#102 | Link |
The script below crashes sometimes. The error points to nnedi3ocl.avsi.
(I originally posted this here because I thought avs4x26x was causing the crashes.) Code:
DGSource("src.dgi") mrdaa2(resharpen=0) flash3kyuu_deband_f3kdb(grainY=0, grainC=0, output_mode=2, output_depth=16) Code:
# modified version of mandarinka's MrdaaLame (http://forum.doom9.org/showthread.php?t=167480) by anonymlol # Based on Daa: Anti-aliasing with contra-sharpening by Didée, modded by Terranigma for nnedi and by thetoof for merge # fixed chroma shift by OnDeed function Mrdaa2(clip c, float "resharpen", bool "OpenCL") { resharpen = Default(resharpen, 0) OpenCL = Default(OpenCL, true) dblshift = (OpenCL) ? c.nnedi3x(field=1, dh=true).fturnright().nnedi3x(field=1, dh=true).fturnleft() \ : c.nnedi3(field = 1,dh=true).fturnright().nnedi3(field = 1,dh=true).fturnleft() dbl = dblshift.Spline36Resize(c.width,c.height,-0.5,-0.5,c.width*2,c.height*2).MergeChroma(dblshift.Spline36Resize(c.width,c.height,-1.0,-1.0,c.width*2,c.height*2)) dblD = mt_makediff(c,dbl,U=3,V=3) shrpD = mt_makediff(dbl,dbl.blur(resharpen*0.2,MMX=false),U=3,V=3) DD = shrpD.repair(dblD,13) return dbl.mt_adddiff(DD,U=3,V=3) } ![]() This crashes: Code:
dblshift = (OpenCL) ? c.nnedi3x(field=1, dh=true).fturnright().nnedi3x(field=1, dh=true).fturnleft() \ : c.nnedi3(field = 1,dh=true).fturnright().nnedi3(field = 1,dh=true).fturnleft() Code:
dblshift = c.nnedi3x(field=1, dh=true).fturnright().nnedi3x(field=1, dh=true).fturnleft() I'll remove the condition for now and use it with nnedi3ocl as default. Last edited by anonymlol; 7th March 2015 at 13:35. |
#104 | Link |
Soul Architect
I'm curious about something with the NNEDI3 OpenCL implementation. It has been reported to not perform any better than the standard version. Shouldn't that depend purely on the graphic card, or is the CPU still the bottleneck?
I'm currently writing code to run HLSL shaders in AviSynth, and I wonder how the NNEDI3 HLSL implementation, which runs entirely on the GPU, would compare to this performance-wise https://github.com/zachsaw/MPDN_Exte...Scripts/NNEDI3 |
#108 | Link |
I am try reinstall Avisynth, problem do not go.
I am also try check on another PC under Windows 10, opencl version nnedi3 work without problem. Please advice roadmap for solving problem. If need additional info I can send. My sytem Windows 7 64 home premium, 8 Gb, i7, GTX 960 (before internal Intel Graphics). Sytem and drivers updated. yup. |
#109 | Link |
What with field= -2, 2 and 3?
nnedi3ocl do not have them? -2 = double rate (alternates each frame), uses avisynth's internal parity value to start 2 = double rate (alternates each frame), starts with bottom 3 = double rate (alternates each frame), starts with top without this not possible use nnedi3ocl in QTGMC ![]() |
#110 | Link |
Well. Find workaround for field=-2 in old nnedi thread.
Function nnedi3xFieldMinus2(clip Input) { Input.SeparateFields() GetParity(Input) ? Interleave( SelectEven().nnedi3ocl(dh=true,Field = 1), SelectOdd().nnedi3ocl(dh=true,Field = 0) ) \ : Interleave( SelectEven().nnedi3ocl(dh=true,Field = 0), SelectOdd().nnedi3ocl(dh=true,Field = 1) ) AssumeFrameBased() GetParity(Input) ? AssumeTFF() : AssumeBFF() } |
#111 | Link | |
Probably adding new video card broken some relations. yup. |
#112 | Link |
High all!
Lucky life continue until Geforce driver updated to 362.00. See error during load simle script in VirtyualDub https://www.dropbox.com/s/k4gsunhr29...diocl.png?dl=0 Language my windows is Russian. Translation Video driver do not respond and was recovered, Video driver Nvidia Windows Kernel Mode Driver , Version 362.00 do not respond and was recovered. Any suggesrtions, please. yup. |
#114 | Link |
Bloax!
I spent some time for finding gui http://forum.videohelp.com/threads/3...=1#post2423628 I am try upscale image to 2-4 time using CUDA (not cuDNN) all work. Also for me work without problem KNlmeansCL plugin. yup. Last edited by yup; 16th March 2016 at 18:27. |
#115 | Link |
Am I blind or this plugin does not have device_id switch like KNLMeansCL ? What opencl device will this plugin use if user has AMD APU + Dedicated AMD GPU?
#116 | Link | |
![]() Two options should be added device_type and device_id
#118 | Link | |
Audiophile
#120 | Link |
For science!
