Old 23rd February 2015, 17:19   #1  |  Link
Batman007
How to make avs from .mpls ?
Hi guys .....
I am trying to make .avs from .mpls ... But I can't ...
Can anyone tell me proper way to make .avs from .mpls (with or without MeGUI) ?
Thank you ......
Batman007 is offline   Reply With Quote
Old 23rd February 2015, 19:05   #2  |  Link
Batman007
Please help....
Old 23rd February 2015, 22:20   #3  |  Link
Asmodian
I don't think it is possible. I do not know of any filter than can open a bluray playlist in AVISynth. You will need to use the .m2ts files directly.
Old 23rd February 2015, 23:57   #4  |  Link
qyot27
qyot27's Avatar
#!/bin/bash
if test x"$1" = x"-h" -o x"$1" = x"--help" -o x"$1" = x"" ; then
cat <<EOF
Usage: mpls-to-avs <mplsfile> <sourcefilter>
Help:
  -h, --help        print this message
EOF
exit 1
fi
if [ "$2" = "ffms2" ] ; then
    SCRIPTFUNC="FFVideoSource"
elif [ "$2" = "lsmash" ] ; then
    SCRIPTFUNC="LwLibavVideoSource"
fi
BASICNAME=$(sed 's/M2TS/M2TS\n/g' "$1" | perl -ne 'print scalar reverse;' | cut -c1-9 | perl -ne 'print scalar reverse;')
echo $BASICNAME | sed 's/M2TS/M2TS\n/g' | grep M2TS | sed -e 's/ //g' -e 's/M2TS/.m2ts/g' | awk '{printf("(\"%s\") ++ \\\n",$1)};' | sed -e "s/^/$SCRIPTFUNC/g" -e '$ s/ ++ \\//' | todos > "$1".avs
This is assuming that .mpls files are simple playlists and don't do weird chapter jumping stuff, and that all of the .m2ts files the .mpls refers to actually work. At any rate, it does show which files the .mpls refers to, so it still has some value, I guess.
Although the easiest way to deal with it is just by running the playlist through mkvmerge and working with the single file it gives you.
Old 24th February 2015, 06:52   #5  |  Link
Batman007
I have a movie whose length is 01:42 .. But the largest M2TS is still shorter than 01:42 .. That's why I chose to encode with mpls ... But I'm not getting how to encode that .mpls ...
Old 24th February 2015, 11:07   #6  |  Link
qyot27's script seems to be Linux based, you might be able to run it under eg Cygwin: http://en.wikipedia.org/wiki/Cygwin
https://www.cygwin.com/
Old 24th February 2015, 14:07   #7  |  Link
Batman007
Please help ...
Old 24th February 2015, 14:25   #8  |  Link
Groucho2004
Originally Posted by Batman007 View Post
Please help ...
I think your best option is to load the playlist in tsmuxer gui, and then create a m2ts that combines all segments (-> m2ts muxing). The resulting m2ts can be loaded in Avisynth with FFMS2 or similar.
Old 24th February 2015, 14:33   #9  |  Link
Batman007
Is this tutorial fine for me ? http://www.dvd-guides.com/guides/blu...blu-ray-to-mkv
Old 24th February 2015, 14:42   #10  |  Link
Groucho2004
You don't need to go through all that just to load your BD into Avisynth. Maybe you should tell us first what you want to do with your BD.
Edit: If you are not sure which playlist you should pick, the guide you linked to is probably fine.
Old 24th February 2015, 14:58   #11  |  Link
ndjamena
That tutorial is fine for nobody. TSMuxer and then MMG? MMG will rip the playlist all by itself, and if you use MakeMKV you can even skip AnyDVD HD. It's WAY out of date.
ndjamena is offline   Reply With Quote
Old 24th February 2015, 14:59   #12  |  Link
Reel.Deel
DGDecNV can index .mpls files directly. Makes it very easy, especially with some Blu-ray's that are split into a large amount of smaller segments.
Old 24th February 2015, 20:02   #13  |  Link
Asmodian
Wow, I had no idea. That makes DGDecNV a lot better. Thanks!
