13th April 2013, 14:58 | #1 | Link |
DGIndexNV - block artifacts in DVB-S2 H.264-stream
Hello,
I'm pretty sure this is not concerning DGIndexNV directly (more to that below), but as it bothers me the most here: I'm experiencing block artifacts in a h.264-TS when decoding it with DGIndexNV 2044. It's a DVB-recording from BBC HD (Astra 28.2E) a couple of months ago, recorded with yaVDR 0.4. I've uploaded a small sample containing the affected position (cut from the original VDR-TS with TSDoctor): http://www.mediafire.com/?rb59vbubam4an44 The problem appears from frame 114 to 121, mainly in the left bottom corner - see attached screenshot. I admit it's not a huge disaster because it's barely noticeable, but it points to a decoder problem. At first I assumed it might plain and simple be an error in the stream, caused by bad satellite reception, the VDR itself or whatever, but I wondered why TSDoctor didn't report an error or a warning. Then I noticed some DirectX-filters/-decoders are showing the scene without any error. I did further checking on that and discovered the following pattern: OK, no artifacts: - MainConcept 8.5.0.53.657 on MPC-HC 1.5.1.2903 - LAV filters 0.56, CUVID disabled on MPC-HC - CoreAVC 3.0.1, CUDA disabled on MPC-HC - VLC 2.0.5 (as far as I know VLC uses its own decoders and no DirectShow-filters?) Error, artifacts: - DGIndexNV 2044 - LAV filters 0.56, CUVID enabled on MPC-HC - CoreAVC 3.0.1, CUDA enabled on MPC-HC So it seems the problem appears whenever CUDA is involved, software-based decoding seems to be fine. My problem here: As a matter of principle DGIndexNV is not designed to turn off CUDA... My System: Windows 7 x64 nVidia GTX 550 Ti (two of them to be precise) with driver version 314.22 (just updated yesterday to be on the safe side) Any ideas? |
17th April 2013, 09:47 | #3 | Link | |
Use DGindex, it doesn't rely on CUDA (or NVidia) at all.
Born in the USB (not USA) |
17th April 2013, 10:50 | #6 | Link | |
I do not use them so I am not that familiar with their names and versions.
17th April 2013, 11:24 | #7 | Link |
User of free A/V tools
Yup, this sample looks like an ideal candidate for testing nVidia CUVID decoder issues. I confirm that blocking artifacts occur with DGDecNV 2044 32-bit on my GT520 & GeForce drivers 301.42 whereas VLC plays it just fine.
Perhaps neuron2 could make use of his nVidia connections and poke them a bit with this sample - provided the stream is indeed 100% error-free. |
19th April 2013, 18:24 | #8 | Link | |||
BTW: LAV set to "DXVA (copy-back)" shows the same error, "DXVA (native)" seems to work fine. Quote:
19th April 2013, 21:02 | #9 | Link |
Anime addict
I have open sample with avidemux and playback properly.
Intel i7-6700K + Noctua NH-D15 + Z170A XPower G. Titanium + Kingston HyperX Savage DDR4 2x8GB + Radeon RX580 8GB DDR5 + ADATA SX8200 Pro 1 TB + Antec EDG750 80 Plus Gold Mod + Corsair 780T Graphite |
artifacts, block, cuda, dgindexnv, error |
