Old 8th May 2013, 19:35   #1  |  Link
Biggiesized
Biggiesized's Avatar
Optimal Bayer CFA codecs?
Given the growing abundance of digital cinema style cameras on the market, there has been a growing need to capture and record RAW sensor data onto high speed solid-state media. Compressed R'G'B' or Y'U'V' data in the form of (10-bit/8-bit) H.264 Intra or ProRes or DNxHD hasn't been a problem for some time, but 12-/14-/16-bit linear RAW can represent a lot of bandwidth.
If you want to go the mathematically lossless route, what are some the best codecs applicable today in terms of compression ratio and hardware requirements? I've done some research and here's what I've turned out:
1) JPEG-LS (HP Labs LOCO-I) - not that effective on CFA but perhaps it can be further optimized
2) JPEG2000 - popularized by RED even though they've gone the lossy route (3~12:1 compression ratio); there is a 5/3 CDF wavelet transform for lossless compression
3) Various vector prediction techniques - one example
4) Libima - experimental; not sure if it's abandonware
5) CinemaDNG - I believe it supports a HuffYUV style lossless compression mode, at least on the upcoming BMPC
Any others to consider?
Biggiesized is offline   Reply With Quote
Old 8th May 2013, 21:21   #2  |  Link
kolak
As it comes to codecs- Cineform, ffv1, but none has a hardware implementation.
Old 8th May 2013, 22:03   #3  |  Link
poisondeathray
cineform isn't "mathematically lossless" as per his requirements
(Also cineform does have a hardware implementation on cinedeck recorders)
Old 8th May 2013, 22:22   #4  |  Link
Biggiesized
I wonder if David Newman could re-optimize the codec for lossless coding.
Does FFV1 handle RAW bayer data?
Old 8th May 2013, 22:25   #5  |  Link
kolak
I spoken with him about it- he seems to be not interested. Lossless coding requires different approach, no?
Also 3:1 mode gives in real world way good enough source to start with- there is really no need for lossless mode.
RED users use 5:1 or 7:1 even for 100M$ productions.
I think 3:1 is a nice compromise.
No ffv1 does not understand RAW data, but I managed to unpack RAW data into 16bit TIFF and than encode it.
No idea if I broken 12bit DNG or not
After debayering it looks fine, so maybe not
Old 8th May 2013, 22:30   #6  |  Link
kolak
Cinedeck recorders run on WIN
Old 8th May 2013, 23:08   #7  |  Link
Biggiesized
I think 3:1 is nice compromise.
5:1 is okay because it hides the artifacts well enough when downsampling from 5K to 2K. Even seen the native resolution compressed that much? There are tons of picture artifacts like rampant softening and poor chroma resolution.
Old 8th May 2013, 23:24   #8  |  Link
kolak
Seen few posts on RED forum which say that 5:1 and 7:1 mode is used a lot. 5:1 seems to be prefered one.
Old 25th March 2014, 16:27   #9  |  Link
zcream
Does anyone know how a CFA Bayer data is encoded via lossless jpeg ?
The code in public libraries only has examples for RGB or 4-channel debayered data.
I could not find any sample code of lossless jpeg used for RAW bayer compression.
DNG SDK does it, but its hard to comprehend.
zcream is offline   Reply With Quote
Old 6th April 2014, 17:53   #10  |  Link
benwaggoner
I dimly recall that JPEG-XR was to have Bayer support. I don't know if that ever made it into an implementation though.
Ben Waggoner
Principal Video Specialist, Amazon Instant Video
My Compression Book
Amazon Instant Video is hiring! PM me if you're interested.
bayer, cfa, codec, color filter array, lossless
