Old 17th March 2015, 21:19   #361  |  Link
Selur
Selur's Avatar
Only the LWLibavVideoSource builds with libav should be able to handle 10bit x264 content, right?
Notice: Since email notifications do not work here any more, it might take me quite some time to notice a reply to a thread,..
Old 18th March 2015, 03:54   #362  |  Link
the_weirdo
Yes, I'm weird.
the_weirdo's Avatar
No. Both builds with FFmpeg and Libav should be able to do that.
“Never argue with stupid people, they will drag you down to their level and then beat you with experience.” — Mark Twain
the_weirdo is offline   Reply With Quote
Old 18th March 2015, 06:38   #363  |  Link
Selur
Selur's Avatar
Strange, for me both don't.
L-SMASH-Works-r729-20141117-32bit-Libav
L-SMASH-Works-r784-20150301-32bit
both only produce garbled output and my script looks like this:
LoadPlugin("G:\MkvCutter\LSMASHSource.dll")
LWLibavVideoSource("H:\Output\HIGH10~1.MKV", cache=false)
Here's also the mediainfo data of the source:
General
Count                                    : 303
Count of stream of this kind             : 1
Kind of stream                           : General
Stream identifier                        : 0
Unique ID                                : 173785410236381370390882345944681015379
Unique ID                                : 173785410236381370390882345944681015379 (0x82BDDA40884D25E1AF571D15FC4FE853)
Count of video streams                   : 1
Video_Format_List                        : AVC
Video_Format_WithHint_List               : AVC
Codecs Video                             : AVC
Video_Language_List                      : English
Complete name                            : h:\Output\high10_10bit.mkv
Folder name                              : h:\Output
File name                                : high10_10bit
File extension                           : mkv
Format                                   : Matroska
Format                                   : Matroska
Format/Url                               : http://packs.matroska.org/
Format/Extensions usually used           : mkv mk3d mka mks
Commercial name                          : Matroska
Format version                           : Version 4 / Version 2
Codec                                    : Matroska
Codec                                    : Matroska
Codec/Url                                : http://packs.matroska.org/
Codec/Extensions usually used            : mkv mk3d mka mks
File size                                : 7234313
File size                                : 6.90 MiB
File size                                : 7 MiB
File size                                : 6.9 MiB
File size                                : 6.899 MiB
Duration                                 : 17160
Duration                                 : 17s 160ms
Duration                                 : 00:00:17.160
Duration                                 : 00:00:17:04
Duration                                 : 00:00:17.160 (00:00:17:04)
Overall bit rate                         : 3372640
Overall bit rate                         : 3 373 Kbps
Frame rate                               : 25.000
Frame rate                               : 25.000 fps
Frame count                              : 429
Stream size                              : 143963
Stream size                              : 141 KiB (2%)
Stream size                              : 140.6 KiB
Proportion of this stream                : 0.01990
Encoded date                             : UTC 2015-03-17 20:03:51
File creation date                       : UTC 2015-03-17 20:03:44.514
File creation date (local)               : 2015-03-17 21:03:44.514
File last modification date              : UTC 2015-03-17 20:03:51.913
File last modification date (local)      : 2015-03-17 21:03:51.913
Writing application                      : mkvmerge v7.5.0 ('Glass Culture') 64bit built on Jan 26 2015 13:43:13
Writing library                          : libebml v1.3.1 + libmatroska v1.4.2
Encoding Gui                             : Hybrid 2015.03.16.1
Video
Count                                    : 297
Kind of stream                           : Video
StreamOrder                              : 0
Unique ID                                : 6920789142181302940
Format                                   : AVC
Format/Info                              : Advanced Video Codec
Format/Url                               : http://developers.videolan.org/x264.h
tml
Commercial name                          : AVC
Format profile                           : High 10@L3.0
Format settings                          : CABAC / 4 Ref Frames
Format settings, CABAC                   : Yes
Format settings, ReFrames                : 4
Format settings, ReFrames                : 4 frames
Internet media type                      : video/H264
Codec ID                                 : V_MPEG4/ISO/AVC
Codec ID/Url                             : http://ffdshow-tryout.sourceforge.net
Codec                                    : V_MPEG4/ISO/AVC
Codec                                    : AVC
Codec/Family                             : AVC
Codec/Info                               : Advanced Video Codec
Codec/Url                                : http://ffdshow-tryout.sourceforge.net
Codec profile                            : High 10@L3.0
Codec settings                           : CABAC / 4 Ref Frames
Codec settings, CABAC                    : Yes
Codec_Settings_RefFrames                 : 4
Duration                                 : 17160
Bit rate                                 : 3305524
Bit rate                                 : 3 306 Kbps
Width                                    : 640
Width                                    : 640 pixels
Height                                   : 352
Height                                   : 352 pixels
Pixel aspect ratio                       : 1.000
Display aspect ratio                     : 1.818
Display aspect ratio                     : 16:9
Frame rate mode                          : CFR
Frame rate mode                          : Constant
Frame rate                               : 25.000
Frame count                              : 429
Resolution                               : 10
Resolution                               : 10 bits
Colorimetry                              : 4:2:0
Bit depth                                : 10
Bit depth                                : 10 bits
Scan type                                : Progressive
Interlacement                            : PPF
Interlacement                            : Progressive
Bits/(Pixel*Frame)                       : 0.587
Delay                                    : 0
Delay                                    : 00:00:00.000
Delay, origin                            : Container
Stream size                              : 7090350
Stream size                              : 6.76 MiB (98%)
Stream size                              : 7 MiB
Stream size                              : 6.8 MiB
Stream size                              : 6.762 MiB
Proportion of this stream                : 0.98010
Writing library                          : x264 - core 146 r2538 121396c
Writing library                          : x264 core 146 r2538 121396c
Writing library/Name                     : x264
Writing library/Version                  : core 146 r2538 121396c
Encoding settings                        : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x111 / me=hex / subme=5 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=0 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=0 / threads=12 / lookahead_threads=2 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=1 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc=cqp / mbtree=0 / qp=18 / ip_ratio=1.40 / pb_ratio=1.30 / aq=0
Default                                  : Yes
Default                                  : Yes
Forced                                   : Yes
Forced                                   : Yes
colour_description_present               : Yes
Matrix coefficients                      : BT.601
Color range                              : Limited
Old 18th March 2015, 08:14   #364  |  Link
qyot27
qyot27's Avatar
Unless something has changed, it's LSMASHSource itself that doesn't support >8 bit in AviSynth. It's probably just doing a straight input->output treatment of the pixfmt, and since AviSynth doesn't have >8 bit pixfmts, that's what you get. In VapourSynth you'd get the proper image.
Old 18th March 2015, 11:16   #365  |  Link
sneaker_ger
Yes, you have to force a compatible output format:
format="YUV420P8" or format="YUV420P16" (stacked)
Old 18th March 2015, 11:51   #366  |  Link
MeteorRain
結城有紀
This is exactly the correct output of a high bit depth video.
You'll need a tool that can display high bit depth preview, or, you'll have to force a 8 bit output, which is YUV420P8 as said above.
MeteorRain is offline   Reply With Quote
Old 28th March 2015, 14:35   #367  |  Link
stax76
stax76's Avatar
What is the runtime situation currently? Doesn't it work without installing a runtime? A few StaxRip users have problems running the plugin, for me it runs but I have installed Visual Studio 2013 Community Edition of course.
Old 28th March 2015, 14:37   #368  |  Link
sneaker_ger
If this is still true they need VC++2013: http://avisynth.nl/index.php/LSMASHSource
Old 28th March 2015, 14:47   #369  |  Link
stax76
stax76's Avatar
How much bigger would the file size be if it was statically linked and provided as 7z download? Could anybody help with a building and uploading this?
Old 26th April 2015, 15:36   #370  |  Link
kuchikirukia
So, is L-SMASH broken for decoding interlaced content out of MKV? I get jumps no mater which field order I use when using QTGMC.
kuchikirukia is offline   Reply With Quote
Old 26th April 2015, 16:22   #371  |  Link
LigH
LigH's Avatar
A broken interlacing is more probable; or Telecine instead of Interlacing. Did you provide a sample of your material?
New German Gleitz board
Old 26th April 2015, 16:52   #372  |  Link
kuchikirukia
It deinterlaces with DGDecode. It deinterlaces with L-SMASH out of .h264 (though it sets as 119/2 fps).
Out of MKV with QTGMC it thinks it's 120fps and it jerks back and forth if you set L-SMASH to 30000/1001 (though not quite as bad as if the field order is wrong).
[s]Out of MP4 with LSMASHVideoSource and no filters I got several instances of "failed to make a frame."
And that ain't right:[/s] E: never mind, that's in the mp4. First time I used this drive was for this MP4, so there might be an issue with it.
http://s14.postimg.org/t0wxc5cvh/untitled.jpg
Old 26th April 2015, 17:16   #373  |  Link
Music Fan
The problem can come from your mkv : if the original container of your video was ts, and if you opened it directly in MKVmerge, the framerate can be wrong, even if you specified the correct framerate in MKVmerge.
I noticed this problem with several interlaced H264 videos. After remux in MKV, MediaInfo detects VFR while it's CFR.
To avoid this, the ts has to be demuxed in elementary streams before remux in mkv.
But it's not too late, you can still demux mkv in elementary streams and remux it.
Music Fan is offline   Reply With Quote
Old 26th April 2015, 17:40   #374  |  Link
kuchikirukia
It was extracted with HD streams extractor, and it played at 30fps interlaced / 60fps LAV filter YADIF bobbed.
E: Ok, now it's not doing it. We're getting 60000/1001 and no jumping.
Old 26th April 2015, 19:47   #375  |  Link
Music Fan
What did you do to make it work now ? What I explained ?
Old 16th May 2015, 13:10   #376  |  Link
Overdrive80
Anime addict
Overdrive80's Avatar
Can not LSmash indexing avi files encoded with magicyuv???
http://forum.doom9.org/showthread.ph...04#post1722304
Intel i7-6700K + Noctua NH-D15 + Z170A XPower G. Titanium + Kingston HyperX Savage DDR4 2x8GB + Radeon RX580 8GB DDR5 + ADATA SX8200 Pro 1 TB + Antec EDG750 80 Plus Gold Mod + Corsair 780T Graphite
Overdrive80 is offline   Reply With Quote
Old 16th May 2015, 13:35   #377  |  Link
Reel.Deel
FFmpeg/Libav does not include MagicYUV. I just use AviSource.
Old 16th May 2015, 13:41   #378  |  Link
LigH
LigH's Avatar
As long as libavcodec doesn't contain a decoder for MagicYUV, L-SMASH Source may not support this video format. Even though I believe it would be possible to index an AVI regardless of the used codec; but why index a clip if the video codec is not supported in libavcodec, thus neither in ffmpeg nor in related projects like FFMS2 or L-SMASH Source.
Old 16th May 2015, 15:04   #379  |  Link
Overdrive80
Anime addict
Ok, thanks for both. I´ll use avisource.
Old 20th May 2015, 00:31   #380  |  Link
stax76
stax76's Avatar
I asked DG how he sends progress from DGIndex and DGIndexNV, his answer:
void OutputProgress(int progr)
	static int lastprogress = -1;
	if (progr != lastprogress)
		char percent[20];
		DWORD written;
		sprintf(percent, "%d\r", progr);
		WriteFile(GetStdHandle(STD_OUTPUT_HANDLE), percent, (DWORD) strlen(percent), &written, NULL);
		lastprogress = progr;
It would be very useful for GUI users to see progress.
