Old 27th August 2014, 11:55   #1  |  Link
3hj
Advice humbly requested on optimal filter order.
Hello.
I have a non-profit film project I'm doing, with the intention of releasing it for free download/streaming online. This film is going to be cobbled together from a multitude of sources:
- 1080p HDV footage
- SD DVCam footage
- 2nd-gen VHS camcorder footage
- Hi-8 camcorder footage
I figure the prudent thing to do would be to release this project in 720p, because (a) I've seen some astonishingly good results with upscalers here and elsewhere on the internet but (b) I think upscaling VHS to 1080p is probably a bit too much of a stretch.
My question is about the 'optimal' order of filters, which ones to put in which order to get the best results. At some point, I'm going to use the following filters on the footage (the HDV footage will probably remain as-is, since it's pretty pristine):
- upscaling to 720p
- cropping (removing useless black/garbage outer edges on the VHS footage; turning all 4:3 images into 16:9)
- deinterlacing (all the VHS footage and some of the DVCam footage is interlaced)
- deblocking (some of the DVCam stuff has lossy DivX compression on top of the original MPEG-2 captures and has noticeable artifacting)
- de-noising (some of the VHS footage is quite noisy, and some of the DVCam footage was shot in low-light and is quite grainy)
- general de-VHS-ugliness'ing (seems to be a lot of filter chains built specifically around making VHS footage more pleasing, so I'll be investigating and probably including stuff like that as well)
- levels/brightness/contrast adjustment
- colour correction/colour grading
- sharpening where needed (not sure if upscaling would negate needing to do this?)
Might be subjected to some minor adjustments and filtering otherwise, but I think the above will be pretty much everything I'll be doing with AviSynth.
So. In what order would I stack these to get the best results? My assumption would be levels+colour correction -> deinterlace -> deblock -> denoise -> sharpening -> upscaling -> cropping, but this is just my gut feel, and I'm not too knowledgeable on the intricacies of filtering. What would you suggest? Any info/hints will be greatly appreciated.
Also, would I want to do the filtering before editing the footage together, or after? I would assume beforehand, but again, beginner knowledge and all that.
3hj is offline   Reply With Quote
Old 27th August 2014, 13:11   #2  |  Link
bxyhxyh
Sharpening should be after upscaling or before downscaling.
Upscaling sharpened video can be "upscale" artifacts caused by sharpeners.
Same for levels/colour correction.
Also I think cropping should be done before resizing. Black borders can be recognized as line then there can be ring/halo artifacts.
So my recommendation is
deinterlace -> denoise -> deblock -> cropping -> upscaling -> sharpening -> levels+colour correction
bxyhxyh is offline   Reply With Quote
Old 27th August 2014, 13:22   #3  |  Link
feisty2
I'm Siri
feisty2's Avatar
1. sharpen (separatefields first and do limit the sharpdif so artifacts and noise will not get worsened)
2. color adjustments (16bpc precision, same as 1, separatefields first, then adjust)
3. denoise/deblock (separatefields then denoise/deblock)
4. deinterlace
5. upscale
feisty2 is offline   Reply With Quote
Old 27th August 2014, 13:27   #4  |  Link
bxyhxyh
4. deinterlace
I think this destroys more detail than deinterlace + denoise.
Old 27th August 2014, 13:32   #5  |  Link
feisty2
I'm Siri
feisty2's Avatar
sharpening should be performed on the original clip before any other filters,
your clip will easily be oil painted look like if sharpen a denoised clip
color adjustments should be performed before denoising
you may find some residual noise/dirty spots if denoise first then lighten the color
Old 27th August 2014, 13:38   #6  |  Link
feisty2
I'm Siri
feisty2's Avatar
deinterlacing WILL affect the original noise pattern, so will affect the denoise effect
however, denoise first is harmless to deinterlace
Old 29th August 2014, 13:48   #7  |  Link
fvisagie
If you have a long, quiet day at the office to kill, consider reading this thread: http://forum.videohelp.com/threads/3...PEG-2-encoding. It covers this and other issues pertinent to working with multiple sources of the types you mention, such as taking into account DV vs. MPEG chroma placement, translating between the SD Rec.601 and HD Rec.709 colourspaces, the luma (and perhaps chroma) correction you mention, etc.
For what it's worth at this point, for interlaced material the most important rule is always to deinterlace before doing ANYTHING that changes vertical geometry (e.g. resize and crop), and/or that makes assumptions about vertical information being from the same point in time (e.g. subtitles) and/or is generally interlacing unaware. For example, denoising interlaced material is debatably damaging - spatial denoising will spatially blur information between fields originally from different points in time, and temporal denoising will similarly not account for true movement between fields. In various threads (if not in the one above) jagabo has explained why not even separated-field work-arounds are generally suitable.
The filter sequence you suggest seems largely safe from that point of view, except that some purists would argue that giving the deinterlacer less-than-original field information after levels and chroma correction is sub-optimal.
fvisagie is offline   Reply With Quote
Old 29th August 2014, 15:04   #8  |  Link
feisty2
I'm Siri
feisty2's Avatar
you can surely interpolate every fields to full frames with eedi3 and do denoise, sharpen all those stuff and simply discard the interpolated fields and weave the source fields together at the end of everything before deinterlacing if you worry about even separatefields first is not right
#interlaced input#
separatefields ().assumeframebased ()
bot=selecteven ().eedi3 (field=0,dh=true,sclip=selecteven ().nnedi3 (field=0,dh=true))
top=selectodd ().eedi3 (field=1,dh=true,sclip=selectodd ().nnedi3 (field=1,dh=true))
interleave (bot,top)
#sharpen, denoise, blah blah...#
bot=selecteven ().separatefields ().selecteven ().assumefieldbased ()
top=selectodd ().separatefields ().selectodd ().assumefieldbased ()
interleave (bot,top).assumebff ()
weave ()
#deinterlace#
EDIT: Fixed field temporal shift
Old 29th August 2014, 16:01   #9  |  Link
Some denoise filters have an Interlaced arg (or similar) eg FFT3DFilter (spacio/temporal) and VagueDenoise (Spacial).
Also, Stickboy's jdl-interlace.avsi has JDL_UnfoldFieldsVertical, and JDL_FoldFieldsVertical (using flip arg), used to apply
spatial filters to interlaced material.
http://www.avisynth.nl/users/stickboy/
StainlessS is online now   Reply With Quote
Old 29th August 2014, 16:17   #10  |  Link
feisty2
I'm Siri
feisty2's Avatar
as far as I'm concerned, all these filters just do separatefields function or things similar internally, which fvisagie thinks is wrong
Old 29th August 2014, 17:03   #11  |  Link
poisondeathray
Everyone has their own way of doing things, you have to determine what works best for your particular scenario
Separatefields() is "technically wrong" because of the even/odd vertical field offset. Even/Odd fields are not vertically aligned
Even if you group even/odd separate fields, and filter that way, then interleave and weave - then use of temporal filters is technically "wrong" and less effective, because in bobbed sequence, you will be filtering 0,2,4,6... separately from 1,3,5,7.... ie. there will be no temporal filtering between even and odd, only within
#interlaced input#
weave ()
#deinterlace#
Did you realize that you're essentially "double rate deinterlacing" by separating , interleaving the EDI "resized" fields ? ie You're supporting what fvisagie said
So why are you deinterlacing, re-interlacing then deinterlacing again ? Seems like a lot of extra steps ?
Old 29th August 2014, 17:13   #12  |  Link
feisty2
I'm Siri
feisty2's Avatar
the difference is a lot of people like to use advanced deinterlace/bob script like qtgmc, those scripts will not keep the original fields, there are new fields interpolated, but the original fields are altered as well, this method will not do anything to the original fields if you leave that #denoise xxxx#part empty
Old 29th August 2014, 17:31   #13  |  Link
poisondeathray
Yes, that will keep original fields.. But who said anything about keeping original fields?
He wants to deinterlace and upscale, and he's filtering anyways - so not keeping original fields
Or maybe you implying that filtering should be done on original fields ?
Old 29th August 2014, 17:34   #14  |  Link
feisty2
I'm Siri
feisty2's Avatar
personally, I think it's quality wise to use sharpen or denoise kinda stuff on original fields and that's the whole point why I order like that, to get the best quality
advice, filters, restoration, upscaling
