Old 11th October 2014, 19:33   #1  |  Link
Necromonger
Shader to play only blue color in mpchc?
I need to play video in only blue color so i can do "blue filter" color calibration. Is there any way to achieve this with shaders or in some other way and player?
Necromonger is offline   Reply With Quote
Old 11th October 2014, 20:19   #2  |  Link
setarip_old
setarip_old's Avatar
Hi!
I believe you'll find such a filter is available foruse with VirtualDub from one of Donald Graft's website...
setarip_old is offline   Reply With Quote
Old 12th October 2014, 17:17   #3  |  Link
Shiandow
You should be able to do that using the following shader:
sampler s0 : register(s0);
float4 main(float2 tex : TEXCOORD0) : COLOR {
	float4 c0 = tex2D(s0, tex);
	//Set r,g channels to 0
	c0.rg = 0;
	return c0;
Old 12th October 2014, 17:56   #4  |  Link
nautilus7
nautilus7's Avatar
Thanks!
nautilus7 is offline   Reply With Quote
blue, calibration, color, filter, mpchc
