Old 16th August 2014, 17:45   #1  |  Link
peterhuh
Looking for a USM filter with 8 pixel radius.
Hi!
I have this film in high definition but extremely soft focus. According to my pixel counting, the soft focus had a glow radius of about 8 pixels.
I was thinking of using a vanilla unsharp masking filter like those found in Photoshop and GIMP to "subtract" out the soft glow with USM's halo.
It works quite well in GIMP, but I had problem locating an equivalent filter for AVISynth. Most sharping filter uses 3x3 kernels which unsharps film grain rather than removing the soft glow.
I was wondering if anyone knows a USM filter with an option to adjust the radius. I never had a need to use a sharpener until now. Thanks in advance.
Oh! Signature! My very own Signature! What should I put?! What can I write?! I must write something! Something that everyone can see! And it will appear at the bottom of my every post! Then everybody will be able to read my signature! Nobody will not read my signature! Somebody will tell others to read my signature! Which will be at the bottom of my every post! And i ca...<cropped>
peterhuh is offline   Reply With Quote
Old 16th August 2014, 21:08   #2  |  Link
colours
colours's Avatar
There're a couple of USM filters (and other sharpeners) linked on the wiki.
colours is offline   Reply With Quote
Old 17th August 2014, 04:56   #3  |  Link
raffriff42
Retried Guesser
raffriff42's Avatar
I know of two good ways;
- with VariableBlur by Tritical:
# http://avisynth.nl/index.php/Variableblur
# http://forum.doom9.org/showthread.php?t=88645
# (libfftwf3-3.dll needs to be in the search path)
LoadPlugin(pathBase + "variableblur07\variableblur.dll")
#@function Unsharp(float "varY", float "varC", float "strength"[0-1], int "border"=4,
##\               bool "integrate"=false, int "Y"=3, int "U"=2,int "V"=2,
##\               int "gfunc"=-1, int "gfuncc"=-1, int "pcr"=0, int "pcrc"=0, int "nthreads")
Unsharp(varY=Sqrt(8.0), varC=Sqrt(4.0), strength=0.7)
- and with NonlinUSM by Didée:
## posted at:
# http://forum.doom9.org/showthread.php?p=1555234#post1555234
#@function NonlinUSM(clip o, float "z", float "pow", float "str",
##\                 float "rad", float "ldmp")
## @ z    - default 6     (3 = subtle; 16 = massive)
## @ pow  - default 1.6   (1.0 = oversharp; 4.0 = mild)
## @ str  - default 0.7   (3 = strong; 18 = massive)
## @ rad  - default 9     (0.6 = sharpen; 18 = soft)
## @ ldmp - default 0.001 (block overlap? 0.01 = a little smoother?)
NonlinUSM(z=6, pow=1.0, str=0.7, rad=8.0)
NonlinUSM is much more versatile; recommended.
EDIT - for example:
NonlinUSM(pow=4)                          ## enhance: for low bitrate sources
NonlinUSM(z=3, pow=4.0, str=1, rad=6)     ## enhance less
NonlinUSM(z=6, str=1.5, rad=0.6).Sharpen(0.3)  ## sharpen: for hi-q sources
NonlinUSM(z=3, str=2.5, rad=0.6)          ## sharpen: less noise
NonlinUSM(z=6, pow=1.0, str=0.7, rad=6.0) ## unsharp
NonlinUSM(pow=1.0, rad=2, str=0.7)        ## smoothen: for noisy sources
NonlinUSM(pow=1.0, rad=18, str=0.5)       ## smear: soft glow
NonlinUSM(z=16, pow=4.0, str=18, rad=6)   ## B+W psycho
NonlinUSM(z=16, pow=4.0, str=3, rad=6)    ## sepia/artistic
NonlinUSM(z=6, pow=4.0, str=1, rad=36)    ## local contrast
NonlinUSM(z=6, pow=1.0, str=1, rad=36)    ## local contrast
NonlinUSM(z=16, pow=2.0, str=2, rad=36)   ## solarized
raffriff42 is offline   Reply With Quote
Old 17th August 2014, 16:02   #4  |  Link
peterhuh
NonlinUSM seems to do the trick!
Thanks!
Old 17th August 2014, 22:13   #5  |  Link
zerowalker
Mind showing Before/After, out of interest?
zerowalker is offline   Reply With Quote
