without doing anything to the actual clip
If I got new ideas, will post here: https://github.com/IFeelBloated
feisty2 is offline   Reply With Quote
Old 27th May 2015, 16:12   #8  |  Link
pandy
Topic is about upscale not general resampling.
Yes fraction upscaling with point resampling can give described result but it is fully reversible i.e. non lossy.
Old 27th May 2015, 20:01   #9  |  Link
*.mp4 guy
*.mp4 guy's Avatar
Point scaling is only non-lossy If you don't do /anything/ with the result. Beyond that, all of the major linear interpolators in avisynth use strictly interpolating kernels, thus they can be made to be lossless under any condition during which pointresize could be lossless by choosing the correct pixel offsets. For integer interpolation be odd factors, eg. 3, 5 you don't even need to calculate an offset, the center pixel ( ie. b, when scaling by a factor of 3 from the pixel set [1->a b c], is unchanged, b=1). This property is generally much much more useful, as lnear interpolation doesn't cause problems for subsequent operations the way pointscaling does. Depending upon how you upscale with nnedi3, it too can produce a lossless result, preserving all of the original picture information in a manner analogous to the situation with linear interpolation.
Point being, if you need "lossless" interpolation, you've got better options than pointresize.
*.mp4 guy is offline   Reply With Quote
Old 28th May 2015, 03:16   #10  |  Link
luquinhas0021
*mp4 gui, tell me how i can make a lossless resize with nnedi3, once even spline 100 was better than it in images and videos that i had upscaled! Three more questions: antialiasing filter makes detail loss? Is there some detail lossless aa filter? What is better center shift correction algorithm that i can choose for nnedi3 parameter? nnedi3 doesn`t is update by tritical since 2011. It was discontinued?
Old 28th May 2015, 03:42   #11  |  Link
if you change something by adding or removing something you lose something it's that simple.
Old 28th May 2015, 10:06   #12  |  Link
Gavino
Avisynth language lover
Yes.
The exceptions to this (ie those that are not strictly interpolating) are BicubicResize with b/=0 and GaussResize with values of p less than about 80.
See also this old thread: Lossless resizing.
